Re: Driving light loose/vibrates
The lower driving light on mine is just held in by 2 tabs on either side of the light, and then the adjuster in the middle has a snap ring also. In order to remove them I have to pop on side out of the tab, then put a flathead screwdriver in the other side (looking up from the ground, far left side of the light) to pop it out of the hole. I'm not sure what you could jam in the hole to keep it from vibrating.
05 DC SR5 4X4
bilstein 5100's front, diff drop, tekonsha p3, nasta stainless step bars, aftermarket fogs, vent visors, flowmaster 40, removed resonator, clear corners
