DIY True CAI, K&N wannabe!!!!
NEWS
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Thread: True CAI, K&N wannabe!!!!
  1. #1
    Supporter 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD is more than famous, they're infamous. 02TundraLTDTRD's Avatar
    Join Date
    Feb 2009
    Location
    Broomfield CO
    Posts
    533
    Liked
    0 times
    Blog Entries
    1
    Images
    10
    Rep Power
    2854
    Default True CAI, K&N wannabe!!!!
    OK so i am soooo fed up with all this BS around the so called "CAI" and the waisting of money and all the garbage going along with it that I attempted my own CAI with parts and glue I already had in the garage. So here is what you will need...
    1) Liquid nails tube and caulk gun.
    2) 2ft of 2" flexible hose. Rigid shop vac hose works great. look for free one on Craigslist.
    3) Locking Oil Funnel by Flotool - Part 10709 - Advance Auto Parts____
    4) 2" hole saw.
    Standing in front of your truck looking at the engine, after removing the complete air box, cut a 2" hole in the bottom right corner of the air box. Make sure you cut the hole before the filter.
    Insert the 2ft shopvac flex hose into the hole you just cut and seal inside and outside with the Liquid nails and leave to dry. This will ensure an air tight fit and also prevent it from pulling out.
    After glue dried re-install air box.Do not remove the factory hose that goes into the wheel well and close off any other holes you might have drilled (do not close the one with the flex hose) on previous occasions. So this will leave you with 2 holes in your factory air box, one going to the wheel well and the other you just glued a 2" flex hose to.
    Now after re-installing it you will notice a hole in the body next to the headlight and I think it is either a transmission cooler hose or an air con hose that passes through the hole. Insert your 2" flex hose through this hole along with the metal one already there. You might have to bend and pry the flex hose to a snug fit.
    Now the next step didn't really make a huge difference so it will be optional. it might also make the removal of the air box a little problem. You can insert and glue the little blue funnel (in the link up top) to the outside end of thi flex hose to act as a scoop for accumulating more air and forcing it in to the engine. If the pressure in the air box gets more than what the engine can consume it will just force out the wheel well end.
    I have been driving my truck like this for about a week now. I immediately noticed a more "alertness" in the truck and when driving in 90 degree plus weather i do not feel the huge loss of power so bad. it feels like I am driving the truck in a cool summer morning air. this has been so uch more worth the effort and a bigger satisfaction that the $300 for a K&N filter. My butt dyno told me we gained some power, not sure how much but its a little... (-:
    Two more things that dramatically improved the drivability of the truck was the drive train lube and TB cleaning.
    I will post some pick after i sprayed everything black and it looks a little better.
    This mod gets a huge thumbs up from me and for less that $10 what do you have to loose?
    Happy air box modding.
    2002 TOYOTA TUNDRA LTD – 265/75/17 Yokohama Geolander with 17” FJ Cruiser wheels – TRD Dual Cat back – JBA Shorty headers – K&N Dropin Filter – Dastek Unichip Q Series with Flux PDA and custom Dyno Tuned Map - Garmin Nuvi 1690 – Line X Bed Liner – TruXedo Lo Pro QT Soft Roll-Up Tonneau Cover - Luverne 3" mandrell bent Side Steps – Toyota OEM Brake Upgrade (TSB) - PowerSlot Cryo Rotors - Hawk LTS Pads -Smittybuilt Grill Saver - Hella 500 Spot Lights & Clear covers - Tint front side windows - Toyota "Tundra" door sill protectors - Hellwig Rear sway bar - Bilstein 2.5" lift front and Bilstein 1.25" lift Rear
    Audio upgrades - Alpine CDA-117 HU, Alpine PDX F4 (100w RMS x 4), Alpine PDX M6 (600w RMS x 1), Alpine RUX- KNOB, Boston S60's front, Boston SC65's Rear, Boston G310-44 Sub woofer, eKo Knu Power and Ground, 6 Channel Monster RCA's all round. (119.4 db)
    Future Modifications - Dynamat.
