Cost to Weld muffler?
+ Reply to Thread
Results 1 to 7 of 7
Thread: Cost to Weld muffler?
  1. #1
    Junior Member MiniKlues's Avatar
    Join Date
    Nov 2010
    Location
    West Gilgo Beach, NY
    Posts
    141
    Liked
    13 times
    Thanks
    0
    Rep Power
    105
    Default Cost to Weld muffler?
    Hey guys, I should be expecting my magnaflow any day now. Its the 18" offset/center for the 1st gen tundra. I tryed calling local muffler shops and couldnt get any estimates. Any ideas of how much it will cost me to get it welded in with a new 12" tip that i ordered too?
    please reply..thanks
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member RCsTundra's Avatar
    Join Date
    May 2008
    Location
    ★ᚱᚱ★
    Posts
    1,843
    Liked
    72 times
    Thanks
    0
    Images
    8
    Rep Power
    5741
    Default Re: Cost to Weld muffler?
    $25-$100 just depends on the shop.
    -2001 Tundra Limited AC : SOLD
    -2006 Tundra SR5 DC : SOLD
    <--- click to view
    CURRENT RIDE: 2005 LEXUS GX470 <--- click to view
  4. #3
    Junior Member rhinosarge50's Avatar
    Join Date
    Sep 2008
    Location
    Los Angeles CA
    Posts
    467
    Liked
    18 times
    Thanks
    0
    Images
    8
    Rep Power
    488
    my shop.. $40 juss to put in a muffler .. if ur still using all the stock piping
    anything else.. its gonna cost you..
  5. #4
    Lurking Member Greken1's Avatar
    Join Date
    Dec 2009
    Location
    Maine
    Posts
    23
    Liked
    0 times
    Thanks
    0
    Images
    3
    Rep Power
    6
    It really depends. Mine was $50 or $60 to install but I didn't bother shopping around because I couldn't wait.
    2000 Toyota Tundra Limited V8, Two tone Imperial Jade/Thunder Grey - Aero Turbine 2525 muffler, no resonator, dumped after muffler - Stock rims painted black - Debadged
  6. #5
    Join Date
    Nov 2010
    Location
    Posts
    141
    Liked
    13 times
    Thanks
    0
    Rep Power
    105
    Thread Starter
    Quote Originally Posted by rhinosarge50 View Post
    yeah im using stock piping, although i just dont like how the tail pipe angles out. I would rather it angle more towards the back tire. but whatever ill get over it. Thanks!
    2006 AC 4x4: tints, magnaflow dual exhaust, spidertrax 1.25" wheel adapters, por15, stock 16s plastidipped
  7. #6
    Senior Contributor tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    6,319
    Liked
    2719 times
    Thanks
    0
    Images
    216
    Rep Power
    255659
    Bout $40-60 sounds fair, mine was an 18 pack and some pizza. Be sure to check out what they are welding with and if possible get a look at something. My buddy who did my muffler welds every bit as clean as the welds from the muffler manufacturer.... I got bored one day while he was out of town and HAD TO have my resonator taken off to cure an itch. I went to an old muffler shop by my house thinking since they have been there for ever, they must be good. WRONG. I can weld better than the old timer that did it and I've only welded a handful of times. Made me want to buy a welder and go into business. At least it was dirt cheap, and I planned on cutting that section out soon anyhow so it isn't a big deal. Point is, there is always a line drawn that separates cheap(crappy) and reasonable(fair work for price).
    If you are cutting out the stock, and reusing the tailpipe, it's pretty minimal time, labor and material. Shouldn't be too high. If you really want the tail pipe to dump out straight back instead of turning, it should be super easy for any muffler shop to use the stock section of tail pipe, cut before that turn(right where the arch comes down after the axle) and stick a 45 or so on to send the tailpipe straight back. That also shouldn't cost too much for parts or labor, it's a cut and a weld or two.
    I wasn't a big fan of the way the tail pipe looked either, but I couldn't deal with a dumped exhaust. What I settled on was cutting my pipe just half way through the last turn, making kind of a flare that still spits exhaust out from under but isn't visible unless I ran you over.
    Last edited by tundrunk; 12-06-2010 at 06:55 PM. Reason: just because I can edit whenever I want. Is that a problem? Too bad, I'll edit again and again. Buwahahaha!
    "Drunk by noon but that's okay, I'll be President some day"
    - Sublime
  8. #7
    Join Date
    Nov 2010
    Location
    Posts
    141
    Liked
    13 times
    Thanks
    0
    Rep Power
    105
    Thread Starter
    alright thanks guys! all the answers i was looking for
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
