Old 11-03-2009, 12:40 PM
tundrunk's Avatar
2003 Toyota Tundra sr5 1wd
Last Online: Today 01:34 AM
Images: 18
tundrunk is a splendid one to behold. tundrunk is a splendid one to behold. tundrunk is a splendid one to behold.
tundrunk's Photo Albums
Default anybody seen these?
ive always wondered whats up with these but i have an idea what they do. ever notice behind the rear seat on the back wall, there are two big plastic covered vents? i imagine its to relieve pressure on hot days when you dont crack the window but does anybody have some input? i saw them and hear them loud and clear since i yanked my useless weight we call a back seat. ive got an 03 access cab btw, not sure if these are on crews. they make the most annoying noise even after stuffing rags in them. thought about cutting them out n welding in some sheet metal but it looks like you have to pull the bed to get them. also my bed is a little off center side to side, doesnt bother me but does anybody else have that?
Old 11-03-2009, 03:24 PM
Marauder's Avatar
Last Online: 11-22-2009 09:55 PM
Images: 16
Marauder is on a distinguished road.
Marauder's Photo Albums
Default Re: anybody seen these?
not sure what the design intent was, maybe to help vent the air like when you have the fan on.
I blocked one, since I mounted my amp on the back wall. never heard noise coming from mine, but I still have the rear seat there to help hide any noise. Then again, my amp helps to make a lot of speaker noise to drown out all other noises.
Those are probably there so you can actually open the door in case you happen to pull a vacuum inside the cabin, like parking it while hot and then cools overnight. I know when I was working designing equipment cases, even with a little vacuum inside a sealed case, you could not pry open the case with your hands. So they probably do that so you can open your doors.
2006 Tundra Access Cab V8 - TRD
16x8 Konig Countersteer w/Nitto TerraGrapplers 285/75R16
Bilstein 5100 front/rear, Wheelers 1.5" rear blocks
Dynomax cat-back w/Cherry Bomb Pro muffler
Pioneer headunit w/Alphasonic amp and Sochse speakers
HID retrofit in the works, Acura TL bi-xenon projectors w/BMW ZKW lenses
Truxedo Truxport
Trail FX black steps bars
Old 11-03-2009, 03:29 PM
tundrunk's Avatar
Images: 18
thanks for that explanation. i hadnt thought of vaccum. i never heard the noise until i pulled the seat, its the wind sound when i drive and if i have the fan pulling in fresh air, these things whistle. they do seem to have a one-way flap in them. anybody else know whats up with these?
Old 11-03-2009, 05:00 PM
csawyer's Avatar
Last Online: Yesterday 09:51 PM
csawyer is on a distinguished road.
csawyer's Photo Albums
I've never noticed them. Part of the cabin air filtration system maybe??
Chris
Old 11-03-2009, 05:32 PM
hofkamp83's Avatar
Dealer : Billion Motors
2005 Toyota Tundra
Last Online: Yesterday 08:38 AM
Images: 49
hofkamp83 will become famous soon enough.
hofkamp83's Photo Albums
I have found these on ford trucks also, made it nice to run wires into and out of the truck like antenna wires for cb and sirius. I think a vent is probably the best choice to prevent a vacume seal in my opinion.
Andrew
2005 Toyota Tundra Access Cab Limited
Goodyear Wrangler Silent Armor LT285/70R17, Bilstien 5100's, 1" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, K&N CAI, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Spidertraxx Adapters, Herculiner Roll On Bed Liner
Full LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
Old 11-03-2009, 05:44 PM
spennrocks's Avatar
Dealer : Team Toyota
2003 Toyota Tundra
Last Online: 11-20-2009 03:29 PM
Images: 2
spennrocks is on a distinguished road.
spennrocks's Photo Albums My eBay
I did the same thing with my accesscab.
only after ditching the back seat, i bolted a piece of plywood with some high density foam stuffed in between. then stapled some carpet on the plywood.
no more road noise, and plenty of cargo space to spare.
Old 11-03-2009, 06:44 PM
tundrunk's Avatar
Images: 18
10-4. i searched for an answer before but never found one. its not a filter or part of the ducting. i think you guys are right with the vacuum theory. i was thinking pressure relief but either way. thanks for the replies.
Old 11-03-2009, 07:07 PM
Greenie's Avatar
Dealer : Hoover Toyota Scion
Last Online: Yesterday 11:58 AM
Greenie is the One. Greenie is the One. Greenie is the One. Greenie is the One. Greenie is the One. Greenie is the One. Greenie is the One. Greenie is the One. Greenie is the One. Greenie is the One. Greenie is the One.
Greenie's Photo Albums
These are vents to allow flow through ventilation. This has been discussed before in an old thread. See post #2.
Interior Soundproofing
More's Law: If more's good then too much is just right.
CBTMA member
