New aftermarket headlights(and fog lights) installed, tested and run, pics
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Thread: New aftermarket headlights(and fog lights) installed, tested and run, pics
  1. #1
    Veteran Member Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family.
    Join Date
    Sep 2007
    Location
    MA
    Posts
    745
    Liked
    70 times
    Rep Power
    5392
    Default New aftermarket headlights(and fog lights) installed, tested and run, pics
    I finally got everything installed, everything but the HID kit I'm waiting to take delivery on but that is no problem as installing the kit from underneath will be super easy.
    I got both Eagle Eye headlights and foglights in and I put the 80W 9006 bulbs for my fog lights in just to get them aimed and to see what the output was like. I was just a bit disappointed at first with the overall output only because I had just finished installing a new set of fog lights with an HID kit in my G8 GT and with HID projectors in the low beams of that car, the output from a 55W 4500K low beam projector, coupled with a 25W 4300K new fog light kit, well, halogen just cannot compare, here is that car as a comparison;
    Both low beams and fog lights on the G8 GT;
    When I first took the Tundra on the road, I was totally disappointed in the output from the low beams, I thought that the pattern was full of holes and shadows, I was ready to turn around, go home and take the housings out and send them back to 1aauto but when I got to the cemetary that I go to to do my aiming, I had found that my drivers side light was very low, and the passenger side was very high. Once I got the drivers side raised and lowered the passengers side, all was right in the world and both the cutoff and the beam pattern was MUCH improved over the very worn out, 110,000 mile/9 year set of OEM headlamps. Here are the promised night-shots;
    Just headlights;
    Headlights and fogs;
    I'm going to expect that once I get the 35W 4500K HID kit in the fogs, I'll have incredible output. I also put the Lamin-X on the fog lights so that I won't have to worry much about pitting.
    At $90 for the fog lights and $73 for the head lights, both shipped, if they don't last long for some reason, I'll bite it and get OEM but they do come with a 3 year warranty which is nice. I'll wager they'll work for just as long as the OEM did and once they scratch/pit up again, I'll buy another set, if I still have the truck.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    179 times
    Images
    27
    Rep Power
    6289
    Default Re: New aftermarket headlights(and fog lights) installed, tested and run, pics
    that is some incredible light. those headlights put my HIDs to shame. looks great.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  4. #3
    Join Date
    Sep 2007
    Location
    MA
    Posts
    745
    Liked
    70 times
    Rep Power
    5392
    Thread Starter
    If you have HID's in the housings, the light is being thrown all over the place and is why it is not as bright on the road.
    I have a 100/130W in my drivers side housing and a 90/100W in the passengers.
  5. #4
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    179 times
    Images
    27
    Rep Power
    6289
    i agree but they are bright enough for what i need. maybe sometime down the road ill try projectors.
    CBTMA Member
  6. #5
    Join Date
    Sep 2007
    Location
    MA
    Posts
    745
    Liked
    70 times
    Rep Power
    5392
    Thread Starter
    I may take my old headlight housings and get a 3M refinishing kit, sand the lenses out to make them look mint again and maybe try my hand at putting some projectors in them myself, maybe.
  7. #6
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,667
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    just make sure you buy refill polish for that 3m kit so you don't have to buy a completely new kit. you will be using it 4-6 times a year as they will haze up like a mofo. it's one of those, do it the first time, then it needs to be done over and over again.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  8. #7
    Join Date
    Sep 2007
    Location
    MA
    Posts
    745
    Liked
    70 times
    Rep Power
    5392
    Thread Starter
    Quote Originally Posted by SuckersWalk View Post
    I'm glad you mentioned that SuckersWalk, for that reason I'm NOT going to bother with it. I'd rather wait and just buy new housings when the time comes.
  9. #8
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    179 times
    Images
    27
    Rep Power
    6289
    yea i polish my headlights as well but they are getting to the point where the inside is yellowed more because of how long the DRLs were used before i unhooked them. ill be looking to replace them sometime down the road.
    CBTMA Member
  10. #9
    Junior Member c350 Sr5 is on a distinguished road. c350 Sr5's Avatar
    Join Date
    Jun 2003
    Location
    Edinburg, Texas
    Posts
    54
    Liked
    2 times
    Rep Power
    10
    same here i've had to buff mine after i bought Meguiars lens restoring. ever since then......i've had to buff out the lens every 4 to 6 months as well.
    2003 White Tundra Sr5 v8
    -stock for now.
  11. #10
    Junior Member JDMHN8 is on a distinguished road.
    Join Date
    Apr 2006
    Location
    AZ
    Posts
    84
    Liked
    23 times
    Rep Power
    8
    Quote Originally Posted by c350 Sr5 View Post
    Sand with ~>1500 grit sand paper, then hit with quite a few thin coats of Clear Jet laquer. It's UV resistant and used on signs.
  12. #11
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,225
    Liked
    1139 times
    Images
    216
    Rep Power
    190697
    Headlights suck. Real men don't use them.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  13. #12
    Junior Member toyotalover79 will become famous soon enough. toyotalover79 will become famous soon enough. toyotalover79 will become famous soon enough. toyotalover79 will become famous soon enough. toyotalover79 will become famous soon enough. toyotalover79 will become famous soon enough. toyotalover79 will become famous soon enough. toyotalover79's Avatar
    Join Date
    Feb 2012
    Location
    Coral Gables (Miami), Florida
    Posts
    367
    Liked
    36 times
    Rep Power
    5
    Quote Originally Posted by tundrunk View Post
  14. #13
    Join Date
    Sep 2007
    Location
    MA
    Posts
    745
    Liked
    70 times
    Rep Power
    5392
    Thread Starter
    I just put in the 35W 4500K HID kit in the fog lights and tested them out and my gosh, between the new housings and the HID kit, the fog lights are now incredible.
    I'm now considering getting a Morimoto HID projector kit and doing the install myself.
  15. #14
    Join Date
    Sep 2007
    Location
    MA
    Posts
    745
    Liked
    70 times
    Rep Power
    5392
    Thread Starter
    I have a new set of 90/100W clear H4's on the way for the headlights as well as a 4300K set of Morimoto HID bulbs. I'm not a fan of the 4500K, they are still too bluish for my liking. I think the 4300K will be just right as I have a set of them in my G8 GT.
    I'll post up new pictures of the output as soon as I get it all installed.
  16. #15
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,667
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    you gonna beef up the headlight harness to run those hotter bulbs?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
