Actuator on front differential
+ Reply to Thread
Results 1 to 6 of 6
Thread: Actuator on front differential
  1. #1
    Rookie byronanancy's Avatar
    Join Date
    Mar 2010
    Location
    new york
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Default Actuator on front differential
    hey everyone,
    i am having some 4wd prblems with my 2002 tundra and the dealer said the actuator on the frnt differemtial is messed up. Anyone knows where i may source a used one?
    Could there be another fix for this problem, the 4hi and 4lo lights blink.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    SAS'ed #5 dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    36
    Posts
    6,519
    Liked
    377 times
    Images
    119
    Rep Power
    26436
    Default Re: Actuator on front differential
    Moving to the 1Gen Forum
  4. #3
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    36
    Posts
    6,519
    Liked
    377 times
    Images
    119
    Rep Power
    26436
    To answer your question, you can find one online either ebay or other toyota sites like TTORA.com. The front diff is the same used on tacomas of the same year.
    The usual seems to be the shifting rod getting stuck within the actuator. Some have tapped the actuator to engage. If you remove it, you may have to add some grease to the shifting rod. Since the shifting rod is not fully engaging, the 4HI will blink. 4Lo will blink because 4Hi is not engaged. You have to engage 4Hi before you can engage 4Lo.
  5. #4
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    36
    Posts
    6,519
    Liked
    377 times
    Images
    119
    Rep Power
    26436
    Here's one that should work for the tundra:
    03 tacoma front end parts - TTORA Forum
  6. #5
    Join Date
    Mar 2010
    Location
    new york
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    hey Mike
    I was taking a look at the pics of the 03 tacoma front end parts. there is a pic that shows the manual hub diff tube - there are two pieces on the pic and I cant see the entire second piece. Can you post another pic that would show it completely.
  7. #6
    Supporter Scoob's Avatar
    Join Date
    Feb 2010
    Location
    Fort Wayne, Indiana
    Posts
    134
    Liked
    0 times
    Rep Power
    6
    I had mine go bad too. The dealership charged around $600 for the repair. 2002 Tundra TRD 4WD.
    Scoob
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
