When to Replace Radiator Hoses?
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Like Tree2Likes
Thread: When to Replace Radiator Hoses?
  1. #1
    Join Date
    Nov 2003
    Location
    Los Angeles, CA
    Posts
    77
    Liked
    0 times
    Rep Power
    12
    Default When to Replace Radiator Hoses?
    When do you guys replace your radiator hoses? The hoses on my 05 with about 84,000 miles still look ok, but I'm wondering if I should just go ahead and replace them as preventive maintenance. Thanks in advance for any replies.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3134 times
    Images
    47
    Rep Power
    162921
    Default Re: When to Replace Radiator Hoses?
    I have a 2002, but it only has 57,000 miles on it -- with the original radiator hoses. Even though the current hoses seem fine (pliable, consistent thickness, no cracking/glazing), I thought it was time. My order for new upper and lower radiator hoses, 8 new NGK #BKR6EGP spark plugs, and new oil plug drain gaskets from Rock Auto just got dropped off this morning.
    Will be picking up a gallon of Toyota Red coolant from the dealer and will be doing a drain/fill this weekend. The old hoses will be rinsed and saved in the truck box for emergency use.
    BTW: I ordered the above from Rock Auto yesterday at 1200, and they were dropped off at my doorstep at 0800 this morning. THAT'S fast.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    606
    Liked
    50 times
    Images
    7
    Rep Power
    2082
    I still have my original hoses on my 2000 (12 years old) with 190,472 miles. Every now and then I'll ask a mechanic what he thinks about replacing them, and they all have said there is nothing wrong with mine still. I have wondered when the right time is though.
  5. #4
    Join Date
    Jan 2009
    Location
    E. Oregon
    Posts
    224
    Liked
    53 times
    Images
    1
    Rep Power
    3961
    I think that hoses, like rubber belts, are made of much better material than they were 20 years ago.
    I remember when normal PM called for inspection of radiator hoses for cracks or swelling and replace at ~50,000 miles or less. Blown hoses were not that uncommon and I use to carry a big roll of friction tape in my trunk for that reason.
    2005 DC 4X4 SR5
  6. #5
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3134 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by INDYMAC View Post
    That's amazing. Although, I can't recall hearing of anyone posting up a radiator hose failure either.
    Anyone know who manufactures the OEM hose line? (The Rock Auto hoses are Dayco -- Made in good ole US of A)
  7. #6
    Supercharged Member cheapskate's Avatar
    Join Date
    Feb 2009
    Location
    Kitchener Ontario
    Posts
    2,138
    Liked
    458 times
    Images
    15
    Rep Power
    32825
    Quote Originally Posted by gnlw View Post
    1 billion miles or when they explode. Whichever comes first.
    2012 Crewmax TRD 5.7, 4x4, 15% tint all around plus sunstrip. Ionic Gladiator running boards. Weathertechs front and rear. Line X, AVS vent visors. Viper 5301 2 way remote start, MBRP S5316304 cat back exhaust. Bakflip Fibermax tonneau cover.
    Traded in my 05 4x4 DC, AFE CAI, Magnaflow Catback15820, Line X bedliner.
  8. #7
    Supercharged Member apimpdad's Avatar
    Join Date
    Aug 2006
    Location
    Polk County, Florida
    Age
    26
    Posts
    2,992
    Liked
    164 times
    Images
    62
    Rep Power
    6832
    I replaced mine at about 95k miles. The stock ones looked in decent shape, but with all the mud that I am in constantly it really dries out rubber parts. Cheap insurance to replace them IMO. I saw what the mud did to my serpentine belt so I figured I'd play it safe.
    Remmy700P likes this.
    New Truck Build Thread 2006 Double Cab
    http://www.tundrasolutions.com/forum...dra-build-2-a/
    New Build Thread 2002 Tundra-Tundra Revamp
    http://www.tundrasolutions.com/forum...tundra-revamp/
  9. #8
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,194
    Liked
    402 times
    Images
    25
    Rep Power
    24544
    Leave them alone. Second timing belt change is the soonest you should think about replacing them. The quality of the hose material is much, much better than it was 20 or 30 years ago. Only the old timers remember burst hoses.
  10. #9
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,565
    Liked
    2638 times
    Rep Power
    235827
    Quote Originally Posted by Remmy700P View Post
    My hoses are original and I am thinking about replacing them with the next timing belt change.
    280,318 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Fitch Fuel Catalyst, Long Tubes with x-pipe and true duals, Stock intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the frontand rear differentials, Cooper Discoveer ATP tires
  11. #10
    Join Date
    Dec 2004
    Location
    MASS
    Posts
    159
    Liked
    26 times
    Rep Power
    2570
    I replaced my hoses and antifreeze when I had the timing belt changed at 95K.
  12. #11
    Supporter jbtoy's Avatar
    Join Date
    Apr 2001
    Location
    MA
    Posts
    2,231
    Liked
    367 times
    Images
    68
    Rep Power
    30136
    I replaced radiator and heater hoses at 12K or so. Nothing wrong with the OEM's, I just have a habit of replacing things
    as mods... (mine are color matched for my engine details)
    JB
    2000 Tundra Supercharged 4.7 TRD (Ivan) in Sunfire Red Pearl.
    Long mod list, but, have some pics in my gallery here
  13. #12
    Join Date
    Nov 2003
    Location
    Los Angeles, CA
    Posts
    77
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    Thanks for the responses. I guess I still have a bunch of miles left on the hoses. Has anyone even heard of modern Toyota hoses leaking?
  14. #13
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,565
    Liked
    2638 times
    Rep Power
    235827
    Did an oil change yesterday (BTW Costco has 6 quarts of Mobile 1 synthetic for $28) and when I took off my skid plate I noticed some rust. For awhile now I have been trying to track down the source of a faint smell of radiator fluid. I think my lower radiator hose is leaking. I hope it is the hose and not the bottom of the radiator.
    Click image for larger version.
Name:	Rust on Skid Plate.jpg
  15. #14
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    606
    Liked
    50 times
    Images
    7
    Rep Power
    2082
    My radiator had a crack about three years ago, causing coolant to pool up in the skid plate. My hoses are still good though.
  16. #15
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3134 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by Highwaylizard View Post
    I'd suggest leaving the skidplate off, and the next time you drive it, have a large piece of clean cardboard handy to put under there after you park it. The system should still be under significant pressure due to heat, and the leak location should show pretty quickly.
    Highwaylizard likes this.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
