DIY CV Axle Replacement - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Like Tree6Likes
Thread: CV Axle Replacement
  1. #16
    Junior Member kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa's Avatar
    Join Date
    Feb 2008
    Location
    so cal
    Posts
    469
    Liked
    111 times
    Rep Power
    5000
    Default Re: CV Axle Replacement
    All fixed up, and the weekend is still young. Good Job!
    2006 DC 4X4 SR5 Phantom Grey Metallic. Mods include: Full Tint,LED lighting inside & Out. Front End Leveling Kit, 900 watt JBL/Alpine audio System, Mishimoto Aluminum Radiator, OBX Stainless Steel Headers, Magniflow Muffler, TRD Dual Exhaust, Polyurethane Upper/Lower Control Arm & P/S Rack Bushings.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Junior Member E.Amado is on a distinguished road. E.Amado's Avatar
    Join Date
    Mar 2002
    Location
    Flagstaff, Az.
    Age
    33
    Posts
    349
    Liked
    0 times
    Rep Power
    12
    Nice write up! About to do this myself!
    ...Gone Fishing...
  4. #18
    Junior Member seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol's Avatar
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    Quote Originally Posted by kovawa View Post
    Oh Wow -You'd been trying to yank the axle out by pulling on it? It's no wonder you were having problems! CV axles, especially the ones with the inner "Tripod" style joint don't take kindly to "yankin'" The joints are only held in their housing by small cir-clips and the rubber boot itself. It's always best to subscribe to the "Bigger Pry-Bar Theory" when trying to remove the axle stub from the front diff.
    I replaced my CV boots recently and removed both half shafts by lightly tugging on them. They came out very easily. Nothing broken, no problems, no leaks after. 4wd works great.
    01 Tundra 4.7L 4x4 TRD access cab- Camburg uniball UCAs, OME 886 coils, 5100s
    Dynapro ATM 285/75r16 on American Racing Chamber teflon wheels
    electric fans, undercover snorkel, extended breathers, muffler swap, dvd player, remote start
    slow build thread - http://www.expeditionportal.com/foru...ol-s-01-Tundra
  5. #19
    Junior Member huntark03 is on a distinguished road.
    Join Date
    Mar 2012
    Location
    Maumelle, AR
    Posts
    59
    Liked
    4 times
    Rep Power
    2
    I'm having a time just getting the dust cover off the hub. Not seeing where it separates...?
  6. #20
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,027
    Liked
    293 times
    Rep Power
    11256
    You may have to use a cold chisel and a rubber mallet. (You COULD use a thin bladed screwdriver, but not being as wide as a cold chisel, be even MORE careful not bend the cover) Work your way around the cover. Just get it lightly separated in one spot, and move directly opposite on another spot directly opposite the cover. Do it in stages...DONT try to get a huge gap all in one spot. Work it off. Take your time.
    Also, hit it lightly...They are easy to bend.
    Make sure you coat the edge that slips into the hub with anti-seize before reinstalling it...Even if you live in a non-rust area....Should make it easier to pull if you ever need to again.
  7. #21
    Join Date
    Mar 2012
    Location
    Maumelle, AR
    Posts
    59
    Liked
    4 times
    Rep Power
    2
    Got it! Thanks Stone!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
