Question Front Door Speaker Replacement
+ Reply to Thread
Results 1 to 13 of 13
Thread: Front Door Speaker Replacement
  1. #1
    Join Date
    Aug 2010
    Location
    North Augusta, SC
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    Default Front Door Speaker Replacement
    Well, my front door speakers have blown. I've done the research on here and I don't want to mod anything, don't want make anything, don't want to un-hook anything....So...my question is....
    Does anyone know a direct speaker replacement? No mods, just a simple switch. If not, is anyone selling their stock speakers?
    My truck is a 05 DC with the JBL system. The speakers I need are the front door 6.5 ones.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member oofy15354's Avatar
    Join Date
    Sep 2009
    Location
    Massachusetts
    Age
    22
    Posts
    1,378
    Liked
    276 times
    Images
    21
    Rep Power
    13237
    Default Re: Front Door Speaker Replacement
    installing speakers is as easy as cutting two wires and taping two new ones to them, matching colors. most 6.5in speakers should bolt right in, mine did
    if you can take off the door panel to get to the speakers, you can cut in new ones. if youre that opposed, get some from the dealership
    2001 Black AC V8 4x4
    Current Mods: 5100s on 4th Notch, Diff Drop, Poly Rack Bushings, Recon Tailgate LED Bar, Edelbrock Exhaust, Hankook Dynapro ATM 265/70/R16, Blacked Out Emblems, Color Matched Mirror Caps, Bumpers and Front Grill, Skid Row Skid Plate (Thanks to four_by_four), Full Blue LED interior lighting, Herculiner Bed Liner, Kobalt Low Profile Tool Box, Smitty Built Rear Shackle, Walmart Front AUX lights, JVC Headunit, Kicker Front Components, Pioneer Rear Speakers, Magnefine Filter, Viper Remote Start, Single in-Dual out 2.25in Exhaust
    Thanks to Rust: New Frame, New Calipers, New Rear Axle, Sway Bar End Links, Tailgate Straps, Patched Bed Floor
    Quote Originally Posted by italiantundra88 View Post
    dave, every one has a weekness, yours is just any work on your truck
  4. #3
    Join Date
    Nov 2007
    Location
    Los Gatos, CA
    Posts
    95
    Liked
    6 times
    Rep Power
    1250
    Crutchfield sends instructions for pulling the panel when you buy speakers from them. Easy money...
  5. #4
    Veteran Member CoachRon's Avatar
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    24
    Posts
    566
    Liked
    67 times
    Images
    26
    Rep Power
    6591
    I don't know of any direct replacements that use the same wiring harness. I replaced all 4 of mine and it was super easy. You just cut the 2 stock wires, twist the new adapter wires to those and put electrical tape around it (if you're lazy), plug the new speakers in, and bolt them directly to the stock location with no drilling.
    You sound like you don't even want to do this project though, so you could just take the truck to Best Buy and have them install the speakers correctly. My brother did that and I believe they did it for pretty cheap.
    2000 Tundra SR5 2WD... Camburg UCAs, Camburg 2.5" coil-overs, Deaver 10-packs, Bilstein 5100s, Moog LBJs, BFG A/T 285/75/16s, TRD bead-lock wheels, K&N air filter, 18" MagnaFlow muffler, clear corners, Sylvania fog/headlights, full LED conversion, Kenwood head unit & 6-3/4" 3-way speakers, Sound Ordnance B-8PT 8" subwoofer, Coverking neoprene seat covers... so far...
  6. #5
    Join Date
    Aug 2010
    Location
    North Augusta, SC
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by CoachRon View Post
    Thanks for the help. I expected to cut some speaker wire but I was talking about unhooking tweeter's, making MDF back plates, or modding the window track. I just prefer things as stock as possible, thanks for the help. Now just gotta find the speakers. Any idea what the Ohms and all the other specs are so I don't risk blowing anything up?
  7. #6
    Join Date
    Jun 2009
    Location
    Montana
    Posts
    3,055
    Liked
    368 times
    Rep Power
    285197
    Quote Originally Posted by guitarman1996 View Post
    I'm not sure what specs you need, but I put Infinity 6030cs's in my front doors and the stock JBL amp didn't last a week.
  8. #7
    Junior Member El Jeep's Avatar
    Join Date
    Oct 2002
    Location
    AZ and Mexico
    Posts
    50
    Liked
    2 times
    Rep Power
    13
    Look into buying new foam surrounds instead of replacing. The JBL system is not so easy to replace as plug and play. Much cheaper than new speakers too!
    2005 Tundra Double Cab 4x4
    2004 Toyota Land Cruiser
  9. #8
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    24
    Posts
    566
    Liked
    67 times
    Images
    26
    Rep Power
    6591
    I would give Crutchfield a call. Those people know a lot!
  10. #9
    Lurking Member balberti76's Avatar
    Join Date
    Nov 2007
    Location
    winston-salem, nc
    Posts
    38
    Liked
    3 times
    Images
    3
    Rep Power
    8
    I put in some Polk audio's when my JBL ones blew. I used the existing mount and all has been fine. Amp is still pushing them too. I do plan to one day take the mid out and get something more cutom, but for the time being have been great. I'll look later for what Polks I got. I used the Polk's tweeters also. I didn't mess with taking the mid out...it wasn't blown so I just left all wiring in place.
  11. #10
    Junior Member Iron Clad Lou's Avatar
    Join Date
    May 2007
    Location
    Irwin, PA
    Posts
    295
    Liked
    13 times
    Images
    4
    Rep Power
    258
    I sent my speakers to these folks Speaker Repair,Speaker Repairs,JBL Speaker Repair,EV Speaker | The Speaker Exchange® for a rebuild...very pleased with the results.
    2004 DC Limited, Husky Liners, 35% window tint, fog light mod, map light mod, Hoen Fogs, 265/70/17 BFGs, color matched wheels, Bazooka sub, resonator removed, full LED conversion.
  12. #11
    Join Date
    Sep 2011
    Location
    Brookhaven
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by Iron Clad Lou View Post
    If I may ask, how much did they charge?
  13. #12
    Join Date
    Aug 2006
    Location
    Omaha, ar
    Posts
    245
    Liked
    5 times
    Images
    4
    Rep Power
    188
    I have the stock factory speakers that came in my 02 AC all 4 of them are in good shape.
  14. #13
    Join Date
    May 2007
    Location
    Irwin, PA
    Posts
    295
    Liked
    13 times
    Images
    4
    Rep Power
    258
    Quote Originally Posted by biltrite View Post
    the wires needed to be redone and it was around $35 total IIRC
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
