Stock Air intake
+ Reply to Thread
Results 1 to 6 of 6
Like Tree5Likes
  • 2 Post By tundrunk
  • 3 Post By Remmy700P
Thread: Stock Air intake
  1. #1
    Lurking Member Justinpm1994 is on a distinguished road.
    Join Date
    Jan 2012
    Location
    Lafayette
    Posts
    25
    Liked
    0 times
    Rep Power
    2
    Default Stock Air intake
    I want to be able to modify my stock air intake of be as loud as possible. I love the sound of my CAI intake, but i am fearing its harming performance. How would i make my stock intake louder?
    Thanks, Justin
  2. #2
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,306
    Liked
    1238 times
    Images
    216
    Rep Power
    196487
    Default Re: Stock Air intake
    You can't really get it to sound like a K&N(or similar) but if you want more sound you can cut a hole in the front of the box. This will suck in air easier at highway speeds and will make a little more sound but wont be loud. You could get that Airaid kit that replaces the tube, the tube is really what muffles the stock intake. The box that has all of the ports for the vacuum tubes absorbs the sounds to silence it. An aftermarket filter might make more noise too, I know the K&N stock replacement filter does make a funny whistle and whoosh sound but I don't recommend it because it doesn't filter very well compared to other options.
    This feels like a fake thread... maybe... maybe not.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  3. #3
    Supercharged Member Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch. Johnny_5 wants you off his porch.
    Join Date
    Jun 2009
    Location
    Montana
    Posts
    3,068
    Liked
    363 times
    Rep Power
    278932
    I noticed a little more sound just by adding an AFE drop in. I later swapped in a True Flow tube (similar to the Airaid mentioned above) and didn't notice much difference.
    Sent from my DROID X2 using AutoGuide.com App
  4. #4
    Supporter jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy has earned a masters in rep power. jbtoy's Avatar
    Join Date
    Apr 2001
    Location
    MA
    Posts
    2,124
    Liked
    205 times
    Images
    67
    Rep Power
    17597
    Quote Originally Posted by Justinpm1994 View Post
    Thanks, Justin
    And the reason you want to do this?
    JB
    2000 Tundra Supercharged 4.7 TRD (Ivan) in Sunfire Red Pearl.
    Check out my cardomain location for pics of mods or use my gallery
    http://www.cardomain.com/ride/665303
  5. #5
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,170
    Liked
    2090 times
    Images
    47
    Rep Power
    125681
    Install a small shop-vac under your hood and have it set to turn on when you press the accelerator pedal. That'll get you the sucking/wheezing noise you're looking for. Home Depot. About $40.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads are JUNK!
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  6. #6
    Supporter SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,757
    Liked
    923 times
    Images
    24
    Rep Power
    26125
    Quote Originally Posted by jbtoy View Post
    he wants it louder than it currently is.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
