Question 100k Maintenance
+ Reply to Thread
Results 1 to 7 of 7
Thread: 100k Maintenance
  1. #1
    Join Date
    Aug 2010
    Location
    Southaven, MS
    Posts
    1
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Default 100k Maintenance
    I purchased a 06 DBL Cab SRT with 98,000 miles. The body is perfect and interior is excellent and engine is very clean. I only have the maintenance records for the things that the dealership did to prepare this truck for sale and the items listed on the Carfax. So far, it runs like new with no problems at all.
    My question is what maintenance items need to be taken care of at 100k miles. I have already changed the oil, air filter and replaced the tires. I am talking about other items. I would like to make sure this baby lasts me a real long time.
    Thanks in advance for any help.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member <TUNDRA>'s Avatar
    Join Date
    Jun 2009
    Location
    WI
    Posts
    331
    Liked
    40 times
    Thanks
    0
    Images
    17
    Rep Power
    5025
    Default Re: 100k Maintenance
    2004 Toyota Tundra AC SR5 4X4
  4. #3
    Supporter Tundraman10's Avatar
    Join Date
    Sep 2007
    Location
    East Liverpool, Ohio
    Age
    28
    Posts
    1,077
    Liked
    0 times
    Thanks
    0
    Images
    5
    Rep Power
    15
    Timing belt, Water pump, Those should be changed at 100K. $600-$800
    I would also clean the throttle body and mass air flow sensor.- you can do this maintenance on your own.
    Chris
    2000 Toyota Tundra SR5 Access Cab 4x4 Black
    Cardomain Member
    Sold the Tundra for $5,000 without the wheels 12/10/2011
  5. #4
    Join Date
    Sep 2007
    Location
    MA
    Posts
    808
    Liked
    110 times
    Thanks
    0
    Rep Power
    16225
    My Toyota Dealership put a sticker on the timing belt cover that has both the date and the mileage for when they changed the timing belt. I think that for all the maintenance, this is probably the most important.
    Like when I bought a used Corvette last year, I went ahead and changed every possible maintenance item on the car. I have not had a single issue in 1 1/2 years-26,000 miles so far.
    My 2004 Tundra has 102,300 miles and feels just like the day I bought it as I do keep up with ALL the maintenance.
    Good luck and welcome.
  6. #5
    Supercharged Member HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,510
    Liked
    7 times
    Thanks
    0
    Images
    12
    Rep Power
    577
    Colant & ATF would probably be nice to replace since anyone thinking that they can go 100K+ has to be out of their minds! Driveline fluids would be nice if you think that they were not serviced prior to you getting the truck!
  7. #6
    Join Date
    Sep 2007
    Location
    MA
    Posts
    808
    Liked
    110 times
    Thanks
    0
    Rep Power
    16225
    Ha, HOGWILD, I'm one of those who DID go 100,000 miles before doing my transmission fluid and I towed a boat from FL to MA/1,600 miles after I already had 53,000 miles on the truck and all the towing I had done thereafter, all with no issues. No question though, that it does need to be done.
    I had my coolant replaced when I had the timing belt down with 84,000 miles on the truck.
    To be safe, I'd either take the time, or have someone replace every fluid possible on the truck before starting the long-term relationship. I even fully bled my brake system last spring. Can't be too safe, especially with a truck going on 7 years/100,000+ miles.
    I am DEFINITELY out of my mind, I know.
  8. #7
    Supporter kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    44
    Posts
    2,697
    Liked
    807 times
    Thanks
    0
    Images
    27
    Rep Power
    231947
    As has been mentioned, the timing belt will need to be done if it hasn't already
    been done. I'd go ahead and change all fluids such as differential, ATF, transfer
    case if you have it, etc. Hold off on the coolant if you need to get the timing
    belt done, they'll do it then. Check to see when the plugs were done or what
    condition they're in.
    John
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
