Leer shell ( third brake light )
+ Reply to Thread
Results 1 to 14 of 14
Thread: Leer shell ( third brake light )
  1. #1
    Junior Member mdhess is on a distinguished road.
    Join Date
    Sep 2005
    Location
    san diego
    Posts
    51
    Liked
    0 times
    Rep Power
    8
    Default Leer shell ( third brake light )
    Not sure if this is the right topic area but..... I have a Leer cap on my 03 Tundra with the third (led)brake light bar not working. Is there any web sites out there that have replacements that don't cost an arm and a leg. Went to the Leer outlet is asking $79.00 seems pricey to me. This is the two sided tape recessed mount light bar. Thanks
  2. #2
    jmo
    jmo is offline
    Junior Member jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold. jmo is a splendid one to behold.
    Join Date
    Sep 2007
    Location
    MA
    Posts
    143
    Liked
    1 times
    Rep Power
    18
    Default Re: Leer shell ( third brake light )
    Did you check the connection to make sure its wired up correctly still? If it was working before it might just be a loose connection.
    2006 Tundra DC, 20" EVO Velociti Wheels, Limited, TRD
    2001 Tundra AccessCab, Limited, TRD
    1993 Toyota Pick Up, Extended Cab
  3. #3
    Life Apprentice Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur's Avatar
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    50
    Posts
    2,391
    Liked
    77 times
    Images
    25
    Rep Power
    145104
    That does seem pricey. Is it the newer one that has LEDs inside or does it have standard bulbs? Seems like if it has bulbs you should be able to replace them. And if it has LEDs those should last indefinitely.
    Maybe a silly question but have you check all wiring connections to make sure something did not get loose or a wire pop out of the solder-less connector? I have seen that more times than I like to admit.
    I would also check with a Leer distributer to see if they have suggestions on bulb or complete unit replacement. EDIT. Just reread your OP you went to a Leer Distributer and they want you to purchase the entire unit?
    Rob K.
    2006 DC, SR5, 4.7L, 5 speed, 4WD, LSD, Silver Sky Metallic, Keyless Entry, Tow Package
    Rackit (powder coated), Leer 100 w/Windoors, Westin wheel to wheel step bars
    Air lift Ride Control w/Quick Shot and Onboard Air, Bilstein 5100s (middle notch), Wheeler's AAL
    Powerslot cryo rotors, Hawk HD pads
    Bedrug, Slide Master bed-slide, Pop & Lock, Scangauge II, Viper 5601, MB Quart Speakers
    Toyo ATs 265/70/17 10 ply / Hancooks studded 265/65/17
    Racor remote transmission filter, All Amsoil synthetic lubricants
    Waiting to be installed:
    Eclipse Amp,
    TC steering rack bushings, TC diff drop, Downey end links, Kartec CV boots
    Wish List:
    Headers, SS exhaust system, Sliders, Spidetrax
    HD front bumber (Reuenal or ARB), Mile Marker Winch
    "If there are no dogs in Heaven, then when I die I want to go where they went." Will Rogers, 1897-1935
    Treat others as you would like to be treated
  4. #4
    Veteran Member hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83 is a name known to all. hofkamp83's Avatar
    Join Date
    Sep 2007
    Location
    Fort Smith, AR
    Age
    30
    Posts
    567
    Liked
    9 times
    Images
    102
    Rep Power
    308
    i would look at v-leds.com and get like there strip led's for starting 5 dollars for the 6 in. i put a couple 6 inch strips in the cab down in the foot wells and like them a lot. they come with double sided tape, for about 70 dollars cheaper i think you can make them work.
