Old 11-05-2009, 12:06 AM
Last Online: 11-06-2009 05:58 PM
legos7997@yahoo.com is on a distinguished road.
legos7997@yahoo.com's Photo Albums
Default 3 in leveling with 33in tires ???????
ok so the procomp 3 in leveling kit and the aal states i can run 33"s so when i put 305-55-20 on why are they rubbing????? Has anyone with this setup used the 1 in body lift? and will that fix the rubbing???? please help i hate body lifts
Old 11-05-2009, 01:37 AM
tundrunk's Avatar
2003 Toyota Tundra sr5 1wd
Last Online: Today 01:34 AM
Images: 18
tundrunk is a splendid one to behold. tundrunk is a splendid one to behold. tundrunk is a splendid one to behold.
tundrunk's Photo Albums
Default Re: 3 in leveling with 33in tires ???????
need more info to help bud. whats the backspace on the wheels? 4.5"bs is as pushing it, you want that or less otherwise you will hit frame or uca. what are you rubbing on? my 33s rubbed a bit when turning and compressing at the same time. i trimmed a little off my front bumpers and its fine now. i have 4" of lift over stock.
Old 11-05-2009, 12:34 PM
Last Online: 11-24-2009 09:51 AM
accrockett is on a distinguished road.
accrockett's Photo Albums
305's are bigger than 33". My 295's (33.17") wouldn't fit with 2.5" coil spacers and I had to drop down to 285's (32.7") to get them to fit without major rubbing.
Old 11-05-2009, 02:22 PM
wheel back spacing is 25mm. the wheel is rubbing on the cab side of the fender flare pretty bad. has anyone used the daystar 1.5 body lift with the 3 in leveling kit???
