Vibration/sway at highway speeds after lifting. (5100 content)
+ Reply to Thread
Page 1 of 7 1 2 3 4 5 6 ... LastLast
Results 1 to 15 of 102
Like Tree24Likes
Thread: Vibration/sway at highway speeds after lifting. (5100 content)
  1. #1
    Junior Member bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp's Avatar
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Default Vibration/sway at highway speeds after lifting. (5100 content)
    Not sure if i'd call it vibration, sway, or what...but I lifted the front of the truck (2003 AC) by 1.3" using Bilstein 5100's on the third notch. I drove it for a couple of days and thought it was great. THEN had it aligned and the tires rotated. Immediately I noticed a slight bump/sway/vibration/shimmy in the steering wheel once I get to about 60 MPH. I assumed my front tires were bad due to late rotation (they were now on the rear) so I went ahead and got new tires. Same problem with the new tires. Kinda feels like it would if a wheel was out of balance.
    Is there something that wouldn't be addressed by the alignment that I should look at? I could have them recheck the alignment, but it's a tire shop and I just bought tires somewhere else so I don't know how cooperative they'll be. I realize the truck isn't engineered to be lifted that way, but wanted to ask if this seems normal or if I missed something.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,667
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    Default Re: Vibration/sway at highway speeds after lifting. (5100 content)
    so it didn't do it before the alignment, but it did it after the alignment? i would have taken it back to them instead of trying to diagnosis the problem on an internet forum. take it back.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  4. #3
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Thread Starter
    Quote Originally Posted by SuckersWalk View Post
    You'd be surprised how many things can be diagnosed on an internet forum. No, I didn't notice it before the alignment, but I was trying to be really careful with the truck between the lift and the alignment. They're pretty good with the alignments and provide a nice chart of how everything is set up. Just want to see if my experience is common.
  5. #4
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,111
    Liked
    2028 times
    Images
    47
    Rep Power
    121449
    Post up your alignment numbers. It sounds like too little caster to me.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  6. #5
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Thread Starter
    You know...now that I look at this chart, I see that they put my tire size in wrong. Way wrong. Would that make a difference?
  7. #6
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,667
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    did the other dealer convince you to get new tires to fix the problem you were experiencing?
  8. #7
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Thread Starter
    No...I was gonna go up a size anyway. It's cause Fishontro made fun of my tiny little tires!
    Preparing to lift. Need advice (pics inside)
  9. #8
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,667
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    lol. did they give you a free alignment check with the tires?
  10. #9
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Thread Starter
    No. I got them at Discount Tire. I'm not even sure they do alignments. Nevertheless, it's at the alignment shop now and they are telling me I've got a warped wheel. I figured something like that would be the answer since I didn't buy the tires from them. I couldn't afford their tires though.
  11. #10
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,111
    Liked
    2028 times
    Images
    47
    Rep Power
    121449
    Quote Originally Posted by bnjp View Post
    All that alignment shop did was "set the toe and let it go". Tire size doesn't matter. There's too much cross-camber, and the caster needs to be higher... closer to 2 degrees.
    I'd be pissed beyond measure if a shop tried to slip that lazy bull**** past me. How much did they charge you for that?
    I'd go right back with DJ's alignment specs and tell them to meet it. If they balk, or say they can't, then I'd get my money back and go someplace that has a Hunter alignment console and a tech that knows how to use it.
  12. #11
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Thread Starter
    That's interesting Remmy. I didn't know there was that much difference. To their credit, they remounted the left front tire and almost eliminated the problem. I'm back at Discount Tire now and they are putting the tires back on some different type of balancing machine that they "don't always use for all terrain tires" I really think they mounted the tire poorly...left front.
    I'm not familiar with DJ's alignment specs. Could you point me to those?
  13. #12
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,111
    Liked
    2028 times
    Images
    47
    Rep Power
    121449
    Attached.
  14. #13
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Thread Starter
    Thanks. I imagine their machine just throws out an acceptable range and they try to get it out of the red zone. I will see who has that Hunter machine.
    I took the truck back to Discount Tire and they took all the wheels off, and put them on their "Road Force Balancer" which they said they don't always do. I'll insist on it from now on. I realize I bought cheaper tires, but I've never had problems with Cooper before. It does ride MUCH better now and they said they did have to remount a couple of the tires.
    arseum likes this.
  15. #14
    DJ
    DJ is offline
    Supporter DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points. DJ has a criminal record for giving away rep points.
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,018
    Liked
    175 times
    Rep Power
    8592
    That printout is from a Hunter alignment machine. The problem is not the machine, rather it is the person who used it. Likely he meant well, but he doesn't know what he doesn't know.
    I suggest reading this post and following the suggestions in it:
    In particular:
    My recommendations have changed over the years, too, in line with Toyota's. The intent behind them is the same, however: To provide the maximum steering stability for any particular FIRST GENERATION Tundra that Toyota's specs for that particular Tundra can provide.
    The recommendation is thus worded the same for all FIRST GENERATION Tundras:
    1) Begin with Toyota's recommended alignment settings for your vehicle. That is easy to do, as the alignment machine has those specs in its internal database.
    2) Set camber and total toe dead on Toyota's recommended settings for your vehicle.
    3) Set caster right at the upper end of the range that Toyota's specs allow for your vehicle.
    Note that neither Toyota nor the alignment shop has any grounds to object, as these settings are within the tolerances that Toyota allows for your vehicle.
  16. #15
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Thread Starter
    Quote Originally Posted by DJ View Post
    Great. Thanks so much DJ. Is there a printed reference somewhere of the Toyota recommended alignment somewhere so I can check their work? I've googled with no success. I plan to take the truck back to them on Friday to see if they will bring it into tighter specs. My truck is a 2003 SR5 AC 4x4, btw.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
