Broken Door Handle How to Remove/Replace
+ Reply to Thread
Results 1 to 6 of 6
Thread: Broken Door Handle How to Remove/Replace
  1. #1
    Supporter rdparker's Avatar
    Join Date
    Mar 2002
    Location
    Western Oregon
    Posts
    13
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Default Broken Door Handle How to Remove/Replace
    I have a broken drivers side door handle on my 2002 Tundra. This is the handle you use to pull the door closed, not the one to open the door. The side to the from of the truck pulled out. Is replacing it a DIY project? Is there a way to fix it. I've removed the two torx screws but I can't seem to get the handle out to look at it. Any ideas?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member jjjackies's Avatar
    Join Date
    Aug 2009
    Location
    southern, California
    Posts
    713
    Liked
    19 times
    Thanks
    0
    Images
    110
    Rep Power
    2475
    Default Re: Broken Door Handle How to Remove/Replace
    rdparker here is a pdf of intsructions for removing door panel think this is what you need
    Attached Files Attached Files
  4. #3
    Join Date
    Mar 2002
    Location
    Western Oregon
    Posts
    13
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Thread Starter
    Nope, that's not it. I just want to remove the handle that you use to pull the door shut and can be used as an arm rest. I don't want to remove the whole door panel if I can avoid it. These instructions don't show the handle I want to remove. Thanks anyway.
  5. #4
    Join Date
    Mar 2002
    Location
    Western Oregon
    Posts
    13
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Thread Starter
    After looking at the instructions for removing the door panel, I believe that what I need to remove is called the door assist grip. All it says in the instructions is to remove the two screws and remove the door assist grip. But it's not that easy. I can't get mine out. I don't want to break anything so I need to know if it should just pop out or if I need to do something else to get it out.
  6. #5
    Join Date
    Aug 2009
    Location
    Posts
    713
    Liked
    19 times
    Thanks
    0
    Images
    110
    Rep Power
    2475
    i could'nt help you out, im sure someone will chime in. just keep checking thread
  7. #6
    Supercharged Member cheapskate's Avatar
    Join Date
    Feb 2009
    Location
    Kitchener Ontario
    Posts
    2,122
    Liked
    451 times
    Thanks
    0
    Images
    15
    Rep Power
    32825
    Cant say for sure on Tundra but I know Corolla door skin is 1 piece from supplier. The assist grip is part of it. If I am understanding you correctly, you have only tried to remove the assist grip and not the skin. Take the whole door skin off and look at it from the back side. It may be bolted to the skin from the inside but I doubt you can remove the handle without taking the skin off first.
    2012 Crewmax TRD 5.7, 4x4, 15% tint all around plus sunstrip. Ionic Gladiator running boards. Weathertechs front and rear. Line X, AVS vent visors. Viper 5301 2 way remote start, MBRP S5316304 cat back exhaust. Bakflip Fibermax tonneau cover.
    Traded in my 05 4x4 DC, AFE CAI, Magnaflow Catback15820, Line X bedliner.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
