Question Help !!!
+ Reply to Thread
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By oofy15354
Thread: Help !!!
  1. #1
    Rookie kctundra5465 is on a distinguished road.
    Join Date
    May 2012
    Location
    wv
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default Help !!!
    Hey guys I have a 2000 tundra v8 it idles but wont rev up I have replaced everything known to man can anyone help ? I drove it to the dealer because it would quit running at upon stopping in traffic. was advised by dealer frame needed replaced when I finally got it back it wouldnt do anything but idle and the dealer says its not there fault
  2. #2
    Supporter pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712's Avatar
    Join Date
    May 2009
    Location
    New York
    Posts
    938
    Liked
    37 times
    Rep Power
    9336
    Default Re: Help !!!
    Does the throttle cable move when you press the gas pedal?
    712
  3. #3
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,170
    Liked
    2091 times
    Images
    47
    Rep Power
    125681
    Just to clarify, this symptom started to occur after you got the truck back from a dealer frame replacement?
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads are JUNK!
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  4. #4
    Veteran Member oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354's Avatar
    Join Date
    Sep 2009
    Location
    Massachusetts
    Age
    20
    Posts
    1,359
    Liked
    262 times
    Images
    21
    Rep Power
    11150
    Quote Originally Posted by Remmy700P View Post
    To me, it sounds like it would shut off when idling in traffic so he took it to the dealer. Then, the dealer replaced the frame and now it only runs at idle.
    Also sounds like you will probably end footing the bill for whatever is wrong unless you are really good at complaining. This is why everyone going for the frame replacement should document the exact condition of the truck and have someone sign off on it BEFORE having the recall done so there is no dispute after
    cpearson817 likes this.
    2001 Black AC V8 4x4
    Current Mods: TrailFX Tube Steps, Uniden CB Radio with PA, Recon Tailgate LED Bar, Edelbrock Exhaust, Hankook Dynapro ATM 265/70/R16, Blacked Out Emblems, Plastidip Mirror Caps, Bumpers and Front Grill, Skid Row Skid Plate (Thanks to four_by_four), Full Blue LED interior lighting, Herculiner Bed Liner, Kobalt Low Profile Tool Box, Smitty Built Rear Shackle, Walmart Front AUX lights, JVC Headunit, Kicker Front Components, Pioneer Rear Speakers, Magnefine Filter, Viper Remote Start, Single in-Dual out 2.25in Exhaust
    Thanks to Rust: New Frame, New Calipers, New Rear Axle, Sway Bar End Links, Tailgate Straps, Exhaust Leaks
    To Do: Diff Fluid, Kenwood DDX419, 5100s Front and Rear set to 1in, Diff Drop, Poly Rack Bushings
    Quote Originally Posted by italiantundra88 View Post
    dave, every one has a weekness, yours is just any work on your truck
Posting Permissions
  • You may not post replies
  • You may not edit your posts