    SOLD
    Click here for something fun to watch! http://www.youtube.com/watch?v=PqXvQ8X4UJI
    2002 Ford Explorer XLT – BabyMobile (Wife’s car) (“,)
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk is almost part of the TundraSolutions family. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    1,073
    Liked
    127 times
    Images
    19
    Rep Power
    7252
    Default Re: True CAI, K&N wannabe!!!!
    sounds cool. waiting for pics.
    2005 Tundra Double Cab Limited 4wd - Phantom Gray Pearl
    Wanted: Heated seat switches (L & R)
  4. #3
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    This has been done (with a detailed writeup) already.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's 1" Rear Block | Hellwig EZ-550 Helper Springs
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    NGK Platinum Plugs #BKR6EGP | Russell Speed Bleeders #639560 |Kobalt LP Bed Box
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
    "There are TWO keys to success: 1. Never tell anyone everything you know."
  5. #4
    Moderator Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    5,456
    Liked
    660 times
    Blog Entries
    78
    Images
    65
    Rep Power
    136813
    1.5 MPG gain on the highway at 75 MPH. I originally ran it jamming the box up with around 11 times more air than the engine can consume. Currently I have routed out some of the areas between the ribs on the side of the box opposite the entrance from the fender well which allows the debris the scoop manages to dump in the box to be jettisoned as well as allows the air charge to be constantly replenished. I found that if the unused incoming air is allowed to hang out in the air box it starts to heat up. Also makes very a really nice sound around 2800 RPM.
    Attached Thumbnails Attached Thumbnails True CAI, K&N wannabe!!!!-designer-with-latest.jpg   True CAI, K&N wannabe!!!!-direct-connect.jpg   True CAI, K&N wannabe!!!!-passenger-side-new-ram-air-scoop.jpg   True CAI, K&N wannabe!!!!-ram-air-ii-inside.jpg   True CAI, K&N wannabe!!!!-ram-air-ii-front.jpg
    Tundra Fuel Economy Blog
    227,537 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires
  6. #5
    Join Date
    Feb 2009
    Location
    Broomfield CO
    Posts
    533
    Liked
    0 times
    Blog Entries
    1
    Images
    10
    Rep Power
    2854
    Thread Starter
    Mmmm...
    SOLD
  7. #6
    Join Date
    Feb 2009
    Location
    Broomfield CO
    Posts
    533
    Liked
    0 times
    Blog Entries
    1
    Images
    10
    Rep Power
    2854
    Thread Starter
    Quote Originally Posted by Highwaylizard View Post
    Ha thank you for the momory jogg.. Now I remember seeing this some time ago. Why did it take me so long to do this??? i guess tghe only difference between this two applications is possisioning. I mounted mine a little higher. You mentioned you rounder out some ribs what exactly did you do? Apart from the filter being pretty quiet (I removed the resonator from my exhaust) the exhaust is still throaty and this mod just removed the loud noise you get from the K&N.
    SOLD
  8. #7
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    5,456
    Liked
    660 times
    Blog Entries
    78
    Images
    65
    Rep Power
    136813
    Quote Originally Posted by 02TundraLTDTRD View Post
    There are actually a couple of differences.
    • I am utilizing the original stock hole in the fender to feed the air box from the directly from the ram air intake ram.
    • You are still drawing from the fender in the stock configuration and added a hole to supplement the stock air box intake.
    • I routed out between the ribs to let excess air out.
    • The intake scoop positions are, as you pointed out, different.
    I will try and get some pictures tomorrow when I go to mow my Godmother's lawn for her. I no longer have a camera so it may take me a minute but I should be able to post some pictures tomorrow night.
    Also running the True Flow intake and foam filter which I love. I would not mind having my ram air intake a little higher up in the grill rather than under the bumper but it does work well where it is currently at and gathers a ton of air.
    Replaced my stock resonator with a glass pack and running an Aeroturbine exhaust. Will be going to true duals with twin Aeroturbines with a modified H-pipe of my own design later in the summer. Need to pay bills and get back on my feet first.
  9. #8
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    5,456
    Liked
    660 times
    Blog Entries
    78
    Images
    65
    Rep Power
    136813
    Here's some pics for you.
