Low oil pressure in 2000 tundra?
+ Reply to Thread
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By Remmy700P
  • 1 Post By Highwaylizard
Thread: Low oil pressure in 2000 tundra?
  1. #1
    Join Date
    Sep 2010
    Location
    pelican rapids
    Posts
    165
    Liked
    6 times
    Thanks
    0
    Rep Power
    5
    Default Low oil pressure in 2000 tundra?
    Yesturday i notice my oil pressure seem a bit low was in between 1/4 and 1/2 mark at idle and once it would warm up it would sit just above 1/2 mark and when i stop at a stop light it goes down to 1/4 mark but when i'm driving at about 2k rpm its almost to the 3/4 mark, is that normal i though it should be around the 3/4 mark at idle. i'm running amsoil 0-30w.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member pirates712's Avatar
    Join Date
    May 2009
    Location
    Rochester
    Posts
    1,264
    Liked
    222 times
    Thanks
    0
    Rep Power
    32567
    Default Re: Low oil pressure in 2000 tundra?
    If you're running 0w30 I would expect the cold pressure to be less than someone running 5w30 or 10w30. For me, on cold startup at idle the pressure is at about 1/2, at 3k rpm it gets closer to the 3/4 mark. Once it's warmed up it'll sit just above the 1/4 at idle, and just above the 1/2 at 2200 rpm (highway speed). I'm running 5w30 amsoil synthetic.
    712
  4. #3
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,330
    Liked
    3124 times
    Thanks
    0
    Images
    47
    Rep Power
    162921
    This has been covered ad nauseum. It's TYPICAL, EXPECTED, and NORMAL functioning for a crank-driven oil pump.
    kerryman71 likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  5. #4
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,531
    Liked
    2599 times
    Thanks
    0
    Rep Power
    235827
    To add to Remmy's observation what you are seeing is a normal and perfectly perfect readout from the oil pressure.
    280,318 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Fitch Fuel Catalyst, Long Tubes and true duals with twin Aero Turbines, Stock intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the frontand rear differentials, Cooper Discoveer ATP tires
  6. #5
    JHH
    JHH is offline
    Join Date
    Dec 2010
    Location
    American Canyon, Ca.
    Posts
    6
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    What if it goes lower than the 1/4 mark after warmed up and at idle . How low should you start to get concerned?
  7. #6
    Veteran Member marvbest's Avatar
    Join Date
    Aug 2004
    Location
    Las Vegas, NV
    Posts
    770
    Liked
    217 times
    Thanks
    0
    Rep Power
    5643
    If it normally reads at or above the 1/4 mark at warm idle & then suddenly reads lower you need to worry as to why. If it always reads that way then possibly this link will explain and provide a solution.
    2000-2003 Toyota 4.7L Tundra & Sequoia Oil Pressure Gauge Reads Low: Engine Builder
    "You can lead a smart-ass kid to knowledge, but you can be sure that he'll have to argue with the facts"
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
