tire sizes 265/70/16 vs.265/75/16 ?
+ Reply to Thread
Results 1 to 12 of 12
Thread: tire sizes 265/70/16 vs.265/75/16 ?
  1. #1
    Join Date
    Sep 2008
    Location
    malone
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Default tire sizes 265/70/16 vs.265/75/16 ?
    is the 265/70/16 a wider tire or is the 265/75/16 the wider one.cant remember. think the smaller number means a wider tire.also is one taller then the other one.thanks
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Sep 2008
    Location
    malone
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default Re: tire sizes 265/70/16 vs.265/75/16 ?
    also should i go with the 70 or 75 size tire on my 2000 tundra sr5.
  4. #3
    Junior Member NegroTundra's Avatar
    Join Date
    Aug 2009
    Location
    Land of Enchantment
    Posts
    423
    Liked
    8 times
    Images
    13
    Rep Power
    30
    Should be the same width. 75 tire is a little taller. Here is a great website for comparables. Tire Size Calculator - tire & wheel plus sizing
    2007 Tundra TRD 4x4 CrewMax 5.7
  5. #4
    Supporter bamafire's Avatar
    Join Date
    Apr 2007
    Location
    Alabaster,Al.
    Age
    43
    Posts
    782
    Liked
    8 times
    Images
    11
    Rep Power
    3403
    I've had 265/75/16's on mine for a while. This size really fills out the wheel well nicely. They don't rub either.
    Pics in my gallery on 02 2wd with stock Enkei wheels.
    Your actions speak so loudly, I can't hear what you're saying.
  6. #5
    Join Date
    Sep 2006
    Location
    Jersey
    Posts
    524
    Liked
    1 times
    Rep Power
    24
    265/75 are probably what you want, they are taller by like an inch over 265/70.
  7. #6
    Rookie lexlawn's Avatar
    Join Date
    Oct 2009
    Location
    Lexington KY
    Age
    35
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    Just put a BFG AT KO on my 2006 DC. It's a 265/75/16. I test fit the 275/70/16 and it rubbed. I have a 2.5" lift in the front and a 1.5" block in the rear. I really am happy with the 265/75/16....it's actually a little taller than the 275/70/16. By the way, the first number (265 means that the width of the tire is 265mm). The second number is the percent of sidewall and the third is the size of the rim. Go with a 265/75/16, you'll be glad you did. No rubbing etc.
  8. #7
    jmo
    jmo is offline
    Join Date
    Sep 2007
    Location
    MA
    Posts
    160
    Liked
    6 times
    Rep Power
    21
    While this size might look better on the truck, keep in mind you will be slightly decreasing the torque and acceleration capabilities of the truck as well as the handling (since your raising the center of gravity and using a tire with a "taller" side wall). I noticed a subtle drop in acceleration off the line with my 285/50/20's as the overall diameter is about 31.2, which is bigger than the stock 30.6 the 265/70/16 measure in at. the 265/75/16 tire will push the OD even bigger ~ 31.6?
    2006 Tundra DC, 20" EVO Velociti Wheels, Limited, TRD
    2001 Tundra AccessCab, Limited, TRD
    1993 Toyota Pick Up, Extended Cab
  9. #8
    Join Date
    Aug 2009
    Location
    Land of Enchantment
    Posts
    423
    Liked
    8 times
    Images
    13
    Rep Power
    30
    Quote Originally Posted by jmo View Post
    Comparing 20" wheels isn't quite the same as comparing a 16" wheel tire size that is only an inch taller. Wheel weight is WAY heavier than a reasonably similar tire size. The tire site I linked above caution's against tire size swaps that put you over 3% of stock. 265/75/R16 does that. Raises good awareness about brake failure (stopping distance); however, it all depends on how you use your truck. If your a pavement guy, stick with the stockers. If you need the 1/2" of extra clearance then go with the taller option. I definitely noticed a more sluggish take-off and comprimised fuel mileage (down about ~1.2mpg). If I didn't four wheel I would most definitely not go with anything other than stock (I miss 19 mpg!!!!)
  10. #9
    Join Date
    Oct 2007
    Location
    Central OH
    Posts
    169
    Liked
    18 times
    Rep Power
    16
    Truspeed could compensate for the difference in size and restore the factory shift points and speedometer reading.
  11. #10
    Senior Contributor tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    6,476
    Liked
    3088 times
    Images
    216
    Rep Power
    261436
    I never recalibrated my speedo, I just do the math. If I am correct I add 10%(for 33s) to what my speedo says and that is the real speed, I have tested this with both my navigation and the "watch your speed" signs we have in California. If you don't have them yet, as you pass they tell you how fast you are going and even flash you as if your picture was taken. Very annoying since so many are fooled and ride the brakes as they pass.
    "Drunk by noon but that's okay, I'll be President some day"
    - Sublime
  12. #11
    jmo
    jmo is offline
    Join Date
    Sep 2007
    Location
    MA
    Posts
    160
    Liked
    6 times
    Rep Power
    21
    Quote Originally Posted by NegroTundra View Post
    Agreed its not an apples to apples comparison - that wasn't in the intent of my post, the point was was trying to make is that as you increase outer diameter of the tire, you decrease your trucks ability to turn it given the minor increase in leverage the tire has, I reference my set up since I have increased the OD and noticed the impact, nothing more.
  13. #12
    Join Date
    Nov 2009
    Location
    Posts
    6,476
    Liked
    3088 times
    Images
    216
    Rep Power
    261436
    The sizes you are talking about shouldn't hurt too bad. You are keeping the same width, just increasing the diameter by one inch. Here is the calculation I use to determine tire size....
    265/75r16 265 is the width in mm, drop it to cm by moving the decimal over so it is 26.5
    26.5cm converts into 10.433inches (we are in America here and don't know what mm's are)
    10.433 multiplied by .75 (which is the ratio number, the 75, 75% of width number)
    7.8248 (I round up to 7.825) is the size from your rim lip to your tread, multiply by two
    7.825x2=15.65 now you take this number and add you rim size, in this case 16"
    15.65+16=31.65"
    This formula can be used with any rim/tire size to get rough overall diameter. It is mostly accurate, but not 100% due to differences in inflation pressure, rim width, and tread.I'll review for the college kids...
    265/75r16....26.5cm-10.433".....10.433"x.75=7.8248, round up to 7.825"x2=15.65....15.65+16=31.65" overall tire diameter
    - Sublime
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
