Old 11-05-2009, 10:43 PM
Last Online: 11-12-2009 12:20 AM
ondown is on a distinguished road.
ondown's Photo Albums
Default LSD or NOT
Bought an 06 4.0 access 2wd about a month ago. Didn't think it had the LSD, but when I punch it in the dirt parking lot it appears both tires are driving. Is there a plate or label were I can locate a build code for the LSD?
Old 11-05-2009, 11:13 PM
Sizematters75's Avatar
Dealer : Toyota Scion of Stuart
2005 Toyota Tundra,
2007 Lexus IS250 -other-,
2006 Toyota RAV4 -wife's family car-
Last Online: 11-19-2009 04:53 PM
Images: 6
Sizematters75 is on a distinguished road.
Sizematters75's Photo Albums
Default Re: LSD or NOT
THe 06's would have a sticker on the rearend stating LSD or not.
Though I have LSD in mine but dont have the sticker. If you go to your local dealer and have them run the VIN they can tell you if it does or not.
2005 Tundra Dbl Cab Desert Sand
20" Enki Deep Six w/ 305/55R20 Cooper Zeon LTZ A/T
Flowmaster 50 Series Cat Back Dual Exhaust
Airaid Cold Air Intake
Airaid Throttle Body Spacer
Alpine w505 InDash Navigation w/ Blackbird
Kicker Comp VR12 Solobaric in custom over seat box
Kicker 1000.1 ZX Mono Amp
ARE Fiberglass Topper
XenonWorks 8,000k UltraWhite H.I.D.'s.
Hertz Mille' MLK 2 Components Hertz Mille' ML1600's 6.5's
Bilstein 5100's set a 2.0" in front
Wheeler's 1" lift blocks, Rancho RS9000XL in rear
Recon Bed Lights
Old 11-06-2009, 08:02 AM
Last Online: 11-19-2009 11:51 AM
WhiteLiteNin is on a distinguished road.
WhiteLiteNin's Photo Albums My eBay
ondown,
look at the rear differential cover. this is where the LSD sticker would be located.
Old 11-06-2009, 05:05 PM
What should the sticker say?
Old 11-06-2009, 05:09 PM
dubktrd's Avatar
Last Online: Today 05:18 PM
dubktrd is on a distinguished road.
dubktrd's Photo Albums
it would say lsd
Old 11-06-2009, 05:22 PM
It only has a tag that has the # 82 and two faded letters on it. Looks more like a inspection tag. Thanks for the help, Ill get the dealer to run the vin.
Old 11-06-2009, 10:43 PM
tundratoy04's Avatar
Dealer : Brunswick Auto Mart
2004 Toyota Tundra,
1995 Toyota Camry LE Wagon (Family),
2001 Toyota Echo Coupe (Wifes Car),
- Other - 1992 Cadilac Sedan
Last Online: 11-10-2009 10:50 AM
Images: 88
tundratoy04 will become famous soon enough. tundratoy04 will become famous soon enough.
Send a message via Yahoo to tundratoy04 tundratoy04's Photo Albums
Just jack up the rear end, turn the ignition on but don't start it, put it in drive rotate one tire in a forward direction and if the other rotates the same direction you most likely have an LSD rear end. If one rotates reverse while the other rotates forward you defiantly do NOT have LSD.
PS safety first block the front wheels!!!!!!!!!!
SR5 Double Cab 4x4 De-Badged
Bilstein 5100 Adj Front Shocks Set at 1.3" Inside TRD Coils
1" Frt Diff Drop
Bilstein 5100 Rear Shocks
Front & Rear Timbens
Removed "Y" Pipe - Gibson Extreme Dual Exhaust
265/70/17 LTX MS Tires
K&N Air Filter
Old 11-07-2009, 03:09 PM
tundrunk's Avatar
2003 Toyota Tundra sr5 1wd
Last Online: Today 05:58 PM
Images: 18
tundrunk will become famous soon enough.
tundrunk's Photo Albums
I was wondering the same a while ago. I checked for the tag, too faded to read. I called toyota, they checked the vin and said I have a tow package but couldn't confirm the rear end. the tech told me to just power brake for a few seconds and watch the driver side tire, so to the dirt I went and found I'm a 1wd dog legger. only the passenger side spins if you have an open diff.
