Re: leveling kit for 2003 Tundra step side?
If you want a nice ride do what most everybody here did. get bilstein 5100 shocks. Look around for the million posts about them. spacers cost about the same so do it right, you will hate the ride quality with a spacer lift. If $ is no biggie, and you don't mind doin some research, check out full coilovers. look at my pics, those are toytecs, fully adjustable ride height. If you go too far up, you will need uniball upper control arms, if you have 4wd, you will need a diff drop kit and will likely have cv joint issues. check around, best thing to read is the second sticky in the off-road section. its under devinsixtyseven's name, off-road tundra mods.
