2000 Tundra front actuator questions.
+ Reply to Thread
Results 1 to 9 of 9
Thread: 2000 Tundra front actuator questions.
  1. #1
    Join Date
    Dec 2010
    Location
    SW Missouri
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Default 2000 Tundra front actuator questions.
    Hi
    For the last 3 years my 4 wheel drive is hit and miss meaning some times it worked and some times it didn't.
    When it didn't I could usually get it to engage with several pushes of the button.
    Well this year no luck. Push the button and all I get is the flashing 4x4 light on the dash.
    I tinkered with it and have it narrowed down to the front drive axel actuator.
    If I tap on the actuator with a small hammer it will engage correctly.
    So I read a post here and they were talking about greasing the actuator and mentioned di electric grease.
    I started to pull the actuator so I could tear it apart and look things over but as soon as the seal between it and the axel was broke loose it started leaking fluid and since I'm not sure what type and weight it takes I quickly tightened it back up.
    A few questions.
    What type and weight gear lube does the front axel use?
    Can the actuator be serviced with out removing it from the axel?
    I'm assuming that the grease they were talking about goes inside the plastic cup that is held on with 4 Philips screws and is it di electric grease or just regular bearing grease?
    Is there anything else I need to know about the removal/repair of the actuator?
    If I cant get this actuator to work where is a cheap place to buy a new one, are there any aftermarket or does it have to come from Toyota? Anyone know the part #?
    Thanks.
    Water Rat
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Mar 2010
    Location
    Columbus, IN
    Posts
    131
    Liked
    25 times
    Rep Power
    3456
    Default Re: 2000 Tundra front actuator questions.
    I can answer a couple of your questions. Hopefully, others will chime in with the missing answers.
    The front differential uses 75w90 gear oil. Many on this site have used the Mobil 1 synthetic version. Make sure you can remove the fill plug before removing the drain plug. I believe the plugs use an allen wrench (hex key) - can't remember the size.
    I have seen the front differential actuators on ebay for around $70 - not sure of the quality.
  4. #3
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,640
    Liked
    2746 times
    Rep Power
    236614
    Hey Water Rat - sorry I cannot offer any advice on fixing but I will offer some advice on preventative maintenance. You should "exercise" the four wheel drive at least once a month as this keeps everything from freezing up and keeps things lubed. I do mine when sitting in the driveway when I first start the truck and before I back out of the driveway - gives the truck a chance to warm up a little before driving.
    You may want to check in the engine drive train sub-forum to see if there is anything there.
    289,965 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Long Tubes with x-pipe and true duals, Stock intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front and rear differentials, Cooper Discover ATP tires
    Highwaylizard needs a new front bumper
  5. #4
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,640
    Liked
    2746 times
    Rep Power
    236614
    Download this to your computer:
    http://www.ncttora.com/fsm/00-03-Tun...Tundra_FSM.pdf
    Manuals with diagrams
  6. #5
    Join Date
    Dec 2010
    Location
    SW Missouri
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by RunawayTundra View Post
    Got me to thinking while Im under there I should do the rear differential also, does it take the same 75w90?
    Tip on the fill plug a big Thanks!! I can just see that drained and cant refill.
  7. #6
    Supercharged Member 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    2,153
    Liked
    926 times
    Images
    14
    Rep Power
    41486
    it happens. don't ask how i know.....
    All you Baja lovers check out: http://www.MasOlas.com
  8. #7
    Join Date
    Dec 2010
    Location
    SW Missouri
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by 2003bajatundra4x4ac View Post
    ??? What happens???
  9. #8
    Join Date
    Mar 2010
    Location
    Columbus, IN
    Posts
    131
    Liked
    25 times
    Rep Power
    3456
    Quote Originally Posted by Water Rat View Post
    From memory, I think the rear takes 90 weight for the LSD's and 75w140 for the non-LSD's. I would definitely double check with your owner's manual to make sure. If you have a LSD, you may also need to add a friction modifier depending on what type of gear oil that you use. I think the rear and transfer case drain plugs are 24mm.
    I have been running synthetic 75w90 in the front, rear, and transfer case for about the last five years without any issues.
  10. #9
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,640
    Liked
    2746 times
    Rep Power
    236614
    ??? What happens???
    Getting the drain plug out only to find that the fill plug will not come out.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
