Old 10-28-2009, 07:13 PM
Last Online: 11-19-2009 05:49 PM
accrockett is on a distinguished road.
accrockett's Photo Albums
Default 110 power
I am trying to figure out a way to get 110 power in my 2006 DC Limited. I did not get the DVD entertainment system which comes with a power outlet. Nor do I want to install some bulky converter and have wires running everywhere.
So...has anyone figured out a cool way to wire in 110 power? I was looking at a Black & Decker inverter like this ( Amazon.com: Black & Decker VEC049DCB 1,000 Watt D/C To A/C Power Inverter With Power Level Meter: Home Improvement) but I am wondering if I can hardwire it straight to the battery. It would be cool to mount it in the console.
Or...can you get the OEM power outlet installed without having the entire DVD entertainment system?
Any ideas are appreciated.
ACC
Old 10-28-2009, 09:03 PM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Last Online: Today 07:06 PM
Images: 17
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Default Re: 110 power
You can hardwire inverters directly to your battery setup, but you can't mount the inverter in a location without significant air flow. The inverters just get too hot and will trip their overheat shutdown circuit. I've heard of some people mounting them under one of the seats, but I don't think that's a workable solution either. Again, no air flow.
2002 Tundra V8 SR5 AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 Truck & SUV | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
Old 10-29-2009, 12:46 AM
hofkamp83's Avatar
Dealer : Billion Motors
2005 Toyota Tundra
Last Online: Today 08:50 PM
Images: 49
hofkamp83 will become famous soon enough.
hofkamp83's Photo Albums
yes you do have to worry about airflow but what are looking at running off of the inverter and how long? if just some small equipment like a labtop or small appliance then just a 400/800 rms/peak will be fine under a seat and a power wire from the battery and just ground it to a seat bolt with a inline fuse the size of fuse on the inverter. that 1000 watt one will be fine under the seat also if run for a limited time like under a hour or so, but if your are going to run it for several hours with like a fridge on it then you may have heat problems. that is a good size one, if it were me i would put it in and run 4 guage wire with the same size fuse on the inverter ( if there are multiple just add them together and use that number) and monitor the heat often with a load attached. if it burns your hand within a couple minutes then you have a heat problem, but if after 45 minutes or so and the heat is little warm to the touch you are good to go. I have run several under seats and never ran extra cooling without problems and about the only other place you can run them would be in the engine compartment or under the truck but both have there disavantages with heat and water.
Andrew
2005 Toyota Tundra Access Cab Limited
Goodyear Wrangler Silent Armor LT285/70R17, Bilstien 5100's, 1" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, K&N CAI, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Spidertraxx Adapters, Herculiner Roll On Bed Liner
Full LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
Tags
power , wiring
