code P2440
+ Reply to Thread
Results 1 to 6 of 6
Thread: code P2440
  1. #1
    veteran member Big_Al1's Avatar
    Join Date
    May 2005
    Location
    Lake Charles,LA
    Age
    35
    Posts
    1,756
    Liked
    11 times
    Images
    16
    Rep Power
    1100
    Default code P2440
    Need some tips on have to fix this problem on my 2005 tundra 67k miles it sounds like crap and I got this stupid engine light on. Feels like it doesn't have its usual ump either.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Banned Cater's Avatar
    Join Date
    Jun 2009
    Location
    Arkansas
    Posts
    444
    Liked
    0 times
    Images
    2
    Rep Power
    0
    Default Re: code P2440
    Uh- Oh you too? Didnt know this was a problem on the gen 1's. Look at the Topics "AIP"
  4. #3
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,386
    Liked
    3173 times
    Images
    47
    Rep Power
    162921
    Read this thread: Check engine light 4 air injection Make sure that all vacuum lines are installed and tight.
    Generally, it looks like it is either:
    1. bad switching valve
    2. not enough backpressure (do you have aftermarket headers, intake, and/or exhaust?)
    I think that the switching valve is susceptible to moisture and gets stuck in either an open or closed position. This hypothesis is backed up by anecdotal evidence that the CEL most often pops right after startup in cold, damp conditions.
    Big_Al, I know you have stock headers on there, but one of the members with JBAs with the same code had JBA look into it and JBA redesigned the air rail with a larger diameter and that seemed to fix the problem. Here's a comparative pic of his two JBAs (the top coated one is the redesign; notice the diameter differences in the rail):
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  5. #4
    Join Date
    Jun 2009
    Location
    Arkansas
    Posts
    444
    Liked
    0 times
    Images
    2
    Rep Power
    0
    Remmy700P: Is this the same as the AIP on gen 2?
  6. #5
    Join Date
    May 2005
    Location
    Lake Charles,LA
    Age
    35
    Posts
    1,756
    Liked
    11 times
    Images
    16
    Rep Power
    1100
    Thread Starter
    Thanks I don't it will be the backpressure thing since I have not modded anything on my truck for 40k miles or so. But it did just start this morning.
  7. #6
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,386
    Liked
    3173 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by Big_Al1 View Post
    Then it's probably the switch.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
