Question Universal Joint......
+ Reply to Thread
Results 1 to 11 of 11
Thread: Universal Joint......
  1. #1
    Join Date
    Aug 2008
    Location
    Sugarland
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default Universal Joint......
    I was wondering if I could scatch yours brains for a minute. I have a 2004 DBL Cab LTD tundra with 102K on it. I love the truck and it still looks new. I have had the upper and lower radiator hoses replaced, new OEM water pump, New timing belt, all new shocks and struts and was looking forward to a mainteance free 50K at least......Then I had to replace a front bearing and lately I have been hearing hearing a sqeak towards the rear of my truck when just rolling down the road. I took it to my mechanic to see what was going on thinking it was another bearing going out. I was told my universal joint was at the stages of going out. He had said its a 4 pcs uni that these toyotas have been known for acting up. Has anyone heard of these issues with the Uni's? How much should it run money wise? With my truck paid off and still looking new I would hate to get into another payment, but I don't want this thing nickle and diming me either. Any info would be appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Brando's Avatar
    Join Date
    Jul 2009
    Location
    Anadarko
    Posts
    52
    Liked
    11 times
    Images
    8
    Rep Power
    2761
    Default Re: Universal Joint......
    I have an 05 DC 2wd. I noticed a squeak at idle speed, then it developed a vibration, then "thump" from R to D with the brake on, it took the "thump" for me to finally realize it was only a universal joint. There are many other threads on here that made me think it was something bigger and more expensive. I went to Auto Zone and bought a new u joint for $14.00. It was the rear one, 2 of the caps across from each other had lost all of the needle bearings. With a vice, torch, and a buddy I got it changed. No more problems so far!
    These u joints are sealed, you don't have to grease them, they will never go bad! Thanks Toyota!
    "Lead, follow, or get out of the way" -Thomas Pain
  4. #3
    Join Date
    Jan 2007
    Location
    Prov, RI
    Posts
    213
    Liked
    5 times
    Rep Power
    861
    My '04 4wd has a bunch of zerks. I break out the grease gun often enough to hopefully prevent joint issues. But, its mechanical and won't last forever.
  5. #4
    M&M
    M&M is offline
    Join Date
    Mar 2009
    Location
    Kentucky
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    Every u-joint on my 2000 4wd has a grease fitting on it. I take a grease gun to the truck with every oil change.
    Showing my age here, but back in "my day", most all u-joints and steering componets had grease fittings. It was the norm to do a lube job with every oil change.
    Mack
  6. #5
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,677
    Liked
    2787 times
    Rep Power
    238684
    Quote Originally Posted by Brando View Post
    Are you referring to the Toyota universal joint or the aftermarket one you bought from Autozone? My 2004 has zerks on every single universal joint.
    Quote Originally Posted by deadrx7conv View Post
    Agreed
    Quote Originally Posted by M&M View Post
    Mack
    Me too.
    290,343 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Long Tubes with x-pipe and true duals, used and abused volant intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front and rear differentials, Cooper Discover ATP tires
    Highwaylizard needs a new front bumper
  7. #6
    Mech. Engr. / Mechanic single's Avatar
    Join Date
    Dec 2006
    Location
    Tulsa, OK
    Age
    58
    Posts
    824
    Liked
    9 times
    Images
    21
    Rep Power
    1222
    On my 06DC I lost my rear U-joint. It was $64 from toyota or $14 from Oreilly or Napa. The main difference is the one from Napa or Oreilly's will have a grease zerk. (which I prefer) Now everytime I change the oil I grease my one ujoint that requires it.
    White 06 SR5 DC - Blinglights bedlights
    Pop A Lock tailgate lock - TRD aftermarket LSD
    Custom Back Up Lights - Factory Fogs added
    Hellwig 7700 Swaybar - Bilstein HD shocks
    Firestone Sport Rite Air Springs w/onboard air
  8. #7
    Junior Member MrBeanley's Avatar
    Join Date
    Mar 2004
    Location
    Glenville, NY
    Age
    45
    Posts
    361
    Liked
    15 times
    Images
    5
    Rep Power
    150
    Ok, not to hi-jack or anything, but my '04 has grease fittings on all the u-joints and the slip joints on the front and rear shafts.
    Did 'Yota stop putting grease fittings on the u-joints in 2005 or something? (If so, maybe it was the fail-safe for when the throttles would stick wide open or someting! )
    MrBeanley
    Glenville, New York
    2004 Tundra Double Cab 4x4
  9. #8
    Join Date
    Mar 2010
    Location
    Columbus, IN
    Posts
    133
    Liked
    25 times
    Rep Power
    3456
    I think the 4WD has zerks (8 of them) and the 2WD does not. Maybe some of the 2WD owners can chime in and confirm.
  10. #9
    Join Date
    Dec 2006
    Location
    Tulsa, OK
    Age
    58
    Posts
    824
    Liked
    9 times
    Images
    21
    Rep Power
    1222
    Quote Originally Posted by RunawayTundra View Post
    Correct!
  11. #10
    Junior Member hobo13's Avatar
    Join Date
    Oct 2009
    Location
    SW FL
    Posts
    124
    Liked
    0 times
    Images
    2
    Rep Power
    17
    My 2wd 04 does NOT have any zerks.
    When they start acting up I'll replace the joints with ones that do have them.
  12. #11
    Supercharged Member 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    2,173
    Liked
    954 times
    Images
    14
    Rep Power
    41895
    i was getting a thunk that i THOUGHT was the leaf springs or axle wrap when starting from a stop for a year now. last weekend i greased all my fittings and the slip yoke (who comes up with these names?) fitting took 15-20 pumps before it moved. i'd been putting grease in every 2-3 months and thought i'd been filling it. apparently not. now the thunk is gone.
    BTW, i don't mean the thunk when you stop and it feels like someone tapped the rear bumper. it was pulling away from the stop...... pump the grease!
    All you Baja lovers check out: http://www.MasOlas.com
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
