Front drive axle throwing grease
+ Reply to Thread
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By RISR5
Thread: Front drive axle throwing grease
  1. #1
    Join Date
    Jun 2010
    Location
    guatalahara
    Posts
    20
    Liked
    4 times
    Rep Power
    6
    Default Front drive axle throwing grease
    Hi all
    While changing the oil in my '03 Tundra last week I noticed both front drive axles have been throwing grease from the inner boots. Closer inspection reveals no torn boots, appears the metal band between the larger and smaller inner boots has just loosened allowing grease to escape. I haven't heard any grinding or clicking while driving. Truck has 123K on it, as far as I know these are original axles.
    As far as I can tell my options are to remove and replace entire axle assembly, or remove and rebuild with a "boot kit".
    My questions are: 1 - Based on mileage should I just replace the axles, even though there is no evidence (i.e. noise) indicating the CV joints are bad? 2 - If replacement isn't necessary, is there a way I can re-grease the boots and tighten the bands without removing the axles.
    Thanks for the info.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2011
    Location
    North Providence, RI
    Posts
    113
    Liked
    14 times
    Rep Power
    5
    Default Re: Front drive axle throwing grease
    this is actually on my "to-do" list, I'm in the same boat where there is grease being thrown but the stock clamps are still in place. With that scenario I cant see how much dirt would find its way into the boot to ruin the cv's. I would imagine that if you're not hearing the tell tale signs of a messed up cv then all you should really do is pull the stock clamp off, pull the boot back, inspect for excessive dirt and such, liberally apply some cv joint grease and install a new clamp...no point in replacing axles if you dont need to, down the road if they start clicking....then do it, but dont jump the gun if you dont have to. Its not like they're just going to explode into tiny pieces from normal driving.
    Highwaylizard likes this.
  4. #3
    Join Date
    Nov 2005
    Location
    Katy, TX
    Posts
    636
    Liked
    107 times
    Images
    13
    Rep Power
    4500
    Or use the OEM clamp and BLUE thread locker.
  5. #4
    Supercharged Member 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    2,149
    Liked
    924 times
    Images
    14
    Rep Power
    41486
    remove the POS stock clamp(s) and peel back the boot and put half a package of CV JOINT grease in each joint. then reclamp.
    http://www.tundrasolutions.com/forum...od-hose-clamp/
    All you Baja lovers check out: http://www.MasOlas.com
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
