ABS light came on... - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Like Tree3Likes
Thread: ABS light came on...
  1. #16
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3192 times
    Images
    47
    Rep Power
    162921
    Default Re: ABS light came on...
    Quote Originally Posted by Mongoose View Post
    I have a new sensor ordered. After I install it and disconnect my Negative Battery cable, should the ABS light go away or will I need someone with a computer to reset it? Or should I disconnect the battery, change out the sensor, then reconnect the battery?
    Anything electrical you should at the very least disconnect the negative terminal on the battery. Let it sit for 10-15 minutes to disperse any residual voltage in the ECU and have at it.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Join Date
    Jun 2003
    Location
    AR
    Age
    44
    Posts
    239
    Liked
    23 times
    Rep Power
    3448
    Thread Starter
    OK... I'll disconnect the negative wire before I take off the wheel and change out the sensor. That will give it time for any clodes to clear.
  4. #18
    Join Date
    Jun 2003
    Location
    AR
    Age
    44
    Posts
    239
    Liked
    23 times
    Rep Power
    3448
    Thread Starter
    My sensor finally came arrived this evening. I unhooked my neg battery cable, installed the new speed sensor (took about 15 minutes total). Unfortunately, my ABS light is still on. I drove the truck about 15 minutes hoping the light would clear. I drove down a gravel road and occasionally would brake hard. I had my window down and noticed that my front tires would lock up but rears wouldnt. It's obvious the my ABS isn't working properly. I will try to get it hooked up to a computer again one day. Sucks that I just spent $200 on a sensor that I might not have needed to replace.
  5. #19
    Join Date
    Jun 2003
    Location
    AR
    Age
    44
    Posts
    239
    Liked
    23 times
    Rep Power
    3448
    Thread Starter
    I just jumped pins 4 and 13 on my OBDII, started my truck and the ABS light blinked 3 times, paused and blinked three times. Not sure what code this is telling me though. When I pull my jumper, the light comes back on.
  6. #20
    Join Date
    Jun 2003
    Location
    AR
    Age
    44
    Posts
    239
    Liked
    23 times
    Rep Power
    3448
    Thread Starter
    Well I bought and replaced the speed sensor for nothing. I took my truck to another local shop and had them hook a computer up to it. They couldn't even get their computer to throw a code. I came home and crawled under it and strarted traceing wires and looking closely at everything with a flashlight. I found a broken wire on the connector that is suppose to be bolted to the rear of the gas tank cover. Mine didn't have a nut on the bolt because the guy the replaced my fuel pump years ago failed to SECURELY fasten the connector bracket back once he reinstalled the gas tank. Years of bumpy roads caused the connector to move around, eventually enableing the wire to break.
    I took it and showed the mechanic and we decided to just jump all 4 wires rather than replacing the whole wire assembly or attempting to rig broken wire back to the connector.
    When I restarted the truck the ABS light was still on. I jumped 4 and 13, the light indicated code 33 again. I quickly tapped the brake pedal 8 times and the light started rapidly flashing. I pulled the jumper and it light went off and hasn't came back on.
    So i have a perfectly good right rear speed sensor if anyone needs one.
  7. #21
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,716
    Liked
    2848 times
    Rep Power
    240771
    Wow, sorry for the headache but glad you got it taken care of. I am sure someone can use that sensor. Maybe post it up in the classifieds?
    290,343 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Long Tubes with x-pipe and true duals, used and abused volant intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front and rear differentials, Cooper Discover ATP tires
    http://www.septemberskyband.com/
  8. #22
    Join Date
    Jun 2003
    Location
    AR
    Age
    44
    Posts
    239
    Liked
    23 times
    Rep Power
    3448
    Thread Starter
    Thanks Lizard... I haven't looked at the Classified section in so long, I forgot we had one. I'll put it on there.
    Highwaylizard likes this.
  9. #23
    Join Date
    May 2012
    Location
    Buena Park
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    i need one for my 2004 tundra right rear sensor mine got damaged when it broke the axle bearing .What is ur best price?
  10. #24
    Join Date
    Jun 2003
    Location
    AR
    Age
    44
    Posts
    239
    Liked
    23 times
    Rep Power
    3448
    Thread Starter
    I still have it. I'm assuming it will fit your truck. Keep in mind that it is the original sensor. PM me an offer.
  11. #25
    Join Date
    May 2012
    Location
    Buena Park
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Sorry .Couldn’t wait so I went to dealer and paid $200 with tax now it’s working perfect
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
