Low Pressure Power Steering Line Issue
+ Reply to Thread
Results 1 to 14 of 14
Like Tree10Likes
  • 1 Post By Remmy700P
  • 1 Post By mibro
  • 1 Post By RISR5
  • 1 Post By bnz433
  • 2 Post By Archer217
  • 3 Post By ragabash1
  • 1 Post By mibro
Thread: Low Pressure Power Steering Line Issue
  1. #1
    Join Date
    Feb 2011
    Location
    North Providence, RI
    Posts
    113
    Liked
    14 times
    Rep Power
    5
    Default Low Pressure Power Steering Line Issue
    Ok, the hard return line from the rack to the reservoir for the power steering is leaking on my truck, due to what looks like some corrosion around one of the bushings where its bolted to the body. I've contacted my local dealer about a replacement and they informed me that the only way to get that hard line is to buy an assembly that includes the high pressure line and all the soft rubber lines and so forth.....for a whopping $500....not a chance. So if anyone who has toyota parts experience I would appreciate it if you could tell me if its possible to get this hard line separately (hell I'd dish out for the two soft lines on either end if I had to). If thats not going to be an option what would you guys think about running one length of rubber line from the reservoir down to the rack? A hell of a lot cheaper and honestly I dont think it would really make a difference. I would assume a length of heater hose would do the trick.....Any and all comments are appreciated.....seeing as how I have to get this nonsense straightened out sooner than later....thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supercharged Member 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    2,147
    Liked
    918 times
    Images
    14
    Rep Power
    41486
    Default Re: Low Pressure Power Steering Line Issue
    i'm gonna go out on a limb, in the tree of the uninformed, and say the reason they use hard lines is to minimize vibration/bounce/flex. if you secure it with zip-ties to minimize any rub issues i don't see a problem.
    and you just saved $480....
    All you Baja lovers check out: http://www.MasOlas.com
  4. #3
    Join Date
    Feb 2011
    Location
    Posts
    113
    Liked
    14 times
    Rep Power
    5
    Thread Starter
    Kind of what I was thinking, I think ultimately the rubber line would only be a temporary thing. I found a couple places online that rebuild lines and such....so if I have the hard line out of the truck I shouldnt have too much of a problem getting a new one fabbed up. Theres just no way I'm buying into a $500 assembly for just that one line.
  5. #4
    Join Date
    Feb 2011
    Location
    az
    Posts
    23
    Liked
    2 times
    Rep Power
    5
    maybe you could finde a copper line conector at home depot to cut out the leaking part and splice in a short peace of copper
  6. #5
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3187 times
    Images
    47
    Rep Power
    162921
    Thumbs up Re: Low Pressure Power Steering Line Issue
    Contact these guys: Arizona Tubes & Hoses. A while back, another TSer had them fab up a replacement and it was a fraction of what the dealer wants to ream you for.
    It's essentially just a hydraulic line. If you get a hose rated for the chemical makeup of PS fluid/ATF, then I don't see why a soft line wouldn't work.
    Highwaylizard likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  7. #6
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,246
    Liked
    429 times
    Images
    25
    Rep Power
    24550
    Here's the tube assembly. The low pressure return line from the rack runs to the power steering cooler (which is just a single loop of metal tube) and then back to the reservoir. This line is at zero pressure so you may be able to fabricate a new piece of hard line by bending up some brake line or fuel line and flaring the ends. I wouldn't try that with the pressure line from the pump to the rack, though. A hydraulic house could fab that up for you.
    Click image for larger version.
Name:	Tube Assy, Pressure Feed.jpg
  8. #7
    Join Date
    Feb 2011
    Location
    Posts
    113
    Liked
    14 times
    Rep Power
    5
    Thread Starter
    Thanks for all the replies guys.....I just went out on a limb and bought some 3/8" heater hose (roughly 4 feet will do the trick). The O/D of the hose isnt too large so you can still use the same brackets in play for the hard line to keep it in place. Its still only a temp fix....I just want to try and find a local hydraulics shop that can fab up a replacement line for me. If and when I find that company locally here I'll post it up just in case anyone from this area is looking for something like that. Thanks again guys
    yotatoter likes this.
  9. #8
    Junior Member bnz433's Avatar
    Join Date
    Dec 2007
    Location
    Clifton Park NY
    Posts
    120
    Liked
    5 times
    Rep Power
    8
    RISR5 - I had the same issue on my '05 DC, but it was right out of the rack, where it bends down to the cross member. This is 10mm tube, and nobody around me carried it, so they bent me a new 3/8 with the flare (to accept the 17mm flare nut). All i did was brought them the rusted line, and they made up the tube to match. The left me a "bump" at the very end, where the tube runs along the cross member, so that I could then use the original hose which was clamped to the old tube. Took all of 10min at the hydraulic shop, and $20 for the material. It was a bit tight stuffing the 10mm hose on the 3/8 tube, but works fine. If you have a flare tool and tube bender, you can get the 3/8 at any NAPA store for about $10. But I didn't so off to the hydraulic shop I went.
