O2 Sensor -- OEM or Aftermarket? - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: O2 Sensor -- OEM or Aftermarket?
  1. #16
    Junior Member kaosv1's Avatar
    Join Date
    Feb 2002
    Location
    Griswold, CT
    Age
    56
    Posts
    230
    Liked
    32 times
    Images
    1
    Rep Power
    31
    Default Re: O2 Sensor -- OEM of Aftermarket?
    So, if Denso's are so good why have mine failed twice? I have 44k on my truck! I am on my third set of 02's made by Denso next set I guarantee you won't be Denso's. Why does Toyota have a zillion problems through out the lineup with Denso sensors? I'm not advocating Bosch - either.
    But before anyone jumps on Bosch I replaced my two Celicas with Bosch 02's , not one issue. Two different yr cars too. 94-92. I'd say a good 150 k more mileage on both cars after the sensors swaps.
    I'm not sure we can cast a wide net on any sensors for this truck seeing they all seem to fail in some trucks early.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Happy Tundra Driver H2O_MAN's Avatar
    Join Date
    Jul 2003
    Location
    USA
    Posts
    5,725
    Liked
    127 times
    Rep Power
    17671
    Quote Originally Posted by Tundradrenalin View Post
    The price difference is negligible and there are no performance gains in using aftermarket sensors.
    The choice is obvious in my opinion, and when the time comes I'll be using direct replacement OEM sensors.
    +1
    2002 TUNDRA, REGULAR CAB - LONG BED - 4WD - V8 - SR5
    2010 CAMRY LE, 2.5L 6-SPEED AUTO
  4. #18
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,712
    Liked
    2840 times
    Rep Power
    240771
    Quote Originally Posted by Tundrasooner22 View Post
    I put two Bosch o2 sensors in my 02 Tundra and after a few days the check engine light went off. Everything has been good so far with them (knock on wood)...
    Wow. You will have a CEL within 500 miles. I did the same thing and could not figure out why my CEL kept coming on. Finally someone on this site (the quote directly below) set me right. Have had Denso in the truck for 70,000+ trouble free miles in the 02 department.
    Quote Originally Posted by Remmy700P View Post
    Folks, the operating voltage parameters of the Bosch sensors are not aligned with the Toyota ECU. Even though you might have some time period where the data remains with the voltage specs, you will start to have CELs thrown when the units report back numbers outside ECU-acceptable ranges, and it can happen at any time.
    Do yourself a favor and save yourself time and $$$ by listening to the advice of members when they adamantly notify you that Bosch components are not meant for our vehicles.
    Absolutely correct Remmy. Bosch does not play well with our trucks.
    Yes, after a few days. Did not disconnect the battery because I have read that it is better for the CPU that it resets itself. Said it would take 5 to 7 drives or so and it did reset on its own.
    Disconnecting the battery is what is known as a "hard reset" and it resets the ECU back to factory (or baseline) parameters. The ECU relearns your driving style faster this way. I typically do a hard reset after any major change (new 02's, new intake, new exhaust, new engine modification, etc. . .) as well as when the weather changes from winter to non-winter. When I disconnect the battery I write down my trip odometer as well as my radio presets and leave the battery disconnected for a few hours.
    Why did I put Bosch's on? Because that is what the auto part store carried. I hadn't been a member of this site that long and hadn't seen people having issues with Bosch's before I bought them and put them on.
    So far they have worked. I'm hoping that I don't have any problems with them.
    Hey we all make mistakes or buy the wrong part becuase we cannot find the right one. As I said above you will have problems. Best to take them out now and take them back. Tell Auto store that they sold you incorrect part as Bosch cannot be used in Toyota. If they refuse go to dealer and get a statement from them. Only Denso or NGK will work in your truck.
    Quote Originally Posted by kaosv1 View Post
    Not sure why your 02 sensors have failed prematurely but it would be my guess that there is something else going on there contributing to their failure. It would be pretty slim odds that you managed to get faulty sensors twice in a row. Remmy is the 02 go to guy here on the Forum and he may be able to help you with that. Odds are if he does not know he can at least point you in the right direction.
    That seems to be a pretty broad sweeping condemnation. I realize you are frustrated and maybe that is clouding your reasoning but seriously - I have never heard of a first generation truck owner having problems with Denso sensors, ever. I have had my Densos for 70,000+ trouble free miles.
    I'm not advocating Bosch - either. But before anyone jumps on Bosch I replaced my two Celicas with Bosch 02's , not one issue. Two different yr cars too. 94-92. I'd say a good 150 k more mileage on both cars after the sensors swaps.
    Maybe back in the 90's Bosch was okay in some Toyota vehicles but Bosch sure doesn't work in our trucks now. Again, I think there is some other factor contributing to the early demise of your 02 sensors.
    290,343 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Long Tubes with x-pipe and true duals, used and abused volant intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front and rear differentials, Cooper Discover ATP tires
    http://www.septemberskyband.com/
  5. #19
    Join Date
    Feb 2002
    Location
    Griswold, CT
    Age
    56
    Posts
    230
    Liked
    32 times
    Images
    1
    Rep Power
    31
    Quote Originally Posted by Highwaylizard View Post
    My truck runs GREAT! Never any codes except the 02 codes. 44k miles. My friends 01 has the same issues two sets of 02 sensors same deal but he has more mileage. (68k) I'm NOT advocating Bosch sensors.
