Mobil1 75-90W gear oil
+ Reply to Thread
Results 1 to 13 of 13
Thread: Mobil1 75-90W gear oil
  1. #1
    Supercharged Member 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    2,081
    Liked
    820 times
    Images
    14
    Rep Power
    41081
    Default Mobil1 75-90W gear oil
    so i bought 3qts anticipating changing my Front Diff and the Tx case...
    the label says LS (for limited slip). is there anything to be concerned over? i hope the LS, that is an additive, won't be needed - or hurt my components in the Tx and Front Diff.
    All you Baja lovers check out: http://www.MasOlas.com
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supercharged Member italiantundra88's Avatar
    Join Date
    Feb 2011
    Location
    Metairie, LA
    Age
    26
    Posts
    2,604
    Liked
    457 times
    Images
    10
    Rep Power
    16440
    Default Re: Mobil1 75-90W gear oil
    Quote Originally Posted by 2003bajatundra4x4ac View Post
    well not an expert but i would say the fact that they make different oils for lsd vs open means something and probably shouldnt be interchanged
    07 Tundra Limited DC 5.7 TRD Off Road
    All interior leds, led reverse lights, black headlight mod, custom homemade led third brake light, morimoto mini H1 projector retrofit with 5000k hids, 6000k 55w hid fogs, debadged, 2010 sport color matching grill, 2 sundown sd 10s in a fox under seat box, afe stage 2 cold air intake, super 44 flowmasters dumped after rear axel, tundra racing rear flip leveling kit, 22" black rhino traverse, tundra racing helper bag kit (made to fit their level kits)...
    Seafoam how to
    http://www.tundrasolutions.com/forum...eafoam-how-to/
    Quote Originally Posted by oofy15354 View Post
    she got mad when i came home and sat in the truck before going inside to see her... i guess the tundra just requires less money and maintenance.....
    Quote Originally Posted by tundrunk View Post
    The sad part is, when I googled "blowmaster" images a picture of my truck comes up, fail.
  4. #3
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1526 times
    Rep Power
    268069
    You can use LS oil in an open differential, but if you use non LS oil in a limited slip differential, you will experience chatter while going around corners.
    Attention environmentalists, reduce emissions from this:
  5. #4
    Join Date
    Feb 2011
    Location
    Metairie, LA
    Age
    26
    Posts
    2,604
    Liked
    457 times
    Images
    10
    Rep Power
    16440
    Quote Originally Posted by Mr. Creosote View Post
    good to kno
    Seafoam how to
  6. #5
    Join Date
    Sep 2009
    Location
    Posts
    2,081
    Liked
    820 times
    Images
    14
    Rep Power
    41081
    Thread Starter
    so... for the rest of us.
    LS is UNIVERSAL to any application calling for 75-90W.
    limited slip diff, Tx, front diff.....
  7. #6
    The Friendly Dragon by the Sea Puffnstuff's Avatar
    Join Date
    Sep 2006
    Location
    Jacksonville
    Age
    51
    Posts
    2,876
    Liked
    182 times
    Images
    45
    Rep Power
    16219
    Just for future reference the synthetic mobil gear oil needs the additive when using it in the toyota lsd in the rear. If you don't add the friction modifier it will chatter even though the label says its compatible with a limited slip diff.
    RIP 2006 Tundra DC with: Eclipse AVN5500 Navigation System, Kicker IX500.4 driving infinity kappa 60.9cs door speakers, Kenwood KAC-X20 driving an infinity kappa 100.9w sub in sound ordnance bass bunker, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Ballistic Enigma 20x9 wheels & Nitto nt420 285/50R20 tires, Hellwig 7697 & 7700 sway bars, Stinger SPP2150 Battery, Big 3 wire upgrade with 1/0 Raptor, Rancho RS5000 struts/shocks, Dynomax VT 17956 muffler, EBC Slotted Sport Rotors & Yellowstuff Kevlar pads, Russell SS brake lines, Cheetah GPS Mirror
  8. #7
    Join Date
    Sep 2009
    Location
    Posts
    2,081
    Liked
    820 times
    Images
    14
    Rep Power
    41081
    Thread Starter
    thanks guys. i run RP in the lsd and didn't have to add the modifier. no chatter yet. last time i filled with lucas and a tube the chatter returned in 14 months=8k miles.
    i was concerned that the additive might be for the lsd ONLY.
  9. #8
    Join Date
    Jan 2008
    Location
    La Jolla, CA
    Posts
    306
    Liked
    34 times
    Rep Power
    2226
    I'll 2nd adding the friction modifier for LSD diffy's regardless of what the bottle says.
  10. #9
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,354
    Liked
    3135 times
    Images
    47
    Rep Power
    162921
    Just did the rear diff service with Mobil 1 75W90 LS Gear Oil today. Piece of cake.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  11. #10
    Senior Contributor tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    6,355
    Liked
    2793 times
    Images
    216
    Rep Power
    255670
    That oil is safe for use with open differentials all day, as is, right out the bottle. If you have an LSD, you just need to squirt a tube of friction modifier additive which is safe to use in conjunction with the oil. ONLY if you have LSD you need it, with open diffs you are fine.
    excellent oil by the way.
    "Drunk by noon but that's okay, I'll be President some day"
    - Sublime
  12. #11
    Join Date
    Sep 2009
    Location
    Posts
    2,081
    Liked
    820 times
    Images
    14
    Rep Power
    41081
    Thread Starter
    thanks for all the replies. when i said this, "i was concerned that the additive might be for the lsd ONLY." i was refering to the LS (limited slip) on the bottle of gear oil. sounded confusing....
    it's going in the Tx and front diff this week.
  13. #12
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,354
    Liked
    3135 times
    Images
    47
    Rep Power
    162921
    * * * REAR DIFFERENTIAL REFILL -- FYI * * *
    To properly refill your rear differential, the OEM repair manual specs the fill level to be less than 5mm (0.20 in.) from the lip of the fill hole. What isn't said (but is inferred) is that this applies to vehicles on stock suspensions and at stock height. Those with vehicles with a front end lift may achieve a more accurate fill by jacking up the rear of the vehicle somewhat (1.0"-1.5") when refilling the rear differential to account for this difference. (I understand that a proper pinion angle should negate this, but you never know...)
    When I did mine, this height difference allowed an additional 0.5-0.6 quarts to be added (that's 12-15% by volume, not an insignificant amount!)
  14. #13
    Join Date
    Sep 2009
    Location
    Posts
    2,081
    Liked
    820 times
    Images
    14
    Rep Power
    41081
    Thread Starter
    M1 installed yesterday.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