    Andrew
    2012 Ford Raptor - 2008 Ford F250 - 1984 Toyota Pickup - 2008 Yamaha Raider .................................................. ................. Sold - 2005 Toyota Tundra AC LimitedNitto Terra Grapplers LT325/60/20 on 20" Rev Commando's, Bilstien 5100's on Top Notch, 3/8" Spacer, 3" Body Lift, Camburg UCA's, 1.5" Rear Blocks, Rough Country Rear Shocks, RevTek Diff Drop, Total Chaos Steering Rack Bushings, Downey HD End Links, CV Boot Mod, Unichip PnP, K&N CAI, Headers, Y-Pipe, Borla Split Side Exit Exhaust, Removed Resonator, Summit Nerf Bars, Bullett Bull Bar, KC Highlights Long Range Slim Lights, 1.25" Spidertraxx Adapters, Blacked Fender Flares, Mouldings and Badges, Herculiner Roll On Bed LinerFull LED Conversion with HIDS, Panasonic CQ-VW100U, Panasonic CA-PANSC1U, Sirius SC-C1, Infinity 6022i, Infinity 6020CU, Q-Logic QL-C1TTX208, Kicker ZX400.1, Rockford Fosgate P2D28 x2, Cobra 9540, Scanguage 2
  5. #5
    Veteran Member 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,455
    Liked
    232 times
    Images
    14
    Rep Power
    13316
    my snugtop has the same issue on the same 03. i took it to a friend twice to hook it up. he said it kept loosing the ground at the brake light where he hooked it up. it is still out. not worth the hassle anymore...
  6. #6
    Join Date
    Sep 2005
    Location
    san diego
    Posts
    51
    Liked
    0 times
    Rep Power
    8
    Thread Starter
    I forgot to say that the braking bar has 24 led lights, the first eight lite, than the next eight are out, but the next eight lite, so I think that the wireing works it's an enclosed system can't change the bulbs.
  7. #7
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    50
    Posts
    2,391
    Liked
    77 times
    Images
    25
    Rep Power
    145104
    That seems really lame that LEDs would fail in just a few years... Is there any way at all to open that thing up? I would be looking into that and as was suggested, changing out the LEDs. If it is just not possible maybe look into making your own...
    Rob K.
    Eclipse Amp,
    Wish List:
  8. #8
    Rookie freewillie is on a distinguished road.
    Join Date
    May 2010
    Location
    wb
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Hello,
    What did you do to correct this issue?
    I have the same problem with my Leer cap on my 03 Access Cab.
    The reason I found out about it, is I failed inspection.
    As was mentioned before, first 8 lights are one, 2nd 8 are out, 3rd 8 are on....
    thanks.
  9. #9
    Junior Member muvico is on a distinguished road.
    Join Date
    Feb 2008
    Location
    miami
    Posts
    202
    Liked
    0 times
    Rep Power
    6
    I saw a guy that bought the cheapest brake light you can find on the autoparts store and mounted it on top of the old one and it worked.
  10. #10
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    50
    Posts
    2,391
    Liked
    77 times
    Images
    25
    Rep Power
    145104
    It seems like there should be a "recall" or some type of fix from Leer on those LED lights. They are supposed to last, isn't that the point!
    Rob K.
    Eclipse Amp,
    Wish List:
  11. #11
    Supporter pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712's Avatar
    Join Date
    May 2009
    Location
    New York
    Posts
    938
    Liked
    37 times
    Rep Power
    9336
    My dad had this issue with his 07 tundra. The problem was where the cap lights were wired to the brake lights- the copper was completely corroded away. Snip, strip and tape and it was all working again.
    712
  12. #12
    Rookie acdatz is on a distinguished road. acdatz's Avatar
    Join Date
    Sep 2008
    Location
    Canada
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    My Raider cap is the same. When I took it apart the board that holds the LEDs is rusted. Of the 32 LEDs there were 9 laying in the light rusted off. I'm trying to retro fit a strip of LEDs in their place. Raider was no help when I contacted them.
    2005 Tundra DC 4x4 Limited
  13. #13
    Lurking Member CHH777 is on a distinguished road.
    Join Date
    Mar 2006
    Location
    Houston, TX
    Posts
    21
    Liked
    0 times
    Rep Power
    8
    My Leer 100 3rd brake light is completely out. I'll try taking it appart of it's not molded.
  14. #14
    Supercharged Member SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000 wants you off his porch. SE2000's Avatar
    Join Date
    Jan 2007
    Location
    Albany
    Posts
    4,562
    Liked
    172 times
    Rep Power
    231617
    Quote Originally Posted by mdhess View Post
    Not the bulbs. You have a wiring problem in the light. It is not really sealed if moisture caused your failure.
    I'd advertise for the light. someone whose cap got trashed might have one. You could get some side marker lights and remove the original.
    Check with your state, not all states require the light to work, as long as the tails work
  1. 02-20-2013, 07:38 AM
  2. 01-03-2013, 04:59 PM
  3. 01-02-2013, 08:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
