Question Front suspension help please!
NEWS
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Like Tree11Likes
Thread: Front suspension help please!
  1. #1
    Junior Member 05tundrawhite is on a distinguished road.
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Default Front suspension help please!
    Hi, I just bought my first Tundra. Abesolutely love the truck; however, I have a squeak. The sound is coming from the front drivers side shock. I have for sure narrowed it down to the shock. You can push on the shock from the very top where the threads are and push it just a bit. Also, if you put a wrench to the top the top half of the shock will spin. Neither of these two problems happen on the passenger side. Is the shock just busted, or do I have other problems? Just hear the metal squeak when going over bump. The truck is a 2005 Tundra, double cab, 4x4, limited, with the 4.7. Any help would be useful. Thank you.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Thread Starter
    Default Re: Front suspension help please!
    So, 85 views and not even the slightest hint of help. Thanks guys.
  4. #3
    Veteran Member cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points.
    Join Date
    Jun 2010
    Location
    Chesterfield, VA
    Age
    17
    Posts
    662
    Liked
    207 times
    Rep Power
    7706
    Quote Originally Posted by 05tundrawhite View Post
    Sounds like a dead strut.
    If you want to retain stock height, get a new front set of Bilstein HD's.
    If you want to lift the front and level the truck get the 5100's. I am sure AJUSA could set you up with either, I got my 5100's through him.
    2000 Tundra V8 SR5 4x4 AccessCab
    3K4 Red Mica Metallic | Bilstein 5100s 2.5" Front | Wheeler's Off Road 1" Rear Block
    LT265/75R16 123Q Goodyear Wrangler DuraTrac | MB Wheels - Razor
    Penzoil Ultra Synthetic 5W-30 | Purolator PureOne Oil Filter| Mobil 1 Synthetic Gear Oil
    NGK Platinum Spark Plugs | Josh's Billet Wing Window Latch Upgrade
    1/9/2012: 252,197 miles
    "No bastard ever won a war by dying for his country. He won it by making the other poor dumb bastard die for his country."
    - General George Patton Jr
  5. #4
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    You gave it a whole 12 hours before coming off like a petulant child.
    This is a public forum. Others are here to help at a time of their choosing, not yours. If you want or need immediate attention, take your truck to a mechanic.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's 1" Rear Block | Hellwig EZ-550 Helper Springs
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    NGK Platinum Plugs #BKR6EGP | Russell Speed Bleeders #639560 |Kobalt LP Bed Box
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
    "There are TWO keys to success: 1. Never tell anyone everything you know."
  6. #5
    Veteran Member 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,099
    Liked
    130 times
    Images
    14
    Rep Power
    9085
    word of the day, "petulant!"
    Highwaylizard likes this.
    1 Ola Mas!
  7. #6
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    Quote Originally Posted by 2003bajatundra4x4ac View Post
    I thought it was supposed to be "Clydesdale"??!!!
  8. #7
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Thread Starter
    Not even acting childish, usually being a new person on a forum doesnt get you the best help. Plus that was mean as more of a joke than coming or ultra serious. But I am getting a little impatient bought the truck last friday and been at the dealers shop for a week. Just to pick it up with more problems. They dropped the tank to replace fuel line and now takes 45 minutes to fill up cause its kinked. What I get for letting others do my work. I wAs looking online could this problem be the shock mount itself. It's a relatively cheap part. Gonna break it down today after duty.
  9. #8
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    No worries. It's just those "Gee... thanks for the no help" posts don't fly too well on technical forums.
    CJ (cpearson817) probably has it right. It sounds like the strut's toast. Make sure that all the shock mount bolts (3) are torqued properly. Also, make sure that the coil isolator pad (between the top of the coil and the upper shock mount) is still intact.
    If you choose to replace the struts, regardless of ride-height, I would suggest the Bilstein 5100s as a replacement. They're only a few bucks more than the HDs, but you have the option of running at anywhere from stock height to about 2" of front lift. If you also get the valve-matched rear 5100s, they will accomodate up to 1.5" of lift via either a block or add-a-leaf (AAL).
    Hope you get the gas tank filling tube figured out. That sounds like a major PITA...
  10. #9
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Thread Starter
    Thanks man. I'm gonna take it apart later. I think it could be that mount now. The shock having wiggle just concerns me. The shock being busted shouldn't cause wiggle.
  11. #10
    Supercharged Member Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5's Avatar
    Join Date
    Jun 2009
    Location
    Montana
    Posts
    3,009
    Liked
    334 times
    Images
    12
    Rep Power
    263738
    The lower shock bushings on mine were worn out at around 36k and squeaked like a mofo. The bushings are available separately.
    Sent from my DROID X2 using Tapatalk
    05 DC SR5
    4.5" Tuff Country lift
    Bilstein coilovers
    Toytec AAL
    other stuff
    Quote Originally Posted by italianprimate View Post
    it feels like it cums from under my but and behind me slightly and best way to describe it is if someone where to bump me from behind
    Quote Originally Posted by DevinSixtySeven View Post
    two of u guys totally make me want to type leik this of or plain engrish.
    -Sean
  12. #11
    Join Date
    Jun 2010
    Location
    Chesterfield, VA
    Age
    17
    Posts
    662
    Liked
    207 times
    Rep Power
    7706
    Quote Originally Posted by Remmy700P View Post
    I agree with the 5100's. I love mine, and they just absorb everything...
  13. #12
    Supercharged Member tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    4,056
    Liked
    257 times
    Images
    191
    Rep Power
    130693
    Are you talking about the stock shocks? I think the top half is just a dust cover, it should spin free. If I remember right, the shock body is on the bottom half, exposed from the coil, and the top half inside the coil is just a tube cover.
    You did mention threads at the top, what threads are they? I was thinking you have aftermarket coilovers from that part.
    You don't have to know a man to treat him the way he should be treated. -Peter Tosh
  14. #13
    Join Date
    Nov 2009
    Location
    Posts
    4,056
    Liked
    257 times
    Images
    191
    Rep Power
    130693
  15. #14
    Join Date
    Feb 2012
    Location
    Homestead
    Posts
    80
    Liked
    4 times
    Images
    2
    Rep Power
    1
    Thread Starter
    I believe everything is stock. I could be wrong though. Don't know that much about these trucks. It does have coil overs though. the threads out of the top are the top threads of the strut. I actually had time to look today. The part that spins is a dust cover. I priced out some bilstien shocks today for fun not to bad. Need to get new tires also. Right now the truck has 285/70 r17 will a shock truck fit these of does this truck have lifting springs there is no leveling spacer.
  16. #15
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    I don't understand the above sentence...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
