Starts fine...then dies - HELP HELP
+ Reply to Thread
Results 1 to 13 of 13
Like Tree12Likes
  • 1 Post By fljar
  • 1 Post By 2003bajatundra4x4ac
  • 2 Post By Remmy700P
  • 1 Post By cheapskate
  • 1 Post By Remmy700P
  • 3 Post By 2003bajatundra4x4ac
Thread: Starts fine...then dies - HELP HELP
  1. #1
    Rookie fljar is on a distinguished road. fljar's Avatar
    Join Date
    Feb 2002
    Location
    Evans, CO
    Posts
    6
    Liked
    1 times
    Rep Power
    0
    Default Starts fine...then dies - HELP HELP
    Have a 2002 Tundra Limited V8 4WD; meticulously maintained; 108k miles; did the timing belt/water pump/etc at 90k.
    Just about to go camping for the weekend and guess what??? Dead truck. Here's what happens:
    It starts just fine, plenty of juice (4 month old battery); does the normal rev to 1500 RPM when I start it; then dies.
    Also has done the following:
    Starts, revs, then sputters/hesitates like it's trying to stay on, and then just about dies (dash lights even come on like it dies) but then revs ON ITS OWN to 1500 RPM. Does this a few times then dies.
    Very little to no throttle response.
    Tank was 1/2 full so I filled it with fresh gas thinking it was bad gas. Still no go - had to get towed back home.
    Alternator?
    ECU?
    Throttle level assembly / throttle motor?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,365
    Liked
    1286 times
    Blog Entries
    78
    Images
    65
    Rep Power
    173757
    Default Re: Starts fine...then dies - HELP HELP
    Check to make sure MAF is connected?
    CEL? Codes?
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  4. #3
    Join Date
    Feb 2002
    Location
    Evans, CO
    Posts
    6
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by Highwaylizard View Post
    CEL? Codes?
    YOU ARE A GENIUS. I AM A MORON. A moron that gets to take his family camping.
    So, looked at the MAF and it was plugged in just fine. Thought i'd look on the inside of the air filter box to see the other side of MAF connection...
    I replaced the air filter earlier today...
    I used compressed air to blow out the dirty box...
    I stuffed a paper towel in the intake to ensure that the dirt I was blowing out didn't go in there...
    And you know the rest...
    THANK YOU
    Highwaylizard likes this.
  5. #4
    Veteran Member 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,437
    Liked
    228 times
    Images
    14
    Rep Power
    12376
    brilliant! lucky that paper didn't get sucked in.
    have fun!
  6. #5
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,365
    Liked
    1286 times
    Blog Entries
    78
    Images
    65
    Rep Power
    173757
    Quote Originally Posted by fljar View Post
    THANK YOU
    I am not all that smart - just lucky. Trust me, I have lots of time on my hands here in my mom's basement.
  7. #6
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2015 times
    Images
    47
    Rep Power
    120525
    ...I have lots of time on my hands here in my mom's basement...
    ... naked, in a beanbag chair, eating Cheetos.
    Highwaylizard and cpearson817 like this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  8. #7
    Veteran Member cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate likes to be on top. cheapskate's Avatar
    Join Date
    Feb 2009
    Location
    Kitchener Ontario
    Posts
    1,229
    Liked
    153 times
    Images
    13
    Rep Power
    11636
    Quote Originally Posted by Remmy700P View Post
    .....leafing through the lingerie section of your moms sears catalogue
    2012 Crewmax TRD 5.7, 4x4, 15% tint all around plus sunstrip. Ionic Gladiator running boards. Weathertechs front and rear. Line X, AVS vent visors. Viper 5301 2 way remote start, MBRP S5316304 cat back exhaust.
    Traded in my 05 4x4 DC, AFE CAI, Magnaflow Catback15820, Line X bedliner.
  9. #8
    Join Date
    Sep 2009
    Location
    Posts
    1,437
    Liked
    228 times
    Images
    14
    Rep Power
    12376
    while sipping an ice cold Yoo-Hoo!
  10. #9
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2015 times
    Images
    47
    Rep Power
    120525
    ...with the QVC channel on in the background...
  11. #10
    Join Date
    Sep 2009
    Location
    Posts
    1,437
    Liked
    228 times
    Images
    14
    Rep Power
    12376
    in the hopes that mom doesn't come home too soon because......
  12. #11
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,365
    Liked
    1286 times
    Blog Entries
    78
    Images
    65
    Rep Power
    173757
    Your forgot to mention the oil - lots of it squishing around.
    Quote Originally Posted by cheapskate View Post
    Dude! Why you tell on yourself like that!?
    Quote Originally Posted by 2003bajatundra4x4ac View Post
    Okay - I got nothing on that one
    Another 5th Amendment violator reveals himself . . .
    Oedipus holds no interest to me at all.
  13. #12
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2015 times
    Images
    47
    Rep Power
    120525
    Now we know what was behind Toby's vision issues...
  14. #13
    Join Date
    Sep 2009
    Location
    Posts
    1,437
    Liked
    228 times
    Images
    14
    Rep Power
    12376
    that coulda been the greatest "never ending story" of all time....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
