Old 11-07-2009, 08:42 PM
MC3156's Avatar
2006 Toyota Tundra,
2006 Toyota 4Runner
Last Online: 11-07-2009 09:49 PM
MC3156 may have some regrets.
MC3156's Photo Albums
Default turn signals and back-up lights not working - 06 tundra
My turn signals and backup lights all of a sudden are not working on my 2006 tundra 4x4. I am not sure if it is coincidence or not but I hooked up my utility trailer when I noticed it, they were working fine earlier in the day. I know that the wiring on the trailer is good because I just rewired the trailer and hooked it up once before and it all worked fine. The only difference is that I did not put the truck in gear, this time I did and now no signals or backups. All other lights work, and my hazzards work, checked all fuses...I am out of ideas - please help if you can.
Old 11-07-2009, 10:48 PM
hofkamp83's Avatar
Dealer : J. Pauley Toyota Scion
2005 Toyota Tundra
Last Online: Yesterday 10:52 PM
Images: 70
hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold. hofkamp83 is a splendid one to behold.
hofkamp83's Photo Albums
Default Re: turn signals and back-up lights not working - 06 tundra
I had a similar problem on another truck a little while back, whenever i plugged in a trailer to the harness the back up lights would come on until the fuse popped, i found the problem to be a short in the plug on the truck that was fine without the trailer plugged in, but when it was plugged in it would short.
so the hazards will work but the left or right signal by themselves would not work along with the back up lights? when you unhook the trailer do the lights start working again? Sounds like you have wire problem somewhere which is going to be a pain trying to track down. If you say the trailer wiring is good i would start at the back of the truck and start tracing wires and hopefully you can find a bad spot like the wires cut or pinched. good luck.
Andrew
2005 Toyota Tundra Access Cab Limited
Goodyear Wrangler Silent Armor LT285/70R17, Bilstien 5100's on Top Notch, 3" Body Lift, 1.5" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, K&N CAI, Headers, Y-Pipe, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Spidertraxx Adapters, Blacked Factory 17" Alloy Wheels, Herculiner Roll On Bed Liner
Full LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
Old 11-07-2009, 10:56 PM
Dealer : Magness Toyota
2002 Toyota Tundra
Last Online: 07-28-2010 09:45 PM
Images: 4
ctateusa is a splendid one to behold. ctateusa is a splendid one to behold. ctateusa is a splendid one to behold. ctateusa is a splendid one to behold. ctateusa is a splendid one to behold. ctateusa is a splendid one to behold. ctateusa is a splendid one to behold. ctateusa is a splendid one to behold. ctateusa is a splendid one to behold.
ctateusa's Photo Albums
a good tool to have is a trailer wiring checker to determine if the problem is in the truck wiring or a problem with the trailer wiring.
Sponsored Links