    Good luck.
  10. #9
    Join Date
    Jun 2009
    Location
    Fort Worth, TX
    Posts
    1
    Liked
    2 times
    Rep Power
    0
    Great info Remmy!!! My local dealer tried this bit on me as well. They wanted $800, parts and labor. Not in this lifetime.
    Thanks again for the info.
    Remmy700P and Highwaylizard like this.
  11. #10
    Join Date
    Apr 2008
    Location
    New Bedford, MA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    RISR5, have you found someone local to fab a replacement line? I'm in SE Ma & both my high & low pressure lines need replacing. There is no way I'm paying my dealer what he's lookin to charge me...
  12. #11
    Join Date
    Feb 2011
    Location
    Posts
    113
    Liked
    14 times
    Rep Power
    5
    Thread Starter
    Quote Originally Posted by marreeme View Post
    unfortunately no I haven't done anything about it.....the rubber line I put in as a temporary situation has become more permanent these days. If I had to guess.....any shop that deals with fabbing up Hydraulic Lines would be able to do those up in a heartbeat. You would just have to pull the originals so they would know how to bend them and such. We have a Diesel mechanic here at work and he wasnt much help with giving idea's as to who I could call so if you find someone local to the RI/SE Mass area let me know....
  13. #12
    Join Date
    Feb 2006
    Location
    northern,nj
    Posts
    38
    Liked
    14 times
    Rep Power
    27
    I had the low pressure line fail in my old t-100, and the high pressure line was on its way out, my mechanic did not want to touch it without a solution in hand because he said, oh, thats going to crumble when I wrench it, we looked up the toyota part, and it was 690, and that was only if he could get it. we both said thats nuts. So, I started looking. I found that trailgears kit for 83 was almost a direct bolt up.
    Tacoma Steering | Toyota, Suzuki Samurai, and Jeep Off Road Parts
    I lost a vacuum dohickey but, saved 600 so, I was ok with it.
    I am thinking a 4wd shop should figure out the hoses, make a kit and then get wealthy selling it back to us.
  14. #13
    Lurking Member ragabash1's Avatar
    Join Date
    Oct 2011
    Location
    Delaware, Ohio
    Posts
    48
    Liked
    17 times
    Rep Power
    1588
    I know this is a necro-thread but I wanted to provide a solution because I'm sure this will be google-searched by many others.
    I had the same problem, the low-pressure return line rusted through just at the fitting at the rack, where Toyota covered it in rubber.
    It's a 17mm o-ring fitting and a 10mm steel tube with a hose barb at the other end.
    Called Toyota looking for it and the dealer told me they only sell it as a "Hydraulic tube assembly" with the high pressure line, hoses, clamps, etc. for $580!!!
    Well that's a darn truck payment.
    So I got into the Gates products catalog and did some cross-reference searching. The return tube for a 3rd gen Camry or a Lexus ES300 is the same size tube, fitting, O-ring and nut. Only problem is it is bent for the Camry not the Tundra, obviously.
    Advance Auto Parts had the Camry tube in stock on the shelf for $30 and change. It is a Powercraft part # 92015.
    I figured what have I got to lose? So I picked it up.
    I didn't have a tube bender the right size so I used a bench vise and screwdriver handles for a mandrel.
    After an hour of tinkering and bending carefully to not crimp the line I wound up with something that fit. The Camry line is a bit longer and to use the right-angle bend already in the line it winds up sitting an inch or so lower than the original, about the level of the anti-sway-bar. It did end up being able to be clamped in the same clamp that holds the high and low pressure lines on the passenger's side frame. The hose barb section was longer and I didn't want to cut it shorter and lose the barb, but the original rubber hose and clamp fit well enough. I could have trimmed 2-3 inches off the rubber hose but it was OK as is. I let the hose go all the way up the new metal tube so there was 2-3 inches inside the hose, and it leaked like that, so I had to make sure I pulled the hose back towards the barb like it should have been.
    Refilled with Dexron fluid, and bled it out, and no more leaks. Now my wife will let me park it in her garage again!
    mibro, Remmy700P and Highwaylizard like this.
    "A man's got to know his limitations." -- Insp. H. Callahan, SFPD
  15. #14
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,246
    Liked
    429 times
    Images
    25
    Rep Power
    24550
    Quote Originally Posted by ragabash1 View Post
    That's great info. If you search Advance Auto's web site for Powercraft "17MM Male O-Ring" you get 12 different products, so there's a good selection of options there.
    While we're sharing info, you can also buy the right and left steering pressure tubes separately from the dealer. These tubes look like part of the rack but they can in fact be replaced separately. Part numbers 44418-0C010 and 44419-0C010.
    Remmy700P likes this.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
