How to replace O2 sensor 2001 toyota tundra
+ Reply to Thread
Results 1 to 9 of 9
Thread: How to replace O2 sensor 2001 toyota tundra
  1. #1
    Join Date
    Aug 2010
    Location
    San Jose, CA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default How to replace O2 sensor 2001 toyota tundra
    Simply, how do I replace a bank 1 shotgun side O2 sensor?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,275
    Liked
    3071 times
    Images
    47
    Rep Power
    162515
    Default Re: How to replace O2 sensor 2001 toyota tundra
    Bank 1 is the driver's side. Link to the DIY in my sig below. And searching the site is appreciated.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Junior Member kaosv1's Avatar
    Join Date
    Feb 2002
    Location
    Griswold, CT
    Age
    56
    Posts
    229
    Liked
    32 times
    Images
    1
    Rep Power
    31
    Good stuff , I'm on my second set of 02 sensors at 44k miles the first set went at 22k the second set went at 44 k. So mine last 22k per set which sucks.
    Warranty they extended to 2009 - on a 2002. 7yrs and 100k. Ofcourse I missed it by 1 yr. So this one is do it yourself. these sensors from the dealer come in pairs - that should tell you something- mine were about 180.00 for two. Factory sensors for this kid.
    Nice write up-
  5. #4
    Join Date
    Apr 2006
    Location
    Quad Cities
    Posts
    28
    Liked
    0 times
    Rep Power
    17
    211000 on my Tundra and just now putting the 2nd o2 sensor in. Bank 1 Sensor 2 is gonna get replaced this weekend - hope that the o2 sensor is the only think I have to worry about this year as I put on more and more miles...........
  6. #5
    jjc
    jjc is offline
    Supporter jjc's Avatar
    Join Date
    Nov 2002
    Location
    Hendersonville, TN
    Age
    45
    Posts
    1,362
    Liked
    11 times
    Images
    269
    Rep Power
    3116
    Just remember...........Aerokroil penetrating oil is your friend .
    Amazon.com: Kano - Aerokroil Penetrating Oil, 10 oz. aerosol (AEROKROIL): Automotive
    '03 Tacoma / '12 FJ
  7. #6
    Join Date
    Apr 2006
    Location
    Quad Cities
    Posts
    28
    Liked
    0 times
    Rep Power
    17
    ok - I think I totally screwed up and ordered the wrong thing....
    ya see - I think there is a difference between the rear and front o2 sensors.
    1: the o2 sensor has a different input to the computer - as seen in the pix below - the picture shows the old one and where the connector goes........in the next post I will show the new connector and you can see that it does not "fit"
  8. #7
    Join Date
    Apr 2006
    Location
    Quad Cities
    Posts
    28
    Liked
    0 times
    Rep Power
    17
  9. #8
    Join Date
    Apr 2006
    Location
    Quad Cities
    Posts
    28
    Liked
    0 times
    Rep Power
    17
  10. #9
    Join Date
    Apr 2006
    Location
    Quad Cities
    Posts
    28
    Liked
    0 times
    Rep Power
    17
    you can also see there is no way to use the normal socket that I purchased to get these off as well.........
    so do I take off the cover with the 2 bolts on the sides of the sensor?
    and then just muscle the o2 sensor outta there?
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
