Coolant Flush
+ Reply to Thread
Results 1 to 13 of 13
Thread: Coolant Flush
  1. #1
    jjc
    jjc is offline
    Supporter jjc's Avatar
    Join Date
    Nov 2002
    Location
    Hendersonville, TN
    Age
    45
    Posts
    1,362
    Liked
    11 times
    Images
    269
    Rep Power
    3116
    Default Coolant Flush
    Isn't always what it's cracked up to be. I was considering having a local "reputable" Toyota dealership do a "flush" on my '01 Tundra just to make sure everything was clean after replacing my timing belt and water pump. So I call them today and asked them what water they use to mix with the red coolant in their pump equipment..........and the tech's answer was "just tap water" .......
    So needless to say, I'll just go grab a few more jugs of distilled water and do the same d*mn flush I did the first time by draining the radiator and block.
    The "other reputable shop" I called said "sure we do flushes"......so I asked them if they use a pump package to perform this.....his answer was "not really, we drain the radiator and refill it"........I'm saying WTF?!!! at this point.
    How's that old saying go.....if you want something done right.......?
    '03 Tacoma / '12 FJ
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,534
    Liked
    2605 times
    Rep Power
    235827
    Default Re: Coolant Flush
    Did you specify a backflush of the block and radiator or just a "flush?" Simetimes you have to get very specific with these guys.
    Even so, the tap water answer would turn me away too.
    280,318 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Fitch Fuel Catalyst, Long Tubes and true duals with twin Aero Turbines, Stock intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the frontand rear differentials, Cooper Discoveer ATP tires
  4. #3
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,331
    Liked
    3126 times
    Images
    47
    Rep Power
    162921
    Just goes to show you how the quality of even the most basic vehicle service has gone downhill, even at the "respectable" dealer service centers. People are getting screwed royally every day at dealers...
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  5. #4
    Forum Admin Tundradrenalin's Avatar
    Join Date
    Apr 2007
    Location
    Virginia Beach, VA, USA
    Age
    36
    Posts
    8,114
    Liked
    415 times
    Images
    240
    Rep Power
    5011308
    That's strange that they wouldn't use the Toyota pink SLL coolant being that it's pre-mixed and is oddly more expensive than the Toyota red LL coolant. After my efan install, I kept the coolant I drained and used that to refill the reservoir. I put new SLL in the rad.
    New to the forum? CLICK HERE!
    Questions about advertising? CLICK HERE!
    Know the facts about Warranties and the Magnuson-Moss Act.
    Link to Amsoil -->
  6. #5
    Veteran Member Hugemoose's Avatar
    Join Date
    Dec 2005
    Location
    Mohnton, PA
    Age
    27
    Posts
    1,863
    Liked
    3 times
    Rep Power
    3434
    Yeah that is why I do my own too. It is simple enough and I can control what gets put into the system. And at 99cents for a gallon of DI water.....it's not a hard choice!
    David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Custom tuned Unichip (thank you Johan)~Powertrax No-slip~Bilstein 5100 front and rear w/ Deaver 10 pack~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
  7. #6
    jjc
    jjc is offline
    Join Date
    Nov 2002
    Location
    Hendersonville, TN
    Age
    45
    Posts
    1,362
    Liked
    11 times
    Images
    269
    Rep Power
    3116
    Thread Starter
    Quote Originally Posted by Tundradrenalin View Post
    I asked them about using the pink and two of the techs were adamantly against it, saying it had Water Wetter in it and that it's notorious for leaking out of any tiny spot it can find .
    I'm kind of surprised that Toyota would mix in Water Wetter, I used to run it in my dirt bikes and there was always a lot of controversy about corrosion and what not. It did make them run a little cooler though.......and it was pink......
    Amazon.com: Red Line Water Wetter - 12 Ounce, Pack of 12: Automotive
    '03 Tacoma / '12 FJ
  8. #7
    jjc
    jjc is offline
    Join Date
    Nov 2002
    Location
    Hendersonville, TN
    Age
    45
    Posts
    1,362
    Liked
    11 times
    Images
    269
    Rep Power
    3116
    Thread Starter
    Quote Originally Posted by Highwaylizard View Post
    I just told them I was looking for a powered flush and they said that they have a machine with a pump that circulates fluid through the entire system to remove any scaling, corrosion, etc........
    '03 Tacoma / '12 FJ
  9. #8
    jjc
    jjc is offline
    Join Date
    Nov 2002
    Location
    Hendersonville, TN
    Age
    45
    Posts
    1,362
    Liked
    11 times
    Images
    269
    Rep Power
    3116
    Thread Starter
    I went ahead and mixed up some new distilled water and red coolant yesterday (50/50), drained the radiator and block completely, and refilled.
    '03 Tacoma / '12 FJ
  10. #9
    Join Date
    Sep 2006
    Location
    Jersey
    Posts
    524
    Liked
    1 times
    Rep Power
    24
    Been flushing my coolant for years with and using tap water, no issues so far.
  11. #10
    Join Date
    Apr 2007
    Location
    Swansboro, NC
    Age
    61
    Posts
    560
    Liked
    3 times
    Rep Power
    27
    Draining both sides of the block is definately a good idea. I didn't measure, but there's a lot of old coolant in there.
    Any fool can fix it right with lots of money.
    The cool thing to do is fix it right with the least amount of money.
  12. #11
    SAS'ed #5 dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    36
    Posts
    6,497
    Liked
    350 times
    Images
    119
    Rep Power
    26436
    Where's the drain for the engine block?
    When I flushed my system, I had gallons and gallons of distilled water. Drained the rad and filled with DW. Did this until the water was clear then, drained and fill with 50/50 mixture. That reminds me, I need to flush my system out as well before the summer time heat arrives....
    BTW, I did bottle the fluid I drained and took it to the local hazardous waste site for proper disposal.
  13. #12
    Join Date
    Apr 2007
    Location
    Age
    36
    Posts
    8,114
    Liked
    415 times
    Images
    240
    Rep Power
    5011308
    Yea there is. It's about 13.5 qts.
    Link to Amsoil -->
  14. #13
    Join Date
    Jun 2004
    Location
    Middle GA
    Age
    36
    Posts
    374
    Liked
    0 times
    Images
    10
    Rep Power
    18
    Quote Originally Posted by dyogim View Post
    I did something similar on the RAV4... just filled with DW, ran it, then drained and filled with SLL Pink. The DW came out really clean, so I didn't feel the need to flush any more. The factory fill on the RAV4 was SLL and it was 6 years into its expected 10 year initial life. I figure 5 year intervals with the SLL Pink shouldn't be a problem and doesn't really cost all that much over the time period.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
