Casting Numbers
+ Reply to Thread
Results 1 to 5 of 5
Thread: Casting Numbers
  1. #1
    Join Date
    Mar 2010
    Location
    Plymouth, MI
    Posts
    68
    Liked
    9 times
    Rep Power
    364
    Default Casting Numbers
    Does anyone know what the casting numbers are on the newer upgraded brake calipers for a 2000 tundra SR5. With these numbers the local auto parts store can order them at a good discount compared to toyota.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,382
    Liked
    3166 times
    Images
    47
    Rep Power
    162921
    Default Re: Casting Numbers
    13WL. The older (smaller) was S13WE.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Join Date
    Mar 2010
    Location
    Plymouth, MI
    Posts
    68
    Liked
    9 times
    Rep Power
    364
    Thread Starter
    Thanks, I will see what I can find for replacements.
  5. #4
    Join Date
    Oct 2002
    Location
    Mukwonago
    Posts
    28
    Liked
    3 times
    Rep Power
    13
    Funny, just did mine yesterday (2000 limited). 13WL is tha casting number. Order all brake parts for a 2005 and you will get the correct calipers.
    Remember when doing the upgrade you'll need to trim off a small section of the rear backing plate to make the 13WL caliper fit. It only like 5/8" that needs to be removed.
    There's a very good "how to" in these forums.
  6. #5
    Join Date
    May 2009
    Location
    Nelsonville, OH
    Posts
    110
    Liked
    23 times
    Rep Power
    23
    Couldn't agree more. Made the process very smooth and easy.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