    I AM saying Denso OEM sensors aren't all that either. I can only go by my experiences which are many.
    My cousin owns a dealership. I asked the mechanic that pulled the codes he is a ASE master Toyota mechanic he said he has no idea why and he also said this isn't the first truck that has the same issues.
    They also dropped a 7/100k warranty on them for a GOOD reason. They are in the books as a problem, sorry maybe you never had issues , but loads of people are or have .Hence the extended warranty.
    Why extend it if there are no issues. Try all data pull up 02 sensors...and you might find I'm not alone. (facts)
    "There was not a recall or TSB issued on this. Toyota issued a " Warranty Enhancement Notice" applicable to 2000 Through Mid-2002 Model Year Toyota Tundra V8 (2UZ-FE Engine). Owner's were notified by letter.
    "In recent months, Toyota has received reports of custome concerns regarding the two oxygen sensors located in the exhuast manifolds that monitor exhaust emissions. These oxygen sensors are installed ahead of the catalytic converter and are also known as the Number 1 Oxygen Sensors. To minimize these concers, Toyota will extend the warranty of these oxygen sensors for illumination of Malfunction Indicator Lamp (check engine light) related to any of the following diagnostic codes (as diagnosed by your local Toyota Dealer): PO135 and P0155.
    If your check engine light illuminates, please bring your vehicle into your local Toyota dealer for diagnosis and repair. Please note that a check engine light can illuminate for unrelated to the Number 1 Oxygen Sensors.
    This warranty extension is offered for a total period of 7 years or 90,000 miles from the vehicle's in-service date, whichever occurs first, for the failure of eiher of the Number 1 Oxygen Sensors. The specific components covered by this warranty extension are:
    - Number 1 Oxygen Sensor, Bank 1 (left side exhaust manifold)
    - Number 1 Oxygen Sensor, Bank 2 (right side exhaust manifold)
    This offer is limited to your specfic Tundra whose VIN is provided and is subject to the same conditions set forth in the New Vehicle Limited Warranty section of your Owner's Warranty Information booklet*, with the exception of the extended warranty coverage on the oxygen sensors listed above. Please note that this coverage is for warranty work performed at an authorized Toyota dealer only"
    They don't just slap warranty extensions on perfectly good emissions parts.
  6. #20
    Junior Member aggreX's Avatar
    Join Date
    Feb 2010
    Location
    PA
    Posts
    54
    Liked
    0 times
    Rep Power
    6
    FYI: Oxygen sensor sockets are available for under $5 at Harbor Freight if needed for your repair. They sell two types of oxygen sensor sockets (cut-away slot and offset) and are of decent quality which is a bit unusual from HF and about a third less than anywhere else.
    Click image for larger version.
    05 SR5 AC: Toyota Liner,Westin Black Platinum SS step bar,Go Rhino grill guard,Stant Lock,WheelSkins,Drawtite hitch,Ultra Rogue,McGard
  7. #21
    Join Date
    Oct 2010
    Location
    anaconda
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    I need to replace my O2 sensors! Am I hearing guys right? Denso is the way to go!
  8. #22
    Supporter Tundraman10's Avatar
    Join Date
    Sep 2007
    Location
    East Liverpool, Ohio
    Age
    28
    Posts
    1,077
    Liked
    0 times
    Images
    5
    Rep Power
    15
    My Denso's died on me at 97K. Installed a set of BOSH ones wasn't thinking at the time. Got only 50K on them. CEL is on right now and its 162K. Also I'm thinking the catalytic converters aftermarket are bad on my truck too.
    Go DENSO O2 sensors.
    2000 Toyota Tundra SR5 Access Cab 4x4 Black
    Cardomain Member
    Sold the Tundra for $5,000 without the wheels 12/10/2011
  9. #23
    Join Date
    Feb 2005
    Location
    Baytown
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    All, I successfully replaced both front sensor on my 01 tundra v8... Got Denso sensors from AMAZON... BEST DEAL YOU EVER FIND.... Dealer wanted $350 for BANK 2 SENSOR 1..... I told he service manager, thanks but no thanks!
    SAVE YOUR MONEY, DO-IT-YOURSELF
  10. #24
    Join Date
    Dec 2004
    Location
    MASS
    Posts
    159
    Liked
    26 times
    Rep Power
    2570
    I have been reading about Bosch vs Denso for months. I bought a set of Bosch a year ago when my check engine light came on.
    It was not the sensor. It was the transmission which I got fixed. It is too late to send the Bosch back. I called the tech people at Bosch with information about this site and they said that they have not had any problems with there sensors. They also said that the specific sensor for the my 05 Tundra are set to OEM specs. Bosch should be reading this site so they can fix their product.
    I plan to use them when I need too since I am stuck with them. If they don't work, I will go with Denso.
    I have read that the universal Bosch and early 2000s are a problem. Has anybody specified what year and whether it is universal or oem spec Bosch sensors that failed and what years worked and didn't work. Do they all stink! I guess I will find out. I have 93,000 miles on my 05 and just did my t-belt and water pump.
  11. #25
    Supporter Boxer's Avatar
    Join Date
    Jul 2002
    Location
    Canada
    Posts
    200
    Liked
    3 times
    Rep Power
    191
    Bosch didn't work with my 03', had to remove it an go with a denso, no problems since.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
