Question Front suspension help please! - Page 3
NEWS
+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Like Tree11Likes
Thread: Front suspension help please!
  1. #31
    Junior Member 05tundrawhite is on a distinguished road.
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Thread Starter
    Default Re: Front suspension help please!
    ill definitely try it then. my buddy has a good ob2 reader. so ill hook up tomorrow and see what the rear 02 sensor is reading.
    cpearson817 likes this.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #32
    Rookie christopher126 is on a distinguished road.
    Join Date
    Aug 2010
    Location
    deep
    Posts
    16
    Liked
    0 times
    Images
    3
    Rep Power
    0
    did you replace the shocks and if so did it solve the problem i have same issue right now too
  4. #33
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Thread Starter
    I have not replaced the struts yet. I did however have to replace both cats. The strut problem is the strut mount i do believe. I ordered one from napa, but it still isnt in yet. They said it was coming straight from the factory. But you could have better luck getting it at toyota.
  5. #34
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    Quote Originally Posted by 05tundrawhite View Post
    Could you elaborate on what leads you to believe this diagnosis?
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's 1" Rear Block | Hellwig EZ-550 Helper Springs
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    NGK Platinum Plugs #BKR6EGP | Russell Speed Bleeders #639560 |Kobalt LP Bed Box
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
    "There are TWO keys to success: 1. Never tell anyone everything you know."
  6. #35
    Veteran Member 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed's Avatar
    Join Date
    Feb 2002
    Location
    Santa Barbara, CA
    Posts
    741
    Liked
    34 times
    Images
    19
    Rep Power
    1640
    I hope someone didn't diagnose the need to replace your cats from the codes. Without a true smog test you can't tell if the cats are bad even with the kick test. I threw those codes plenty of times but with the required california smog tests that were perfect confirmed the failing rear O2 sensor.
  7. #36
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Thread Starter
    I already changed one of the rear o2 sensors, and the code kept popping up. No exhaust leak so that is the cat. NO CODES AFTER NEW CATS. REMMY700. I would think strut mount because the only thing that holds the strut on top is the rubber strut mount. The wiggle on my was at the top of the strut. The center of the mount has a hole for the strut to go through and mount.
  8. #37
    Moderator Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    5,456
    Liked
    660 times
    Blog Entries
    78
    Images
    65
    Rep Power
    136813
    What brand and how much did that cost you?
    Tundra Fuel Economy Blog
    227,537 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires
  9. #38
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Thread Starter
    I did high flow magnaflow cats with 2 flow master super 40s and some nice tips coming out the side. all for 540. not bad when the cats were almost 200 a piece.
  10. #39
    Junior Member TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1 has done just about everything...and then some. TundraDad1's Avatar
    Join Date
    Dec 2010
    Location
    Glennville, GA
    Posts
    73
    Liked
    19 times
    Images
    7
    Rep Power
    824
    I'd like to try & help, but dang if I'm not confused I suppose you're speaking of the strut mount & insulator assembly, which is at the very top of your strut & coilspring assembly. However considering your quoted tire size, you may have some sort of "Spacer Lift" device which may cause us to offer you bad advice. I believe Tundrunk is dead-on, we need a picture.....
    arseum and Remmy700P like this.
    2005 Tundra D/C 4x4 Limited-Finest Vehicle I've owned yet!! "Freedom is not just a right, it is a responsibility!!"
    Bilstein 5100's all around, (Set on 3rd Notch up front), Westin Sportsman Grill-Guard, Dirty-Deeds Ind. BAMuffler, (Love it!!), Flexi-Lite Dual Electric Fans, (Best MPG Improver yet!!!), Upgraded Head&Fog bulbs, & a few other tidbits that probably won't matter to you all, but I really like!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
