Question Tundra Transmission cooler
+ Reply to Thread
Results 1 to 4 of 4
Thread: Tundra Transmission cooler
  1. #1
    Join Date
    May 2012
    Location
    Blaine WA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default Tundra Transmission cooler
    Any thoughts on the factory installed transmission cooler on the 06 Tundra Double Cab 4.7L
    Is it adequate for pulling a travel trailer at max towing weight. The book indicates 7000lbs and the trailer is 6805Lbs. Should I replace or add to the factory installed cooler? Thanks bob
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,680
    Liked
    2796 times
    Rep Power
    238684
    Default Re: Tundra Transmission cooler
    Are you referring to the factory auxiliary cooler? If towing in the upper weight limits I would upgrade to a bigger (more efficient) cooler. Have not done so myself as I quit towing a few years back but may do so in the next year after the boat build is complete. PM Remmy and ask him his opinion on aftermarket transmission coolers as he has done the research.
    290,343 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Long Tubes with x-pipe and true duals, used and abused volant intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front and rear differentials, Cooper Discover ATP tires
    Highwaylizard needs a new front bumper
  4. #3
    Veteran Member marvbest's Avatar
    Join Date
    Aug 2004
    Location
    Las Vegas, NV
    Posts
    770
    Liked
    217 times
    Rep Power
    5643
    Whatever you decide, adding another cooler or upgrading the size of the installed trans cooler, you should seriously consider adding a Magnefine trans ATF filter also. There are numerous threads on here about using this filter for the ATF and also another for the PS fluid.
    "You can lead a smart-ass kid to knowledge, but you can be sure that he'll have to argue with the facts"
  5. #4
    Supercharged Member 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    2,178
    Liked
    964 times
    Images
    14
    Rep Power
    43644
    it's all here:
    ATF temp seems high
    All you Baja lovers check out: http://www.MasOlas.com
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
