Question 06 Tundra 'Jerks' on acceleration at hwy speed
+ Reply to Thread
Results 1 to 8 of 8
Thread: 06 Tundra 'Jerks' on acceleration at hwy speed
  1. #1
    Rookie CT782 is on a distinguished road.
    Join Date
    Feb 2011
    Location
    NC
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default 06 Tundra 'Jerks' on acceleration at hwy speed
    I have an '06 Dbl-Cab Tundra with approx. 93k miles. Recently it began 'stumbling' on acceleration at highway speeds. I tried to be more attentive, and notice that it only happens at a speed of 50-60mph, approx 2000-2200rpm, when I ease down on the accelerator to slightly increase speed. It makes no difference what terrain (level or hill). I have no active codes, and the light has not come on. It feels like a misfire, but I can't rule-out the transmission shifting somehow and causing it, because I don't 'hear' anything, just feel the 'jerk'. Afterwards, I can accelerate and decelerate just fine with no more hesitation or jerking.
    Oh yea, to make it more perplexing, it doesn't always happen. It may happen several times one day, then not again for a week.
    I don't have any specialty Toyota tools, but I do have digital multi-meters, digital-storage o-scope, code-reader (Autozone model), and schematics from alldata if someone could point me in the right direction toward something to check.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,104
    Liked
    2020 times
    Images
    47
    Rep Power
    121449
    Default Re: 06 Tundra 'Jerks' on acceleration at hwy speed
    It could be an issue with the torque converter and/or shift solenoids. I strongly urge you to do an Auto-Rx treatment, run it for 1,000-1,500 miles, then flush your tranny with Mobil 1 Synthetic ATF. The link to purchase is in my sig line.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  4. #3
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,372
    Liked
    1296 times
    Blog Entries
    78
    Images
    65
    Rep Power
    175260
    X2 what Remmy said. You may also want to clean the MAF and Throttle Body.
    Tundra Fuel Economy: Cleaning the MAF and Throttle Body
    Tundra Fuel Economy: MAF Sensor and Throttle Body Cleaning
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  5. #4
    Supporter 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some. 06grnmstr has done just about everything...and then some.
    Join Date
    Nov 2006
    Location
    Hanahan, SC
    Age
    32
    Posts
    201
    Liked
    11 times
    Rep Power
    789
    I would check your throttle body. Take that sucker off and give it a really good cleaning. That many miles it isn't uncommon, and my Dad's truck (220,000 miles) did the same thing, but probably not as bad. Take that whole thing off, spray the inside out and clean it really well.
  6. #5
    Lurking Member pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of. pengy has much to be proud of.
    Join Date
    Feb 2011
    Location
    Citrus Heights
    Posts
    36
    Liked
    0 times
    Rep Power
    45
    +1 on cleaning throttle body. Also disconnect the battery for about 30 minutes to let the ECU reset, and have it relearn everything.
  7. #6
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,216
    Liked
    1132 times
    Images
    216
    Rep Power
    190649
    "Tundra Jerks" sounds like a new forum.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  8. #7
    Junior Member buglao is on a distinguished road.
    Join Date
    Jul 2006
    Location
    Memphis, TN
    Posts
    200
    Liked
    3 times
    Rep Power
    7
    change pcv valve if you have not change it lately. check & regap spark plug if you don't want to replace them.
  9. #8
    Join Date
    Feb 2011
    Location
    NC
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for all the excellent suggestions! I disconnected battery cable for about an hour while I cleaned the MAF-Sensor and throttle-body. They were both VERY dirty!
    I'm on my second tank of gas since this service, so it's probably still 'learning' everything again, but so-far it has not been jerking anymore. Hopefully I will see a little improvement in fuel economy also. I'm getting right at 15mpg. Just over 16mpg was the best I remember seeing, but that was shortly after I bought it.
    On the spark-plug thing. I bought a set of those Pulstar plugs and tried them last year. Within 1 month one had failed. They were kind enough to replace the entire set, but I never noticed any additional power or better fuel economy. After 3 months I had another one fail, and just put the factory irridium plugs back in. Haven't had an issue since. So if anyone's considering those, I wouldn't waste the $180. At least not for a Tundra.
    Thanks again to everyone for the help.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
