+ Reply to Thread
Results 1 to 5 of 5
Thread: Tire 265 70/16 vs. 245 75/16
  1. #1
    Join Date
    Sep 2010
    Location
    Durango
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Default Tire 265 70/16 vs. 245 75/16
    My tundra currently has Michelin 265 70 16's. I am considering replacing those with 245 75 16's. I live in snow country and the narrower tire might be better in the snow. I will be putting a pop up camper in the truck bed. The narrower tire has a heavier load rating. Is there a downside to a narrower tire on the Tundra? thanks - this Forum has been very helpful.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    606
    Liked
    50 times
    Images
    7
    Rep Power
    2082
    Default Re: Tire 265 70/16 vs. 245 75/16
    I think the only things you have to worry about are rims (what size does your new tire fit) and diameter of the tires (more ABS related but can affect speedometer accuracy).
  4. #3
    Supporter ThomasE's Avatar
    Join Date
    Feb 2002
    Location
    San Jose, CA
    Posts
    371
    Liked
    1 times
    Rep Power
    14
    If you have the stock 16x7 rims then 245/75/16 are optimal for the 7" wide wheels. I'll probably go back down a size to 245/75/16 when my current tires wear out for better mileage. Also the diameter is the same as the stock 265/70 so the speedometer is not affected.
    TRUCK: 2001 2WD V8 AC MODS: JBA headers! Magnaflow muffler, TRD 4x4 coils & shocks, Wheeler's AAL's, Truxedo bed cover, Bridgestone Dueler AT LT265/75/16, Surepull hitch, Drawtite convertor box, MAPP nerf bars, Toyota bed mat
  5. #4
    Junior Member HawkFanatic's Avatar
    Join Date
    Sep 2005
    Location
    41051
    Age
    36
    Posts
    191
    Liked
    18 times
    Images
    20
    Rep Power
    2984
    I just did the exact same thing. I took the stock 265/70s off and put 245/75 snow tires on the TRD rims. Same reason as you, better tire section for snowy roads. The truck doesnt really drive any different, and they tires are the same height as stated above.
    TRUCK: 2006 Toyota Tundra Double Cab 4X4 White ext, Dark Grey int.
    OPTIONS: FE, CK, DJ, CC, JC, KE, LD, OF, PG, PN, DK, Z1
    MODS: Tint (20% Front, 50% Rear) Westin In-Channel Vent Visors AVS Rear Window Vent Visors Clarion NX500 w/back up camera Interior 5K LED Conversion - Front 5100s - 18x9 Method Racing MR301 wheels - 285/65/18 Yokohama Geolandar ATS - TorzaTop HardHat Folding Tonno Cover
  6. #5
    Supercharged Member SE2000's Avatar
    Join Date
    Jan 2007
    Location
    Albany
    Posts
    4,604
    Liked
    188 times
    Rep Power
    247449
    The idea of narrower tires for snow seems to lost on a lot of the younger drivers. For them, looks over function is priority. Having a wrecked truck is way uglier than some not so wide tires for a few months of the year. 245 as narrow. It wasn't all that long ago that a 245 would have been a very wide tire, and I remember people getting around ok with 2wd and much narrower tires.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
