Old 11-01-2009, 01:26 PM
Dealer : Stevinson Toyota West Inc
2004 Toyota Tundra
Last Online: 11-02-2009 01:26 PM
Spatten1 is on a distinguished road.
Spatten1's Photo Albums
Default Oil Coming from Breather
This question is for a 2004 double cab 4wd.
I changed my transfer case and differential oils, and now I have oil coming out of the smaller of the two underhood breather tubes. It looks like it goes to the front differential.
I pulled the front diff plug and the level seems correct.
Is it normal to lose oil out of the breather after a oil change if the level is correct?
Thanks in advance.
Scott
Old 11-01-2009, 06:27 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 06:27 PM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Default Re: Oil Coming from Breather
Still over serviced if oil is coming out! it should be below the inside opening of the hole just a tad!
Old 11-02-2009, 01:26 PM
2004 Toyota Tundra
Thanks for the reply.
My garage is at a slight angle, didn't think that would make much of a difference, only slightly more oil. Turned the truck around, draining slowly from the level hole now.
Preciate the help.
Old 11-08-2009, 01:54 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 12
Most gear oil has anti-foaming agents but some have more than others but as long as you keep it below the inside of the round opening it should not vent! Finding a flat level surface is important and you should check and sercvice it at this same place to keep from having this breather overflow! big mess to clean up but that is what they made WD40 for and then just wash it off once ya get the level correct!
Old 11-08-2009, 01:58 PM
5 Speed's Avatar
Dealer : Longo Toyota
Last Online: Today 03:41 PM
Images: 19
5 Speed will become famous soon enough.
5 Speed's Photo Albums
Look at it this way, where it is coming out is the only place on my tundra frame that doesn't have any rust