    Attached Thumbnails Attached Thumbnails True CAI, K&N wannabe!!!!-100_0304.jpg   True CAI, K&N wannabe!!!!-100_0305.jpg
  10. #9
    Join Date
    Feb 2009
    Location
    Broomfield CO
    Posts
    533
    Liked
    0 times
    Blog Entries
    1
    Images
    10
    Rep Power
    2854
    Thread Starter
    Great!!!! Thank you for the pics.... One question though... Doesnt that allow hot air in at low speeds?
    SOLD
  11. #10
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    5,456
    Liked
    660 times
    Blog Entries
    78
    Images
    65
    Rep Power
    136813
    I would think that it does but at low engine speed (like sitting at a light) hot air means less fuel is injected. At nearly any speed the scoop gathers more air than the engine can ingest.
  12. #11
    Forum Admin Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin wants you off his porch. Tundradrenalin's Avatar
    Join Date
    Apr 2007
    Location
    Virginia Beach, VA, USA
    Posts
    7,634
    Liked
    116 times
    Blog Entries
    6
    Images
    218
    Rep Power
    5000012
    Quote Originally Posted by SuckersWalk View Post
    Here are some pics of my project a few years ago: Project Pics - Photo Gallery
    New to the forum? CLICK HERE!
    Questions about advertising? CLICK HERE!
    Know the facts about Warranties and the Magnuson-Moss Act.
    Link to Amsoil -->
  13. #12
    Rookie babalu87 is on a distinguished road.
    Join Date
    Apr 2009
    Location
    Middleboro, MA
    Posts
    8
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by Tundradrenalin View Post
    Well done!
    Where did you put the intake end?
  14. #13
    Veteran Member cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate has a criminal record for giving away rep points. cheapskate's Avatar
    Join Date
    Feb 2009
    Location
    Kitchener Ontario
    Posts
    740
    Liked
    37 times
    Images
    9
    Rep Power
    8095
    [QUOTE=02TundraLTDTRD;1515598]OK so i am soooo fed up with all this BS around the so called "CAI" and the waisting of money and all the garbage going along with it
    Just wondering what your definition is of waste of money? If it is something that someone buys for their vehicle that provides no real improvement? If that is the case, wouldnt half of your mods be considered a waste of money too? Like step bars or spot lights?I am not here to start a fight, I just see the same repeat threads on here regularly, and I have not even been a member here that long.
    Here's how it goes- New guy joins the site, all excited because he's like a kid on Christmas day. He doesnt spend any time reading first, he just wants to jump in there and ask some questions. I should know, I was guilty of it too. Then you get a couple of veteran members chime in and they tell these guys how stupid they are for not reading first and then telling them how stupid a CAI is. Your never going to get people to stop asking the same questions because it's never the same guys who ask the questions. Just some new guys pulling the trigger a little too quick. Maybe give them a break. I see the same threads too but I just dont see the point in chiming in and bashing.
    That being said, I have an AFE CAI. And oh my god yes, it is even open style. I know, I am a total idiot. But I dont really care. I like how it looks, I like how it sounds and I knew what I was getting into when I bought it. Is my truck any faster? Not that I can tell. But I dont fell like it lost anything either. So, at the end of the day, good for you for doing a mod for for little or no money, and sharing that info with fellow members.
    But as far as bashing what people do with or to, their vehicles, is it really necessary to slam them?
    Again, not trying to pick a fight so please dont get pissed at me. I just dont understand why some guys get so mad at how people blow their money. Hey let's be honest here. Pretty much anything we put on these trucks that is not simpy a replacement of a warn out OEM part could be considered a waste of money and not truly necessary. I will continue doing it whenever I see something I want for my truck. Happy modding.
    05 4x4 DC, AFE CAI, Magnaflow Catback15820, Line X bedliner. Really nice air freshener-not the pine tree one.
  15. #14
    Join Date
    Apr 2007
    Location
    Posts
    7,634
    Liked
    116 times
    Blog Entries
    6
    Images
    218
    Rep Power
    5000012
    Quote Originally Posted by babalu87 View Post
    Well done!
    Behind the black honeycomb in the right-side lower valence of the '05 resin bumper.
    Link to Amsoil -->
  16. #15
    Join Date
    Apr 2009
    Location
    Middleboro, MA
    Posts
    8
    Liked
    0 times
    Rep Power
    0
    Thanks
    Is this more of a mod for the earlier Tundras or will an 06 benefit from it as well?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
