Question Another rear diff gear oil question
NEWS
+ Reply to Thread
Results 1 to 10 of 10
Like Tree9Likes
  • 3 Post By Highwaylizard
  • 2 Post By Remmy700P
  • 1 Post By Invid
  • 1 Post By 2003bajatundra4x4ac
  • 2 Post By Highwaylizard
Thread: Another rear diff gear oil question
  1. #1
    Rookie Canatct is on a distinguished road.
    Join Date
    Jan 2005
    Location
    cana
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default Another rear diff gear oil question
    I have a '05 Tundra DC 4x4 with the limited slip diff. It has 120,000 miles and has never had the rear gear oil changed (which I plan to do tomorrow). I know Toyota recommends the 80w90 conventional but I can buy Amsoil 75w90 severe gear for about $11/qt here locally. I am apprehensive because of what I have read about inner axles seals leaking when switching over. The price I'm getting is a good deal but is it worth the risk, or should I just get the 80w90 conv and add 4 oz of additive and be done with it? Any suggestions are welcome.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points. cpearson817 has a criminal record for giving away rep points.
    Join Date
    Jun 2010
    Location
    Chesterfield, VA
    Age
    17
    Posts
    662
    Liked
    207 times
    Rep Power
    7706
    Default Re: Another rear diff gear oil question
    Quote Originally Posted by Canatct View Post
    You will be fine with the 75w90, the 5w will not make enough difference.
    A lot of people have used the 75w90 amsoil gear oil on here
    2000 Tundra V8 SR5 4x4 AccessCab
    3K4 Red Mica Metallic | Bilstein 5100s 2.5" Front | Wheeler's Off Road 1" Rear Block
    LT265/75R16 123Q Goodyear Wrangler DuraTrac | MB Wheels - Razor
    Penzoil Ultra Synthetic 5W-30 | Purolator PureOne Oil Filter| Mobil 1 Synthetic Gear Oil
    NGK Platinum Spark Plugs | Josh's Billet Wing Window Latch Upgrade
    1/9/2012: 252,197 miles
    "No bastard ever won a war by dying for his country. He won it by making the other poor dumb bastard die for his country."
    - General George Patton Jr
  4. #3
    Moderator Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    5,456
    Liked
    660 times
    Blog Entries
    78
    Images
    65
    Rep Power
    136813
    If your fluid has not been changed in 120,000 miles I would not waste Amsoil on it for the first change. Run regular Valvoline in it first and then do another change 3-5,000 miles later with Amsoil.
    Switching from dino oil to synthetic oil per say does not cause seals to leak. What causes the seals to leak is if the breather is clogged. The other cause is if the seals have shrunk due to being coated with sludge or gunk inside the differential and thereby not being exposed to the lubricating or "hydrating" properties of the oil. The new oil (synthetic or otherwise) tends to clean this junk out and expose the shrunken seals which allows oil to leak. It may be possible to pre-treat the seals by running some AutoRx but you should consult with Remmy700 first as he knows more about this than I do.
    Tundra Fuel Economy Blog
    227,537 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires
  5. #4
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    5,648
    Liked
    1031 times
    Images
    37
    Rep Power
    102836
    The issue with axle seals leaking after switching to synthetic gear oils was a function of the design of the early model's seals. That has been corrected, so you will be fine switching to a full synthetic.
    The 75W-90 Mobil 1 is an excellent gear oil. Some have been lucky and not required any LSD friction modifiers, others have needed to add a couple ounces to quiet it down. I'd suggest having a tube on hand just in case.
    I would also suggest a 500-1000 mile "flush run" with a less expensive gear oil like Highwaylizard recommended before refilling with the (expensive) Amsoil.
    I don't see any benefit to treating it with ARX unless there are symptoms of heavy contamination.
    SuckersWalk and cpearson817 like this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's 1" Rear Block | Hellwig EZ-550 Helper Springs
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    NGK Platinum Plugs #BKR6EGP | Russell Speed Bleeders #639560 |Kobalt LP Bed Box
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
    "There are TWO keys to success: 1. Never tell anyone everything you know."
  6. #5
    Join Date
    Jan 2005
    Location
    cana
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the replies guys. I actually have a degree in auto technology and used to work on bowties (reason I drive a Toyota) but it has been many years ago and when I did diff fluid changes on the chevy trucks it was always conventional back then. I will use a cheaper dino for a 1,000 miles or so and then run the Amsoil. Thanks again!
  7. #6
    Junior Member Raider Man is a splendid one to behold. Raider Man is a splendid one to behold. Raider Man is a splendid one to behold. Raider Man is a splendid one to behold. Raider Man is a splendid one to behold. Raider Man is a splendid one to behold. Raider Man is a splendid one to behold. Raider Man is a splendid one to behold. Raider Man is a splendid one to behold. Raider Man is a splendid one to behold.
    Join Date
    Jan 2003
    Location
    Danielsville, GA
    Age
    52
    Posts
    140
    Liked
    0 times
    Rep Power
    16
    I have been using Valvoline 80-90 with 4 oz. GE additive for 90000 miles with no problems. Changed every other year for me about 28000 miles total with no problems.
  8. #7
    Junior Member Invid is on a distinguished road. Invid's Avatar
    Join Date
    Jun 2002
    Location
    Corona, CA
    Age
    39
    Posts
    368
    Liked
    6 times
    Rep Power
    10
    I ran AMSOIL 75w90 for the past 80K miles without issue and just replaced it all last month. It came out looking like NewCastle Brown Ale and went in looking like Corona Light.
    SuckersWalk likes this.
    Spintech 3332XL Muffler | Hellwig Rear Anti-Sway Bar | Updated 2005 Tail Lights | Updated 2003 Alloy Wheels | AMSOIL OAF-15 Oil Filter | Ultra-Strong Oil Filter Magnet | Synthetic Fluids all around | Line-X Bedliner | Osram Silverstars | Michelin LTX M/S tires | Custom Grille w/updated Body Panels | De-Badged | Optima Spiral Cell Gel Battery
  9. #8
    Veteran Member 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac has a criminal record for giving away rep points. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,099
    Liked
    130 times
    Images
    14
    Rep Power
    9085
    corona light is what i produce after drinking a pitcher of "yellowtail pale ale...."
    just sayin.
    Highwaylizard likes this.
    1 Ola Mas!
  10. #9
    Junior Member INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light. INDYMAC is a glorious beacon of light.
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    448
    Liked
    15 times
    Images
    2
    Rep Power
    253
    I'm afraid what you see when you pull the drain plug will look frightful (remember to always remove the fill plug before the drain plug). Here is what I would recommend how you procede after so many miles of neglect:
    Mag-Hytec
    Next I would fill with any conventional GL5 gear oil (Valvoline, Castrol, etc.) with LS additive and then add 2 ozs of Auto-Rx for every quart you put into the diff to fill to the fill hole. Drive for 1000 miles and then drain. Then fill with whatever gear oil that you want to start using for 30K mile OCI's.
    Fortunately, the Tundra has a fill and drain plug instead of a bolted faceplate, so it's an easy procedure to do yourself.
    Good luck!
  11. #10
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    5,456
    Liked
    660 times
    Blog Entries
    78
    Images
    65
    Rep Power
    136813
    My rear differential fluid at first change right after I bought the truck used at 103,000 miles
    Tundra Fuel Economy: Changing the Rear Differential Fluid
    After changing I blew three rear axle seals until I did the breather modification (mine was missing) and have had absolutely no problems since. I think the rear axle seals would have blown regardless of changing the fluids as the hole that the stock breather cap was supposed to be in was completely clogged.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
