How to replace the spark plugs
+ Reply to Thread
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Remmy700P
Thread: How to replace the spark plugs
  1. #1
    Join Date
    May 2011
    Location
    Charlotte, NC
    Posts
    4
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Question How to replace the spark plugs
    I have a 2001 Tundra V8 4.7 access cab. It has about 108K on it (I bought it a few days ago) and I do not think that the spark plugs have never been replaced. I understand that the OEM NGK Irridium are the best. The only thing I do not know is how to replace them. Is that difficult? I am a handy man and good with tools. How can I replace them?
    Thank you,
    A.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter bamafire's Avatar
    Join Date
    Apr 2007
    Location
    Alabaster,Al.
    Age
    43
    Posts
    782
    Liked
    7 times
    Thanks
    0
    Images
    11
    Rep Power
    3402
    Default Re: How to replace the spark plugs
    These trucks are very easy to change plugs on. Go slow, pay attention, and do them one-at-a-time. There are four coils on each valve cover (if you have the V8). Remove the fasteners on each coil, pull straight up, removing the coil and "tube". Then get at the plug with a spark plug socket attached to an extension. I like to tape the socket to the extension, due to a previous disaster on another vehicle, that involved removing the intake to retrieve the socket that I managed to hopelessly jam in the hole. My truck performs very well on the cheapo, non-iridium Denso plugs. I also like to add a touch of anti-seize compound to the threads of the new plugs.
    Your actions speak so loudly, I can't hear what you're saying.
  4. #3
    Join Date
    Nov 2007
    Location
    Los Gatos, CA
    Posts
    95
    Liked
    6 times
    Thanks
    0
    Rep Power
    1250
    If you don't have a torque wrench, now is the time to buy one. When you torque a fastener, pull evenly on the wrench until you reach the desired value. Just my 2 cents...
  5. #4
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,330
    Liked
    3124 times
    Thanks
    0
    Images
    47
    Rep Power
    162921
    Do-It-Yourself Re: How to replace the spark plugs
    Here you go....
    Attached Files Attached Files
    Maxattack likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  6. #5
    Leader of Group Evil DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,128
    Liked
    728 times
    Thanks
    0
    Images
    22
    Rep Power
    12366
    2nd everything Bamafire said, in particular the part about the tape . I prefer electrical tape, personally!
    All joking aside, it REALLY sucks to lose the rubber-lined socket down the hole on a new plug, because the only ways to get it out are either remove the plug you just installed, or try tape over the end of the socket extension to get more friction between socket and extension than suction between the plug and the plug liner in the socket. Grumble.
    A u-joint is really handy for the driver's side rear plug, if you have ABS.
    GFX by FreedomEagle50
    1-Gen Tundra Offroad Technical FAQ Index
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
