Old 11-06-2009, 05:57 PM
tundraman89's Avatar
Dealer : Toyota and Scion Mall of Georgia
Last Online: 11-18-2009 09:48 PM
Images: 34
tundraman89 is on a distinguished road.
Send a message via MSN to tundraman89 Send a message via Yahoo to tundraman89 tundraman89's Photo Albums
Default What a day What a day
As i was leaving work at 12 to go to lunch i turned out of the driveway and it started to spin then the rear end got in a bind and now is stripped out. I have to lock in it 4wd to move it ugh!!
2000 tundra 4.7L TRD Limited AC cab.
Mods
-Windows tinted
-Highland floor mats
-Maganaflow single in dual out
with 3 " tips
-16x10" rims 5 spoke Ultra
Stargazer chrome plated
-One 10" speaker with a 400
watt amp Under back seat
-Interior lights changed to blue
-Red blinkers
-Sirus radio
-Volant cold air intake
-Ready lift leveling kit
-Tool box
-Hitch recevier
-Chrome step sides
-Chrome bed rails
-Chrome grille guard with spot
lights
-White face gauges
Old 11-06-2009, 06:27 PM
tundrunk's Avatar
2003 Toyota Tundra sr5 1wd
Last Online: Today 02:59 AM
Images: 18
tundrunk will become famous soon enough.
tundrunk's Photo Albums
Default Re: What a day What a day
ouch bud. So I take it your rear end has ended its life? Think that had something to do with the hard shifts you mentioned the other day? Thats why im scarred to smoke my tires, with my luck I'd blow my rear end and be pushing 5klbs home.
Old 11-06-2009, 06:38 PM
Images: 34
I'm not sure i think that is in the trans, but i can smoke my tires like hell just something got in a bind but we are going to pull the pan off Monday morning and see what is tore up. If it is just the pinion gear then i will replace that if its more tore up than that then i will get a new rear end from Toyota for 966 list 1375. While i'm at it i will change my trans filter and fluid.
Mods
-Windows tinted
with 3 " tips
-Red blinkers
-Sirus radio
-Tool box
-Hitch recevier
-Chrome step sides
-Chrome bed rails
lights
-White face gauges
Old 11-06-2009, 08:23 PM
tundra05_trd's Avatar
Dealer : Norm Wagner Toyota
2005 Toyota Tundra
Last Online: Today 01:00 AM
Images: 10
tundra05_trd is on a distinguished road.
tundra05_trd's Photo Albums
Just so you know, there's no "pan" on Toyota rear ends. You will have to pull the axles, then the driveshaft, then unbolt the third member to see what went wrong. Look on the brite side, its a good time to upgrade to a LSD. I bet you can get new gears, and a LSD and have someone set it up for less than $966. And you can just bring the whole third member to them, not the whole truck.
2005 Stepside TRD AC- phantom grey, 2.5" cornfed lift, 285/65/18 Nitto Terra Grapplers on Pro Comp 18x9 9089's, dual magnaflow out same side, k+n fipk, pioneer dvd, 2 infinity kappa 8's under rear seat, all Infinity kappa components in doors, passport 8500, Scangauge II w/ blendmount, clear corners,tint, Tonneaumasters tonneau cover, fog light mod, silverstars, SAW's or Toytec coilovers next, maybe uniballs too $$$$
Old 11-06-2009, 08:44 PM
navytoy82's Avatar
Here for the long haul!!!!
2006 Toyota Tundra,
1999 Toyota Tacoma Sold (Man I miss it),
- Other - 2005 Acura MDX,
2005 Toyota Camry-Solara (Sold)
Last Online: Today 09:19 AM
Images: 7
navytoy82 is on a distinguished road.
navytoy82's Photo Albums My eBay
Man that sucks but on a positive note like tundra05_trd said its a third member so you can pull it out and most likely just rebuild it yourself on the workbench at home if you have some mechanical knowledge. Add a some new gears and an LSD or possibly a locker!!!!! Godd luck man.
2006 Tundra XSP DC, 4WD, 3" ToyTec Lift, Camburg UCA, 32" Cooper Zeon's, FloPro Custom Exhaust, Fitch Fuel Catalyst, N-Fab Nerf Steps, KC slimlites.
Old 11-07-2009, 12:16 AM
Images: 34
I would rebuild it but i don't have time. I got money but not time. So i can buy a brand new one and have it on wed and be rolling again. I think i have lsd but I'm not sure either. I know it don't really have a pan i just couldn't think what to say at that moment but we are going to pull the drive shaft out and take the cover off or whatever you want to call it and see whats messed up it could be just as simple as a pin come out but don't know.
Mods
-Windows tinted
with 3 " tips
-Red blinkers
-Sirus radio
-Tool box
-Hitch recevier
-Chrome step sides
-Chrome bed rails
lights
-White face gauges
Old 11-07-2009, 09:10 AM
navytoy82's Avatar
2006 Toyota Tundra,
Images: 7
Well let us know what exactly happened once you get it apart. Good Luck
Old 11-08-2009, 10:34 PM
Dealer : Apple Valley Toyota
Last Online: Today 12:25 AM
400exboy2 is on a distinguished road.
400exboy2's Photo Albums
In order for the third member to come out, you have to pull your axles out. Easy to do though.( four bolts on each side, and two break lines). I feel your pain man, Im getting ready to put/build my third rear in my truck. I blew the first one out acting stupid one day. The second one I had $5000 invested in. 4.56 gears, Detroit locker, chrome alloy axles, bearings, seals etc. Ended up doing a little burnout one day in the rain and it started hoping and one of my bolts that hold my pinion gear in fell out and chewed the whole locker up. Wasn't a good night. Only got 8,000 miles out of it. Now its been sitting in the garage for the last six months with no motor or rear axle. It sucks man, it really does.
Old 11-09-2009, 12:32 AM
tundrunk's Avatar
Images: 18
damn 400! that's a tear jerker there. I knew wheel hop was bad but that's crazy.
Any updates so far tundraman?
The stories you guys shared are making my foot lose weight faster than the hollywood diet!
Old 11-09-2009, 07:01 AM
Images: 34
See i have been doing burnout latley just to show off but when this happen i wasent even doing anything and i think the bolt fell out like you was saying happend to yours. Tundrunk no i don't but im going to start on it at 8:00 this morning i will let yall know this afternoon.
Mods
-Windows tinted
with 3 " tips
-Red blinkers
-Sirus radio
-Tool box
-Hitch recevier
-Chrome step sides
-Chrome bed rails
lights
-White face gauges