Old 11-07-2009, 03:58 PM
scottnmos's Avatar
E PLURIBUS UNUM
Dealer : Nye Frontier Toyota/Scion
2001 Toyota Tacoma Xtra Cab....SOLD,
2008 Toyota Tundra 5.7 4x4 SR5 Crew Max,
2004 Toyota Tundra 4.7 4x4 DC SR5-Sold,
1993 Toyota 4Runner SR5 Wheelin' Machine
Last Online: Today 02:24 PM
scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor. scottnmos is a superior contributor.
scottnmos's Photo Albums
There is a post on here that states there is a drain plug difference for the lsd vs the non lsd. If you do some searching it should turn up. Basically the drain plug will be on one side for the lsd equipped diff vs the non lsd.....
Old 11-07-2009, 11:19 PM
kerryman71's Avatar
Dealer : Harr Toyota
2002 Toyota Tundra SR5 AC V8 4X4 TRD
Last Online: Yesterday 03:43 PM
Images: 27
kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything.
kerryman71's Photo Albums My eBay
This is the way to do it, or punch it like you said you did in some dirt and
see if it leaves two sets of tracks. I did the VIN route with the dealer
and they couldn't tell me either way.
John
The fools, the fools the fools! They have left us
our Fenian dead, and while Ireland holds these
graves, Ireland unfree shall never be at peace!
Padraig Mac Piarais (Patrick Pearse)
Old 11-08-2009, 06:06 PM
Dealer : Sunrise Toyota Scion
2004 Toyota Tundra
Last Online: 11-11-2009 05:10 PM
John-O is on a distinguished road.
John-O's Photo Albums
You can't always tell if you have an LSD if you leave two spin tracks in dirt. If both rear tires have the same traction a non LSD rear end can leave two spin tracks. I do it all the time when I was pulling tree stumps out from my back yard. I have an LSD in the rear but an open differential in the front (non-LSD) and I almost always have two spin ruts from my front tires.
Old 11-08-2009, 06:20 PM
single's Avatar
Mech. Engr. / Mechanic
Dealer : Riverside Toyota Tulsa
2006 Toyota Tundra SR5 DC
Last Online: 11-19-2009 06:56 PM
Images: 21
single will become famous soon enough.
single's Photo Albums
Correct, I could leave two spin tracks in gravel with my truck. Had to add LSD anyway, needed the traction when it mattered.
White 06 SR5 DC - Westin Nerf bars
Blinglights bedlights - Pop A Lock tailgate lock
TRD aftermarket LSD - Custom Back Up Lights
ScanGaugeII+X - Factory Fogs added
Hellwig 7700 - Firestone Sport Rite Air Springs
Old 11-08-2009, 06:34 PM
tundrunk's Avatar
Images: 18
that's interesting. the guy at toyota told me to do it on the street, but I'm not looking to wear out my nice tires. that's why I went for dirt. Only one tire spins for me, especially if I'm turning. I never checked for marks, I watched the actual tires. Could this be a 2wd vs 4wd difference? The drain plug scott mentioned sounds like a good way to know as long as your truck hasn't had lsd installed since leaving the factory.
Old 11-08-2009, 10:23 PM
scottnmos's Avatar
E PLURIBUS UNUM
I just checked your first post.... I dont recall any v6 tundras being equipped with a LSD, mostly SR5's with TRD package...2 wheel tracks are very common on dirt regardless of open or limited slip...sorry to break it to ya but I am pretty sure you dont. That shouldnt keep ya from getting one though...
Old 11-11-2009, 11:21 AM
HobbesHas1's Avatar
Last Online: 11-18-2009 10:30 PM
HobbesHas1 is on a distinguished road.
HobbesHas1's Photo Albums
Saweeet! I thought that I did not have LSD, but I looked at the cover and someone wrote LSD on it in yellow marker. I put the parking brake on in the dirt and punched it - sure enough the right spun for about half a turn then the truck lunged forward with both wheels driving. Good times to come
2003 Tundra SR5 Access cab 2WD
