Question cylinder 4 and 7 misfire
+ Reply to Thread
Results 1 to 9 of 9
Thread: cylinder 4 and 7 misfire
  1. #1
    Join Date
    Dec 2006
    Location
    Austin, Tx.
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Exclamation cylinder 4 and 7 misfire
    Help please! I am showing a cylinder 4 and 7 misfire and need to know exactly where they are located on a 2001 Tundra engine. I am replacing my plugs(going back with denso plugs) and want to also replace the ignition coils for those two cylinders. Any help would be great!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Keeper of the Peace RudyDep's Avatar
    Join Date
    Oct 2007
    Location
    San Antonio, Tx.
    Age
    61
    Posts
    2,230
    Liked
    30 times
    Images
    57
    Rep Power
    2870
    Default Re: cylinder 4 and 7 misfire
    Moved to the Gen-1 forum. Good Luck.
    Black 2014 Platinum 4x4, seems to have ALL the options, Flowmaster Dual Delta 40's, K&N drop in filter, LineX,4" Tuff Country Suspension lift, Nitto Trail Grapplers 35/12.50/18, Moto Metal M0961's in Chrome 18x9. Fully DeBadged , Stebel horn, TRD Swaybar, Craven Speed Stubby Antenna, 10,000 lb winch, 5000K HID's (all), Production date 8/07
    "CBTMA Member"
    Black 2007 D/C Limited 4x4-SOLD
    1997 Chevy Tahoe Sport 4x4 (R.I.P)
    2008 Sequoia Ltd. Slate Metallic (purchased on 3/28/09)
    "Some people spend an entire lifetime wondering if they made a difference. The MARINES don't have that problem."
    President Ronald Reagan 1985
  4. #3
    Supporter vincas2005's Avatar
    Join Date
    Nov 2009
    Location
    CT
    Age
    33
    Posts
    764
    Liked
    16 times
    Images
    22
    Rep Power
    2221
    according to Haynes manual they go like this
    8____7
    6____5
    4____3
    2____1
    front of engine
    Thank you Middletown Toyota in Middletown, CT for painless and quick frame replacement, and awesome customer service.
    New mods: Air Lift air spring kit + onboard compressor.
  5. #4
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,238
    Liked
    3033 times
    Images
    47
    Rep Power
    162515
    Quote Originally Posted by vincas2005 View Post
    8____7
    6____5
    4____3
    2____1
    front of engine
    Correct.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  6. #5
    Join Date
    Dec 2006
    Location
    Austin, Tx.
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the help! I also have the unichip ECU piggyback module installed on my truck, and I have been running regular gas instead of premium. Would that possible be a contributing factor to a misfire?
  7. #6
    Join Date
    Nov 2009
    Location
    CT
    Age
    33
    Posts
    764
    Liked
    16 times
    Images
    22
    Rep Power
    2221
    If its stops misfiring with premium i'd say yes, but really shouldn't if compression (some fancy engine mods) and timing changed. Don't count on me as i'm no superfly, just from my general knowledge. Could be plugs, bad coil (had that), bad gas.... and more things
  8. #7
    Lurking Member Mat M's Avatar
    Join Date
    Jul 2009
    Location
    Near the Rubicon Trail
    Posts
    34
    Liked
    0 times
    Rep Power
    6
    I'd take a look at your coil pack plug boots. I recently had a misfire on #8, and moved the coil pack to cyl #6 to test if the misfire changed. It did. The robber/silicone (whatever) boot on that particular coil was split as if someone chopped it down the center with an axe, apparently grounding out itself on the head.
    $97 later, she was back to her old 240K mile self!
    Mat M, AKA MatMan
    www.M2Differentials.com
    "Putting our parts in your rear end since 2009!"
    MatM@M2Differentials.com
  9. #8
    Join Date
    Dec 2006
    Location
    Austin, Tx.
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for all your help I really appreciate it!
  10. #9
    Join Date
    Dec 2006
    Location
    Middle of the Mitten
    Posts
    55
    Liked
    10 times
    Rep Power
    850
    Just pull the Coils and check the continuity with an Ohm Meter. Very easy to find problem coil. It might just be one bad coil giving you the problem. I found NAPA to have the best price on the coils. Denso $75.00 approx.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
