P0500 code and no speedo/odometer/rpm
NEWS
+ Reply to Thread
Results 1 to 9 of 9
Thread: P0500 code and no speedo/odometer/rpm
  1. #1
    Rookie kellypa is on a distinguished road.
    Join Date
    May 2010
    Location
    Cincinnati
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default P0500 code and no speedo/odometer/rpm
    I have a 2000 Tundra 4.7L 2wd. Got a P0500 code (variable speed sensor malfunction) after my speedometer, odometer and rpm gauges stopped working. I replaced the speed sensor on the end of the transmission and erased the code with my code reader before starting the engine but that didn't fix it. Any ideas what could be the cause? Could there be more than one issue?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    Default Re: P0500 code and no speedo/odometer/rpm
    Q: Were you getting any erratic transmission operation prior to replacing the VSS unit?
    Q: What symptoms are present other than the CEL code and the instrument cluster not reporting?
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's 1" Rear Block | Hellwig EZ-550 Helper Springs
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    NGK Platinum Plugs #BKR6EGP | Russell Speed Bleeders #639560 |Kobalt LP Bed Box
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
    "There are TWO keys to success: 1. Never tell anyone everything you know."
  4. #3
    Join Date
    May 2010
    Location
    Cincinnati
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    There were no erratic transmission operation. Shifts were fine.
    The only other possible issue is the chime not working for "open door" and "lights on" when key is in the ignition. Everything else works as it should.
  5. #4
    Life Apprentice Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur's Avatar
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    49
    Posts
    2,353
    Liked
    55 times
    Images
    25
    Rep Power
    125660
    I have this same code up right now. I have ABS brakes and was having a problem with them malfunctioning when applied at slow speeds. I disconnected the wiring on the rear differential (because I wanted to stop when I was driving) and my brakes work but the ABS light is on and shortly after doing this I had this code come up. Disconnecting that one plug caused the ABS system, the speedometer and the odometer to stop operating.
    I have read where some have cleaned the sensors and the problem was solved. I just had a right rear wheel bearing fail and get replaced. After searching and reading on TS I think some particles are causing this issue. I was planning to take the truck back to the dealer to have them fix it it but if it is simple I may just attempt the removal and cleaning myself. Just have never done this before and I don't even know what is involved.
    Rob K.
    2006 DC, SR5, 4.7L, 5 speed, 4WD, LSD, Silver Sky Metallic, Keyless Entry, Tow Package
    Rackit (powder coated), Leer 100 w/Windoors, Westin wheel to wheel step bars
    Air lift Ride Control w/Quick Shot and Onboard Air, Bilstein 5100s (middle notch), Wheeler's AAL
    Powerslot cryo rotors, Hawk HD pads
    Bedrug, Slide Master bed-slide, Pop & Lock, Scangauge II, Viper 5601, MB Quart Speakers
    Toyo ATs 265/70/17 10 ply / Hancooks studded 265/65/17
    Racor remote transmission filter, All Amsoil synthetic lubricants
    Waiting to be installed:
    Eclipse Amp,
    TC steering rack bushings, TC diff drop, Downey end links, Kartec CV boots
    Wish List:
    Headers, SS exhaust system, Sliders, Spidetrax
    HD front bumber (Reuenal or ARB), Mile Marker Winch
    "If there are no dogs in Heaven, then when I die I want to go where they went." Will Rogers, 1897-1935
    Treat others as you would like to be treated
  6. #5
    Supporter Ironman72 has disabled reputation
    Join Date
    Apr 2010
    Location
    Maryland
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Hello,
    I have the same problem, however, my tach is working. The truck is in the shop for the second day for the third time. The shop replaced the curcuit on the back of the speedo cluster but still not working. On occasion, the speedo will work for a few minutes then stop. I really believe there is a short in the harness, but the shop states the wires are testing positive. I also replaced both of the sensors that plug into the tranny. I have a 2004 and it has two sensors on the drivers side - one around the middle and the other towards the back.
    I will let you know what the problem was when I hear back from the shop.
    MJ
  7. #6
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    49
    Posts
    2,353
    Liked
    55 times
    Images
    25
    Rep Power
    125660
    Quote Originally Posted by Ironman72 View Post
    Hello,
    MJ
    My tack was working but my ABS was stuttering and that is why I disconnected the plug on the rear diff. I decided to investigate myself rather than waste an entire day of travel. I removed the sensor that is installed directly behind the wheel bearing on the top of the differential. It is a magnet. It was filthy and a large hunk of metal was stuck on it. I cleaned it and reinstalled. Problem solved. Took me all of 15 minutes to do what the dealership should have done when the truck was in for the wheel bearing.
    On the 04 are there sensors at the wheels?
    Rob K.
    Eclipse Amp,
    Wish List:
  8. #7
    Join Date
    Apr 2010
    Location
    Maryland
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    I did not have any problems with my brakes, it was strictly the speedo and odo working sporatically or not at all. I did a ton of research on both TS and the rest of the web and all the data pointed to the speed sensors on the side of the tranny for speedo issues.
    On Friday, the dealer ordered a new ECU from Cali. I live in MD, so it will be Tuesday or Wednesday before I know more.
  9. #8
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    49
    Posts
    2,353
    Liked
    55 times
    Images
    25
    Rep Power
    125660
    Good luck with it!
    Rob K.
    Eclipse Amp,
    Wish List:
  10. #9
    Supercharged Member Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5's Avatar
    Join Date
    Jun 2009
    Location
    Montana
    Posts
    3,009
    Liked
    334 times
    Images
    12
    Rep Power
    263738
    I did not have any problems with my brakes, it was strictly the speedo and odo working sporatically or not at all..
    I don't know if you have any mods, but my Truspeed quit working and produced identical symptoms.
    05 DC SR5
    4.5" Tuff Country lift
    Bilstein coilovers
    Toytec AAL
    other stuff
    Quote Originally Posted by italianprimate View Post
    it feels like it cums from under my but and behind me slightly and best way to describe it is if someone where to bump me from behind
    Quote Originally Posted by DevinSixtySeven View Post
    two of u guys totally make me want to type leik this of or plain engrish.
    -Sean
Posting Permissions
  • You may not post replies
  • You may not edit your posts
