Where to pour seafoam through to clean intake
NEWS
+ Reply to Thread
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Highwaylizard
Thread: Where to pour seafoam through to clean intake
  1. #1
    Rookie trd214 is on a distinguished road.
    Join Date
    Jan 2012
    Location
    Oregon
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default Where to pour seafoam through to clean intake
    Can someone post a photo as to where to pour seafoam through to clean the intake? I used to do this with my
    Tacoma but this is the first time with the Tundra. Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    Default Re: Where to pour seafoam through to clean intake
    Seafoam makes it in a spray can with a straw & hook assembly that hooks over the throat of the intake. You temporarily reinstall the intake hose, run the engine, and spray while it's running.
    Go to Seafoam's website for more information.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's 1" Rear Block | Hellwig EZ-550 Helper Springs
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    NGK Platinum Plugs #BKR6EGP | Russell Speed Bleeders #639560 |Kobalt LP Bed Box
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
    "There are TWO keys to success: 1. Never tell anyone everything you know."
  4. #3
    Supporter arseum has disabled reputation
    Join Date
    Nov 2005
    Location
    Katy, TX
    Posts
    512
    Liked
    68 times
    Images
    11
    Rep Power
    3766
  5. #4
    Moderator Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    5,456
    Liked
    660 times
    Blog Entries
    78
    Images
    65
    Rep Power
    136813
    Here you go:
    My finger is pointing to the hose that leads from the PCV valve. Pull the hose from the PCV valve and use a small funnel when pouring to eliminate spillage. Follow directions on the can. Pour slowly to avoid hydro-lock or killing the engine.
    This is where the vacuum hose from your PCV valve attaches - it is the brass nipple where I pulled the hose off.
    Tundra Fuel Economy Blog
    227,537 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires
Posting Permissions
  • You may not post replies
  • You may not edit your posts
