2003 OEM skidplate issues
+ Reply to Thread
Results 1 to 9 of 9
Thread: 2003 OEM skidplate issues
  1. #1
    Veteran Member 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,443
    Liked
    229 times
    Images
    14
    Rep Power
    12376
    Default 2003 OEM skidplate issues
    the first time i drained my oil on this truck a couple of years ago it was missing 2 screws. i just dealt with it until i finally got the replacement screws. after changing both my rear O2 sensors yesterday i went to install the new bolts and the holes don't line up!
    WTF???
    i got the front 3 in and one on the rear. the other is off by 3/4 a diameter of the bolt. is there a certain order they need to be installed for them to fit? wiggling, shaking and cussing failed to get it to line up....
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra has blessed us with their presence. JTs02Tundra's Avatar
    Join Date
    Dec 2004
    Location
    Bronx, New York
    Posts
    235
    Liked
    1 times
    Rep Power
    41
    Default Re: 2003 OEM skidplate issues
    I got sick of the skid plate a few years ago and upgraded to a skid row plate. I never had to drop it to do an oil change after that. I also added a Fumoto valve so I don't even have to remove the oil pan bolt anymore either.
    JT
    2002 SR5, Thunder Grey, Access Cab, 4.7, Off Road pkg, 4WD, Toyota Bedliner, Bed Extender, Limited Slip Diff, ABS
    Add Ons: Toyota Tube Steps, Leer 700 Lid, Curt Front Mounted Receiver Hitch, WeatherTech Window Vents, WeatherTech Front Floor Liners, Cabela's Aux Back Up Lights, Hellwig Rear Anti Sway Bar, Skid Row Front Skid Plate, Fumoto Valve, SP Rotors and Hawk Pads, SnowSport SnowPlow
    Have on workbench: Total Chaos Steering Gear Bushing kit, Autoxray 6000
  4. #3
    Junior Member greener will become famous soon enough. greener will become famous soon enough. greener will become famous soon enough. greener will become famous soon enough. greener will become famous soon enough. greener will become famous soon enough. greener's Avatar
    Join Date
    Sep 2004
    Location
    Midwest
    Posts
    278
    Liked
    1 times
    Rep Power
    11
    The front diff isn't dropped by chance??
  5. #4
    Junior Member Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19 has done just about everything...and then some. Lastone19's Avatar
    Join Date
    Oct 2002
    Location
    Rensselaer, NY
    Age
    60
    Posts
    113
    Liked
    4 times
    Rep Power
    911
    I get the two in the back started first, then the three in the front started,then tighten them all down.That way it gives you a little room to jockey the skid plate around. Plus plenty of never seize.
  6. #5
    Join Date
    Sep 2009
    Location
    Posts
    1,443
    Liked
    229 times
    Images
    14
    Rep Power
    12376
    Thread Starter
    no diff drop.
  7. #6
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,225
    Liked
    1139 times
    Images
    216
    Rep Power
    190697
    Is your plate bent by any chance? Dented?
    Skid Row plate. Good investment.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  8. #7
    Join Date
    Sep 2009
    Location
    Posts
    1,443
    Liked
    229 times
    Images
    14
    Rep Power
    12376
    Thread Starter
    there are some rusty scrapes, but nothing major. maybe i'll get the sledge out and beat it back.
  9. #8
    zcd
    zcd is offline
    Junior Member zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd has a criminal record for giving away rep points. zcd's Avatar
    Join Date
    Mar 2008
    Location
    Wylie, TX
    Posts
    323
    Liked
    16 times
    Images
    15
    Rep Power
    8130
    drill new holes. or beat it as you suggested.
  10. #9
    Rookie Ramay is on the right track. Ramay is on the right track.
    Join Date
    Feb 2011
    Location
    Phx
    Posts
    14
    Liked
    2 times
    Rep Power
    0
    Quote Originally Posted by JTs02Tundra View Post
    This is about Skid Row. I have an '06 and the Trans Case plate does not line up with my tranny cross member, and if I make that line up, I have to drill 4 new thru holes on the frame. Has anyone else seen this on thier '06 w/skid row plates?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
