Old 11-05-2009, 12:35 PM
Last Online: 11-06-2009 09:29 AM
rick5472 is on a distinguished road.
rick5472's Photo Albums
Default Tire Pressure Sensor Leak
Hello All,I have a 2005 Toyota Tundra regular cab 4x2. I checked the tire pressure the other day on the truck and drove the truck to work and when I left I found one of my tires flat. Needless to say, I discovered that the tire had a slow leak from the valve stem probably caused by checking it with a gage or filling it from the air chuck. Eventually the valve seated and no longer leaked. The question(s). Can the valve stem be repaired/replaced without removing the tire from the wheel? Is this common with this type of system? In the old days you could remove the valve stem. Can these be removed and perhaps tightened? I appreciate any info on this as I am monitoring my dash pressure indicator and hoping it stays off. I also understand that this light can come on if the spare is low as well. Thanks !
Old 11-05-2009, 12:50 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Default Re: Tire Pressure Sensor Leak
Gen1...thread is moving there.
Beer please!
Old 11-05-2009, 09:30 PM
tundra05_trd's Avatar
Dealer : Norm Wagner Toyota
2005 Toyota Tundra
Last Online: Yesterday 10:32 PM
Images: 10
tundra05_trd is on a distinguished road.
tundra05_trd's Photo Albums
Do you mean the little spring valve core? If thats not seating, you can get them cheap and theres a special tool to do it. Any auto parts store should have them. If its leaking around the valve stem itself(by the rim), it could be a bigger problem. Either its the gasket where the tpms attaches, or the stem is cracked which would really suck.
2005 Stepside TRD AC- phantom grey, 2.5" cornfed lift, 285/65/18 Nitto Terra Grapplers on Pro Comp 18x9 9089's, dual magnaflow out same side, k+n fipk, pioneer dvd, 2 infinity kappa 8's under rear seat, all Infinity kappa components in doors, passport 8500, Scangauge II w/ blendmount, clear corners,tint, Tonneaumasters tonneau cover, fog light mod, silverstars, SAW's or Toytec coilovers next, maybe uniballs too $$$$
Old 11-06-2009, 12:08 AM
Sizematters75's Avatar
Dealer : Toyota Scion of Stuart
2005 Toyota Tundra,
2007 Lexus IS250 -other-,
2006 Toyota RAV4 -wife's family car-
Last Online: 11-19-2009 04:53 PM
Images: 6
Sizematters75 is on a distinguished road.
Sizematters75's Photo Albums
Rick,
Do you knwo if the air was leaking through the valve or around the valve? If it was coming throught the valve then yes bring it to Toyota and they can tighten the inner pin back. If it is leaking from around the valve you will need to have the tired broke down and replace the o-rings that sit between the rim and the valve. I had to do this when i had my ris replaced.
2005 Tundra Dbl Cab Desert Sand
20" Enki Deep Six w/ 305/55R20 Cooper Zeon LTZ A/T
Flowmaster 50 Series Cat Back Dual Exhaust
Airaid Cold Air Intake
Airaid Throttle Body Spacer
Alpine w505 InDash Navigation w/ Blackbird
Kicker Comp VR12 Solobaric in custom over seat box
Kicker 1000.1 ZX Mono Amp
ARE Fiberglass Topper
XenonWorks 8,000k UltraWhite H.I.D.'s.
Hertz Mille' MLK 2 Components Hertz Mille' ML1600's 6.5's
Bilstein 5100's set a 2.0" in front
Wheeler's 1" lift blocks, Rancho RS9000XL in rear
Recon Bed Lights
Old 11-06-2009, 08:13 AM
Yes...the schrader valve is leaking and it doesn't always fully seat after checking tire pressure with a gage or filling with air from an air chuck. I was wondering if they had the same innards as a regular schrader valve. They used to have the valve cap that had a side with 2 slots used for inserting into the valve body that you could tighten or remove the guts. I am wondering if the valves on TPMS sensors have the same configuration? Thanks again.
