Locking Lug Nut broke
+ Reply to Thread
Results 1 to 12 of 12
Thread: Locking Lug Nut broke
  1. #1
    Veteran Member Garth's Avatar
    Join Date
    Jan 2000
    Location
    VT
    Posts
    618
    Liked
    3 times
    Images
    4
    Rep Power
    267
    Default Locking Lug Nut broke
    the corners of the locking lug nut broke, when I tried to take it off to swap winter tires. Now, I can't get the lock to hold so it will unscrew. Any ideas on how to get this off?? I tried channel locks, pipe wrench, I can't get hold of it enough to unscrew it.
    5.7L 4x4 DCSB
    Mods completed so far:Techstream No Locks on takeoff/park/in gear -Underseat storage~Husky Weatherbeaters~Truxedo LT Pro QT Tonneau Cover~Westin Step Bars~Scotchguarded carpet/seats~Backup Camera with dimming mirror~Onyx Spray in BedLiner~TRD Sway Bar~Webasto 740 Series Sunroof~
    Mods to come - in progress)~3m Clear Bra~Window Tinting
    Mods Later (Fall maybe)~Clazzio Seat covers~Heated Seats
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2002
    Location
    Seattle, WA
    Posts
    917
    Liked
    2 times
    Rep Power
    58
    Default Re: Locking Lug Nut broke
    A picture would be helpful. You may try large vise grips.
    At least they have circled the problem.
  4. #3
    Veteran Member 07bsmcrewmax's Avatar
    Join Date
    Sep 2007
    Location
    youve never heard of it...
    Posts
    665
    Liked
    0 times
    Images
    3
    Rep Power
    751
    Pictures would be helpful but you may try welding a regular nut to your locking lug nut and then break it loose. Of course you want to make sure you protect the wheel and get a good weld, and obviously the lug nut will be a total loss but you dont want this problem again anyways.
  5. #4
    Supercharged Member cheapskate's Avatar
    Join Date
    Feb 2009
    Location
    Kitchener Ontario
    Posts
    2,182
    Liked
    471 times
    Images
    15
    Rep Power
    33305
    We could not find the "key" for the wifes sienna when we put the winters on last year. Fortunately I was at a tire shop and they had one off each tire in no time. I say stop by your local tire shop and do the same. At least call them. They will probably give you advise for free. Then get rid of the other ones at the same time. Personally I think those stupid locking nuts are the dumbest things ever invented.
    2012 Crewmax TRD 5.7, 4x4, 15% tint all around plus sunstrip. Ionic Gladiator running boards. Weathertechs front and rear. Line X, AVS vent visors. Viper 5301 2 way remote start, MBRP S5316304 cat back exhaust. Bakflip Fibermax tonneau cover.
    Traded in my 05 4x4 DC, AFE CAI, Magnaflow Catback15820, Line X bedliner.
  6. #5
    Join Date
    Jan 2000
    Location
    VT
    Posts
    618
    Liked
    3 times
    Images
    4
    Rep Power
    267
    Thread Starter
    5.7L 4x4 DCSB
  7. #6
    Join Date
    Jan 2000
    Location
    VT
    Posts
    618
    Liked
    3 times
    Images
    4
    Rep Power
    267
    Thread Starter
    I think I'll call a local garage this week. I'm not the first to do this, (people I'm sure have lost the Lock key too) I know there's a tool that does this.
    Thanks,
    Garth
    5.7L 4x4 DCSB
  8. #7
    Join Date
    Mar 2007
    Location
    lonoke, ar
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    What I've done and always worked is get a chrome 12 point 19mm socket and force it on with a hammer. It will slide on and fit tight. Next hit it with an impact and it will come right off. chuck socket up in a vise a punch the lock out.
  9. #8
    Junior Member shen's Avatar
    Join Date
    Feb 2002
    Location
    Coppell, TX
    Posts
    80
    Liked
    1 times
    Rep Power
    74
    Quote Originally Posted by neq0323 View Post
    Yep, just get a socket that's just slightly larger than the locking lug nut and hammer it in on to hold the lug nut as best you can. Then use either an impact wrench (preferred), or just the lug nut wrench to break it loose. You may need to try several times to get it off. Last time this happened, I was able to get 3 out of the 4 off on my wife's Lexus. But the 4th one was just too stubborn, and by then, my socket also was cracked on the edge. I finally took the 4th one to the local Discount Tires, and they charged $10 per lug nut which I thought was reasonable. Give it a try first before taking it to Discount Tires or some other tire/wheel specialist.
    2003 Tundra SR5 Access Cab 4x2 4.7
    FM 40s w/o resonator
    5100 set @ 2.5"
    Hawk LTS brake pads
    Power Stop Cross Drilled and Slotted rotors
    Gone through 3 sets of wheels already from 18x10s to current 20x8.5....still experimenting
  10. #9
    Junior Member jflops25's Avatar
    Join Date
    Feb 2008
    Location
    portland, tx
    Posts
    155
    Liked
    0 times
    Rep Power
    8
    this same thing happened to me at discount when there were putting on my new tire for me and their smart way to get it off was to beat the hub and tire with a sledge hammer, when that did not work they tried to drill it off. i walked to the next door auto parts store and bought a lug not removal tool and got it off in like two mins. they had to pay for new alignment and hubs. just fly go to your auto part store and get that tool.
  11. #10
    Junior Member aggreX's Avatar
    Join Date
    Feb 2010
    Location
    PA
    Posts
    54
    Liked
    0 times
    Rep Power
    6
    What brand were the locks? I keep the locks away from ANY IMPACT WRENCH USER and remove them first and install them last.
    05 SR5 AC: Toyota Liner,Westin Black Platinum SS step bar,Go Rhino grill guard,Stant Lock,WheelSkins,Drawtite hitch,Ultra Rogue,McGard
  12. #11
    Supporter Chudlles's Avatar
    Join Date
    Nov 2009
    Location
    Prince George B.C.
    Posts
    517
    Liked
    114 times
    Images
    20
    Rep Power
    7440
    Working at a tire shop, there are sockets u can buy that have reverse grabbing teeth on it. Im sure you could buy at a parts store, or just goto your local tire shop, if you haven't already. Just dont put em back on.
  13. #12
    Join Date
    Feb 2008
    Location
    portland, tx
    Posts
    155
    Liked
    0 times
    Rep Power
    8
    that is what i got the reverse grabbing teeth socket
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
