reading reviews it looked like many didnt use it and those who tried to were easily frustrated by its installation
*Anything I say has a very good chance of being based on nothing but personal intuition and vague secondhand comments and so may be completely false or even dangerously stupid. Listen to me at your own risk.
2001 Black AC V8 4x4Current Mods: TrailFX Tube Steps, Uniden CB Radio, Recon Tailgate LED Bar, Edelbrock Exhaust, Hankook Dynapro ATM 265/70/R16, Blacked Out Emblems, Plastidip Mirror Caps, Bumpers and Front Grill, Skid Row Skid Plate (Thanks to four_by_four), Full Blue LED interior lighting, Herculiner Bed Liner, Kobalt Low Profile Tool Box, Smitty Built Rear Shackle, Walmart Front and Rear AUX lights, JVC Headunit, Pioneer Door Speakers, Magnefine Filter
Thanks to Rust: New Frame, New Calipers, New Rear Axle, Sway Bar End Links, Tailgate Straps, Exhaust Leaks,
To Do: Change ATF, Diff Fluid, Transfer Case Fluid, Refinish Wheels, New Front Components, Uniden BCT-8, Black Caliper Paint, Remote Start, Redo Exhaust
01 Tundra SR5 -
AFE Stage 2 CAI, Shorty Headers, 18" Magnaflow Magnapack, Hornblasters S4 Shocker Train horns, 2 Gallon Tank, LED 3rd Brake light, 6000k Bi-Xenon HID Headlights, 6000k Fog lights, Bed Cover, All Green and Blue Interior LEDs, LED Under Dash lights, 48" LED strip behind back seat headrests, LED Dash lights, LED A/C Panel lights, Alpine Door speakers, Boss Tweeters, 800w Autotek Street machine 4 channel amp hi's, 10" SSD Fi, 1600w Hifonics Brutus amp, Pioneer 5000ub Head unit
http://www.tundrasolutions.com/forum...store-coupons/ GOOD STUFF IN HERE
Hehehe :P
VBS = Visual Basic Script
INI = Initiation(Configuartion) file
Basically the script would call on the INI file which holds the information to load, like different sets of numbers.
It shouldn't be too hard to implement once you get something going. I am here to help if you have any questions, or I am sure that your teacher would help too!
-CJ
2000 Tundra V8 SR5 4x4 AccessCab
3K4 Red Mica Metallic | Bilstein 5100s 2.5" Front | Wheeler's Off Road 1" Rear Block
LT265/75R16 123Q Goodyear Wrangler DuraTrac | MB Wheels - Razor
Penzoil Ultra Synthetic 5W-30 | Purolator PureOne Oil Filter| Mobil 1 Synthetic Gear Oil
NGK Platinum Spark Plugs | Josh's Billet Wing Window Latch Upgrade
1/9/2012: 252,197 miles
"No bastard ever won a war by dying for his country. He won it by making the other poor dumb bastard die for his country."
- General George Patton Jr
Toby, This says it can send logging info into excel for analysis. Not sure what all it can record at once. Thanks to Remmy:
https://market.android.com/details?i...l.torque&hl=en
That headS-up (sorry, Air Force vet here) display looks great at night! Now, combine with FLIR and you've got something.
"... nevertheless, thou may chose for thyself ..."
Mormon Doctrine
01 Tundra SR5 -
Tundra Fuel Economy Blog
227,537 miles on the odometer [come see me when you get that on your ford]
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires
2002 Tundra V8 SR5 2WD AC
1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's 1" Rear Block | Hellwig EZ-550 Helper Springs
LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
NGK Platinum Plugs #BKR6EGP | Russell Speed Bleeders #639560 |Kobalt LP Bed Box
Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
* * * I highly recommend Auto-Rx for your engine and transmission. * * *
* * * O2 Sensor Replacement DIY * * *
"There are TWO keys to success: 1. Never tell anyone everything you know."
